Old 12-05-2012, 08:49 PM   #701
meifert
Member#: 301676
2009 Forester XT
Originally Posted by swilcox01 View Post
Good idea or bad idea?
I have this:
I want to tow this?
Polaris RZR XP4 900 has a dry weight of about 1300 lbs. and a wheelbase of 107" and a width of 64". a the wheels.
I have no doubt that this will look moderately rediculous if I get it to work. I just hope my car has the capacity to pull it. I realize the trailer will contribute considerably to the weight I will be pulling, but Ive heard these things do fine puling up to 2000 lbs.
I towed a 1900 pound trailer from Atlanta to Los Angeles with no issues. just keep it below 70 mph and you will be fine.
meifert is offline   Reply With Quote
Old 12-05-2012, 08:52 PM   #702
tratpop
Member#: 130346
will look interesting, but will work. for liability your trailer would need trailer brakes. Our manual says once you are over 1000lbs they are needed. I have done about 1800lbs on my 4x8 utility with no brakes. (2006 wrx) barely felt it on the throttle, you knew it was there on the brakes, but never made me nervous or concerned. (reached highway speeds)
-tratpop
tratpop is offline   Reply With Quote
Old 12-06-2012, 10:10 AM   #703
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Garnet Red Peal (33j) e85
...i would try to find an aluminum trailer. I picked one up for hauling my sand toys around and it is great.
Another thing to note is drag coefiecent....just bc a trailer loaded weighs X amount and it's under X amount of towing capacity just remeber air has density and while driving the drag increases the wieght or the item(s) being towed...quick reply but it's true.
SuaveCougarBait is offline   Reply With Quote
Old 12-11-2012, 10:08 AM   #704
JaydEmm
Member#: 262984
Anyone think that this is feasible. I have a lot stiffer spring rates so i feel as if it would be able to handle the weight easily.
JaydEmm is offline   Reply With Quote
Old 12-11-2012, 10:08 AM   #705
JaydEmm
Member#: 262984
Obviously this hitch would be on the STI though.
Old 12-11-2012, 10:30 AM   #706
SuaveCougarBait
Member#: 255092
2007 WRX Limited
I wouldn't risk it. 200Lbs is that the rating is for tongue weight. You will likely exceed that.
Old 12-11-2012, 10:58 AM   #707
meifert
Member#: 301676
2009 Forester XT
not a chance. those are designed for class 4 hitches which have around an 800-1200 pound tongue weight limit...our cars have a 200 pound limit.
Old 12-11-2012, 02:41 PM   #708
JaydEmm
Member#: 262984
Gotcha thanks alot =D
Old 12-19-2012, 03:58 PM   #709
Justafour
Member#: 252066
2012 WRX LTD
DGM Sedan
What are our options for a rear cargo carrier? With 200 lb tongue weight it would have to be aluminum at 40 ish pounds and i doubt id have anything more than 100 back there so under 150.
This curt one weighs under 30 lbs:
Amazon.com: Curt 18100 Aluminum Cargo Carrier with Folding Shank - 2 Piece: AutomotiveAmazon.com: Curt 18100 Aluminum Cargo Carrier with Folding Shank - 2 Piece: Automotive
Any recommendations?
Justafour is online now   Reply With Quote
Old 12-19-2012, 04:09 PM   #710
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
200 tongue weight is for a trailer. Simple physics, the longer the lever the greater the force. 200lbs of trailer tongue weight is MUCH less than 200lbs on one of those baskets. Even 100lbs on one of those baskets will exceed the equivalent force of 200lbs of trailer tongue weight.
Old 12-19-2012, 04:11 PM   #711
Justafour
Member#: 252066
2012 WRX LTD
DGM Sedan
its been a while since ive had a physics class, so lets say you have a 30lb carrier, how much could you load and be safe?
Old 12-19-2012, 04:15 PM   #712
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
200lbs rating is 6" from the edge of the hitch.
Simple math/physics says
if 6" = 200lbs, then
12" = 100lbs
24" = 50lbs
Old 12-19-2012, 05:02 PM   #713
Justafour
Member#: 252066
2012 WRX LTD
DGM Sedan
you know ive been searching all these other forums with people talking about carriers and class 1 hitches and no one has brought this up. not even this "expert review":
http://www.etrailer.com/question-43251.html
i wonder how many people have messed up their cars because of the lack of info.
Old 01-02-2013, 09:11 PM   #714
mattcrum1223
Member#: 342373
02 WRX
Default Any help
Hey so i have an 02 wrx and im looking to get a hitch but i kniw there arent any 2" cuz the car isnt supposed to tow that much to need a 2", but could i put a hitch on and make an adapter to have a 2" hitch end. Im in school for welding so i could manage that but i would be putting a motorcycle carrier on it and my motocross bike. Would that that be considered weight on the tongue since its all being held up. I think the carrier weighs around 65lbs and my bike 225lbs. Would that be too much weight? I could of course just get a small trailer for it but i dont really want to deal with it if i dont have too.
P.S please excuse my spelling im on my ipad and sometimes i make mistakes. Thank
mattcrum1223 is offline   Reply With Quote
Old 01-02-2013, 09:19 PM   #715
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Curt requires a stabilizing strap to carry the weight of non-trailer loads.
Note: All non-trailer loads - bike racks, cargo carriers and so forth - should be supported with stabilizing straps. Failure to properly support these loads will void your hitch warranty from Curt.
http://www.etrailer.com/Trailer-Hitc...cleid=20029016
Old 01-02-2013, 09:26 PM   #716
premier00000
Member#: 251060
2008 Impreza Outback
They make adapters already. And by using an adapter you'll be moving the weight further from the car. The max tongue weight is 200lbs and by moving that out it would be like having more weight on the tongue like that.
Old 01-02-2013, 09:47 PM   #717
mattcrum1223
Member#: 342373
02 WRX
Ok thanks
Old 01-02-2013, 10:19 PM   #718
wjfawb0
Member#: 122526
05 Subaru STI
I towed bikes behind my subarus on a folding 4'x8' harbor freight trailer. I'd much rather have had a bike specific trailer, but the flat deck came in handy for all sorts of fun I probably already posted in this thread years ago. The trailer folds and stands in my garage so that I can still get two cars in there too.
http://www.fawbush.org/images/2008_5...haul_small.jpg
http://www.fawbush.org/images/2008_5...0_004small.jpg
http://www.fawbush.org/images/action_shot.jpg
I just welded up a 2" receiver tube to my utility trailer this weekend to add a removable winch to it for hauling things onto the deck. I can also use the winch in the receiver on the back of my truck. It's pretty handy.
https://www.youtube.com/watch?v=_1nvBz-NC0c
Here's some video of the buggy since I show it off a bit in the video. I built it in 10 months in my garage. It's my current toy and a great welding project.
https://www.youtube.com/watch?v=zngpuPspS8Q
https://www.youtube.com/watch?v=Ms3fE1ywu8g
https://www.youtube.com/watch?v=hgHQ-F7eBPE
wjfawb0 is offline   Reply With Quote
Old 02-06-2013, 09:59 AM   #719
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Were supposed to get dumped on this weekend! (Maybe)
Old 02-06-2013, 10:05 AM   #720
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Old 03-07-2013, 09:20 AM   #721
.HaVoK.
Member#: 229726
'09 2.Slow
I learned a lot from you guys here. Here's my Drawtite Class I hitch and my hitch cover I took the towing capacity sticker off as well.
Now just waiting on the Yakima Big Horn 4 Bike and next season will be running the Yakima Hitchski.
.HaVoK. is offline   Reply With Quote
Old 03-07-2013, 12:02 PM   #722
flboarder
Member#: 165133
2005 Saabaru
Whats the word on hauling a 5x8 enclosed trailer behind a 2002 wrx? I have searched and couldn't find any info. Will the wind resistance be too much for a little car? I was thinking about picking up a v-nose type to haul my motorcycle and random other crap a couple thousand miles.
Thanks,
Charlie
flboarder is offline   Reply With Quote
Old 03-07-2013, 02:06 PM   #723
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
I have that exact hitch cover and also the penguin one and the fleur d'elise
Old 03-14-2013, 11:00 PM   #724
caughtanSTi
Member#: 350075
Default 2013 STi towbar
Has anyone with a 2008-2013 STi hatch or 2011-2013 WRX hatch installed a towbar WITH an aftermarket exhaust? I'm considering the Invidia Q300 and the curt hitch but am not sure if they are compatible with one another.
caughtanSTi is offline   Reply With Quote
Old 03-17-2013, 12:06 PM   #725
aeoporta
Member#: 334126
Dark Gray Mettallic
For use with my kuat bike rack
Towing WRX behind RV with RV mounted tow hitch Ardrossan General Community 36 03-17-2016 01:07 PM
Tow Hitch flent General Community 2 11-26-2001 05:19 AM
tow hitch kream Bay Area Impreza Club Forum -- BAIC 6 04-01-2001 10:34 PM
