Old 10-16-2009, 09:14 AM   #26
48mpg
Member#: 58405
2004 Element GT65'd
Hydra, Hydramist'd STi
the wrap itself shouldnt fall off if you put it on well and secure it well. it is a woven fiberglass fabric. if you burn through the wrap then you have more serious problems than the wrap to worry about.
the ceramic coating may crack. wrapping that would help I guess.
48mpg is offline   Reply With Quote
Old 10-16-2009, 10:41 AM   #27
the suicidal eggroll
Member#: 51961
2005 STi
Originally Posted by my94saleen View Post
the aluminum foil, do you think its will also help hold the wrap better from falling off. cause how they get very brittle in time. it shouldnt start to flake or fall off because the foil is holding it all together i whould think. right
Possibly
I think it's probably wear and tear that breaks up the heat wrap...getting hit with rocks, sticks, tire pieces, getting soaked in water and then dried back out time and time again. The aluminum wrap should help protect the heat wrap from most of that stuff, possibly increasing the life of the wrap. I don't know for sure though, I've never done a side by side life expectancy test on heat wrap with and without aluminum wrap on top of it.
the suicidal eggroll is online now   Reply With Quote
Old 10-16-2009, 11:12 AM   #28
adrenalinejunkie
Member#: 204728
2004 STI
On my 6.6L nitrous durango, I wrapped both headers with the 2 2"x50' rolls Using metal ties. I learned a few important lessons from that build. Most important!---->Carry a fire extinguisher!!!!!!!!! My durango shot flames from under the hood at a stop light and I had no way to put it out(Pissing on it wouldn't of done ****). I never found what started the fire, but suspect that the passinger side fuel rail blew off spraying fuel everywhere.
For the short time I had it, the heat wrap worked very will. I'm sure that stuff works better than coatings. The aluminum tape looks cool and is very creative, but I would like to see how its durability ends up. All that adhesive may just melt or become brittle over time.
For my next exhaust setup I plan on doing this. First, wrapping with the 2 2"x50' rolls and securing with normal stainless steel ties. Then wrapping over that with the heat sheet wraping. Its a cloth that's woven on the inside and aluminum reflective on the outside. I have some made by DEI. Haven decided how I will secure that yet, but you can get it in tubing. I may just get tubing sheaths and cut down side and secure. It will defiantly hold inner wrapping together and be much more durable. Plus extra insulation. I'm not sure but think this is what NASA uses. If its what they use it's sure as **** good enough for me.8). Just my 2 c.
adrenalinejunkie is offline   Reply With Quote
Old 10-16-2009, 11:25 AM   #29
Member#: 51961
2005 STi
As I said before, it's been on my car for a year and a half and still looks and works like the first day I put it on. At one point a good 2 foot section of the header was literally coated with a few quarts of oil. When I got the mess cleaned up off the floor, I started up the car and drove around. After things got hot, the oil on the header smoked off, and that was the extent of it. A spill like that would have lit the car on fire if the wrap was exposed (it's happened on several occasions to other cars, apparently yours included).
Old 10-29-2009, 02:26 AM   #30
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! hey bro. your the man . i love your idea. virtually impossible to not spill some oil when pulling the oil filter . i do it everytime. would suck to throw out a $100 headers wrap job on account of it.or to have flames shooting up from under my car . im wrapping my headers tommorow and came accross this . looks like i'll stop at home depot before i get to it . you my friend just earned a treet. here enjoy . thanks again .
watchunglava is offline   Reply With Quote
Old 09-11-2010, 11:16 AM   #31
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
Default pipe
I wrapped & painted the wrap on my PDE down pipe
deep snow took most of it off one winter
I didn't like what I found when I unwrapped what was left of the wrap looks like rust on stainless steel
I'm taking it with me to work at the body shop I plan to remove all rust & paint with high temperature paint then wrap again
The way the metal is discolored has me a little concerned
cky211 is offline   Reply With Quote
Old 10-16-2012, 08:56 PM   #32
smadasam
Member#: 161271
2005 Saab 92x
Originally Posted by cky211 View Post
Will the pipes always rust like this with a wrap? Is that why you are supposed to use the dei ht silicon paint?
I have some dei titanium wrap that I was going to put on some new headers an up, but maybe I won't.
smadasam is offline   Reply With Quote
Old 01-02-2013, 10:50 PM   #33
AMG08
Member#: 254815
2008 wrx
white
About how much of a spool time difference would there be between a header being wrapped and not being wrapped, same header, and everything else the same except for the wrap?
AMG08 is offline   Reply With Quote
Another Header Wrap = Fire question. Treefolk Newbies & FAQs 10 07-29-2008 09:56 PM
Header wrap question D-Speed 2.5 Factory 2.0L Turbo Powertrain 13 02-13-2006 06:54 PM
question about header wraps. downsti Factory 2.5L Turbo Powertrain 2 12-14-2005 10:15 AM
header WRAP question Jejunum Normally Aspirated Powertrain 11 01-07-2004 04:59 PM
turbo wrap? header wrap? LttLDGN Factory 2.0L Turbo Powertrain 9 10-31-2001 07:05 PM
Message Board Statistics All times are GMT -4. The time now is 04:52 PM.
