Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 01-03-2013, 07:22 AM   #1151
Veblen
Member#: 281548
Originally Posted by waspdawg02
Intake Manifold question here. Can I use a STI's (04-07) and replace the one that is on my 08 WRX? I am looking at a bigger Top mount and if i can just get the STI TMIC and the manifold, that would be cheaper than buying the Other top performing Top Mounts.
Thanks for the help folks.
It's actually a bit more work than that, not to mention a step in the wrong direction ditching the composite mani. Imo wait and get a proper top mount designed with the 08+ in mind.
Veblen is offline   Reply With Quote
Old 01-03-2013, 11:40 AM   #1152
Ranatsu
Member#: 87314
2013 BRZ
Crystal Black Silica
It may be more work if the 08 wrx uses the compressor housing that mounts to the bottom of the intercooler via the bolts rather than the rubber/plastic hose.
If thats the case then he would need to change the turbo as well, or use some f'ed up routing to duct it properly.
Ranatsu is offline   Reply With Quote
Old 01-03-2013, 12:43 PM   #1153
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
I need some shims/buckets for the valves on my baja. All the ones I have are too big, anyone have any? call my cell please- 360-914-1297
bugeyetex is offline   Reply With Quote
Old 01-03-2013, 01:50 PM   #1154
Ranatsu
Member#: 87314
2013 BRZ
You know the stealership has every size possible right?
Old 01-03-2013, 04:18 PM   #1155
BlueLGT
Member#: 247590
2010 Legacy GT
Tonight's Meet:
Lion and The Rose
842 NW Loop 410 (Park North Shopping Center)
San Antonio, TX 78216
Time: 7:30pm - whenever
Please rsvp on the Facebook event --> https://www.facebook.com/events/442605135793679/
If you can't do that, let one of the regulars know. (i.e. Ranatsu, Cozykat, or myself).
BlueLGT is offline   Reply With Quote
Old 01-03-2013, 04:20 PM   #1156
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Yeah, not in stock and $25 each... Maybe that's why they call it a stealership. They just send their heads to the machine shop and have them grind away to get the right clearance.
I found a machine shop to do it for $150. I'm happy, I guess.
Old 01-03-2013, 06:28 PM   #1157
Chuck2012
Member#: 324568
2005 Wrx Sti
Someone with land around San Antonio take me dove hunting.
Chuck2012 is offline   Reply With Quote
Old 01-04-2013, 12:06 PM   #1158
SnowmanFX
Member#: 25753
2015 WRX
Lightning Red
2nd..
SnowmanFX is offline   Reply With Quote
Old 01-04-2013, 02:44 PM   #1159
cozykat
Member#: 160387
'93 SVX (Red)
'07 FXT (OBP)
Did you try Duffin Engines? They have worked on several subaru motors that I can recall.
cozykat is offline   Reply With Quote
Old 01-05-2013, 08:35 PM   #1160
Representexas
Member#: 115350
2015 STI Limited
Hatch sold back in a Muffk'n STI again!!!
2013 Sedan Have to add the experience at North Park Subaru was 10000x better than Gillman in San Antonio. Thanks to Chad for getting the deal done the way I wanted!
Representexas is offline   Reply With Quote
Old 01-05-2013, 08:59 PM   #1161
deityXanthus
Member#: 294485
thank you sir ralliart4. i was just curious. gonna keep running regular pump. i'm at the top end of what my stock clutch can handle anyways. when it's cold outside like right now and i really get on it... the car screams at about 400 whp. and the clutch slips every once in awhile in third and forth gear. i'll be doing clutch next with some upgraded brakes soon. thanks for input.
Originally Posted by Ralliart4 View Post
It depends on the mods you have and what you are looking for more than anyhting else.
- you are going to need more than 1000cc injectors to support most of your e85 needs.
- that 255 will also run out at about 450whp
If you are able to make it up to those numbers the DW400 pump and some 1200cc+ will work quite well. Keep in mind that e85 is basically ethanol racing fuel closer to 109oct regular petrol and you need a lot of it because of the burn dynamics approx 35%> or more.
One last thing if you are trying to have decent gas mileage forget the e85!
deityXanthus is offline   Reply With Quote
Old 01-05-2013, 09:01 PM   #1162
deityXanthus
Member#: 294485
oh and i installed the sick speed blue horns on my car. what a pain in the ass to find the right bolt set up on the passenger side horn. since it didn't have a already threaded hole. in the end i had to use a nut clip and bolt after cutting slightly in to the metal to allow the clip to fit. but now that it's done i'm happy with it.
Old 01-06-2013, 10:59 AM   #1163
Representexas
Member#: 115350
2015 STI Limited
By the way if anyone is interested, North Park San antonio will have one Orange Sema addition STI in may and Gillman will have one orange wrx.
I originally was going to get the Sema edition at North park but there is a $2,000 up charge which i couldn't justify spending for some paint.
Old 01-06-2013, 03:55 PM   #1164
Chuck2012
Member#: 324568
2005 Wrx Sti
If I was buying a car that expensive I think I would fork out the extra 2k for a unique color
Old 01-06-2013, 08:05 PM   #1165
SATSTI
Member#: 341814
2013 STI
Holy crap! Did you just get it? Was that the one that the GM was driving? If so...they tried to get me to buy it...but it didn't have the shifter knob on it (someone actually stole the knob). I drove it even without the shifter knob though, and that's what made me decide to go with the STI sedan.
Congrats man.
SATSTI is offline   Reply With Quote
Old 01-06-2013, 11:18 PM   #1166
Representexas
Member#: 115350
2015 STI Limited
Congrats man.
Hahaha yes man! That was the one! Just like 20 minutes ago i was looking at the invoice and realized they charged me for a $189 STI shift knob that is not in the car. It's the standard shift knob! It's not really an option i wanted anyways but i did pay for it and it just didn't cross my mind at all. I emailed the sales guy and i hope he can straighten it out for me. He has been pretty cool so far so hopefully it will be a non-issue.
I got them to drop the price due to to the couple miles put on it and it worked out perfect for the price I wanted to pay. I was going to order the orange special edition but its a 3 month wait and a price bump, to me the low price and driving off the lot was the way to go. No Regrets.. can't wait for the 1,000 mile break in so i can hit up an autocross again!!! It's been for ever.
Old 01-07-2013, 02:32 AM   #1167
SATSTI
Member#: 341814
2013 STI
Ouch. Good catch.
Old 01-07-2013, 11:32 AM   #1168
Vater
Member#: 267354
2011 STI Limited
Congrats! Chad sold me my STi, great guy
Vater is offline   Reply With Quote
Old 01-07-2013, 12:30 PM   #1169
HonduHunter
Member#: 28408
2002 vf48ed WRX
very nice car man!! congrats!!
HonduHunter is offline   Reply With Quote
Old 01-07-2013, 02:35 PM   #1170
SATSTI
Member#: 341814
2013 STI
Now just replace those wheels!
Old 01-07-2013, 03:44 PM   #1171
SnowmanFX
Member#: 25753
2015 WRX
Lightning Red
I like those wheels actually.
Old 01-07-2013, 04:04 PM   #1172
Representexas
Member#: 115350
2015 STI Limited
Thanks everyone !
Havnt decided on first mods yet but the wheels will be way later. I dig em..
Accessport and a catback will come first.
Old 01-07-2013, 04:54 PM   #1173
Chuck2012
Member#: 324568
2005 Wrx Sti
Thanks everyone !
I say driver mod first. Enjoy your new car and warranty.
Old 01-07-2013, 06:26 PM   #1174
Representexas
Member#: 115350
2015 STI Limited
Ya chuck true, maybe ill start with some coil overs.
Old 01-07-2013, 06:59 PM   #1175
Chuck2012
Member#: 324568
2005 Wrx Sti
Going to medina for a little drive after I eat if anyone wants to go. Gonna drive park road 37.
Rally San Antonio, San Marcos, Austin RichardM Texas Impreza Club Forum -- TXIC 6 05-11-2011 11:56 AM
ATX/San Marcos/San Antonio photoshoot aznburn210 Texas Impreza Club Forum -- TXIC 74 01-13-2008 11:31 PM
San Antonio Raceway thread Richardcranium419 Texas Impreza Club Forum -- TXIC 19 11-29-2007 08:08 PM
Tint/Inspection San Antonio/New Braunfels/San Marcos Area Yogiwerx Texas Impreza Club Forum -- TXIC 2 09-01-2006 04:06 PM
The San Antonio State Meet Thread Lux Texas Impreza Club Forum -- TXIC 33 01-25-2005 04:24 AM
