Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Mid Atlantic Impreza Club
Old 01-02-2013, 07:40 PM   #1
Ryuduo
Member#: 325432
Talking Trans/Rear Diff Fluid Change!
It's time to put this new Subaru Extra-S good stuff in my 02 WRX. I am having trouble finding a place to do this, especially since it gets dark quickly outside now. Would anyone like to help out with this quick DIY? Foods and beers available!
I am in the Northern Virginia area.
Ryuduo is offline   Reply With Quote
Old 01-02-2013, 07:54 PM   #2
infinite012
Member#: 74392
2015 Forester
It's super easy. Just grab a flashlight and a couple ramps if you don't want to deal with jacking the car up on stands.
Old 01-03-2013, 08:55 AM   #3
Ryuduo
Member#: 325432
Hmm sounds good. My driveway is on an incline, gotta do some measuring to figure out how much wood I need. How good are the plastic ramps I've seen at some stores?
Old 01-04-2013, 03:54 PM   #4
onsit
Member#: 292225
08 WRX (16g)
Like $50 for some Rhino ramps.
-or-
spend $12 at home depot for some wood, and create your own ramps!
onsit is offline   Reply With Quote
Old 01-06-2013, 03:48 PM   #5
CR22
Member#: 167470
2005 Subaru
Don't use a torque wrench. My differential rear cover plate cracked when I performed the diff fluid change a few months back. If you look at the 1/2 inch drain plug it doesn't have a head and body like the oil drain plug. It's one continuous screw so if you try to torque it, it will just keep spinning until the plate cracks or until it screws itself into the diff.
I felt like an idiot after realizing this fact.
CR22 is offline   Reply With Quote
Old 01-06-2013, 03:49 PM   #6
Candor
Member#: 219200
An always loosen the top screw first.
Candor is offline   Reply With Quote
Old 01-08-2013, 08:02 AM   #7
Ryuduo
Member#: 325432
Awesome, thanks for the tips guys. Got the job done! Checking the tranny dipstick seems to be a little off, maybe I am not checking it correctly. I don't want to overfill the transmission, but I did put just enough in to account for error. The stick reads half way, but I get a different reading every time ><
