Old 12-22-2012, 01:12 PM   #1
Darth Sleader
Member#: 293322
2008 WRX Sedan
Dark Gray Metallic
Default P0031 O2 Sensor issues SOLVED
Hello,
It's been over a year that I've been dealing with this and it seems that it's finally fixed! I really hope this helps someone else. This would have saved me some serious time and money.
I've gone through five (!) O2 sensors in a year. Each time, the code was P0031 which deals with the electronic heater in the sensor that gets it up to operating temps faster for more accurate O2 readings.
The bottom line is, the issue for me was in my headers. I have a Perrin equal length header, the older one with the slip-joint adjustable fittings. Newer models do not have the issue that caused me so much strife.
The issue is that the sensor bung is welded into the header in such a way that the sensor sits exactly parallel to the ground. As the gases in the exhaust stream cool, moisture forms and collects on surfaces inside. This moisture gets in the tip of the O2 sensor and eventually kills it. The factory Subaru header has the sensor situated so that it points downward at a slight angle (maybe 15 deg or so.) Apparently this downward angle allows moisture to exit the sensor tip.
Last week my mechanic took the header off and took it to an exhaust welder to reposition the sensor bung. As it turns out, the bung is welded right at the junction between right and left piston banks, and repositioning it "northward" to point down would only be getting exhaust from 2 pistons, not all 4. So he decided to mount the sensor in the uppipe instead. It's approx. 3" farther downstream than the original position. He did extensive testing and readings on sensor data and it seems to be rock-solid. Well within spec.
My mechanic mentioned some other cars he knew of that had this same problem and same symptoms as well so I'm pretty confident this will be a fix.
Good luck!
Jer
Darth Sleader is offline   Reply With Quote
Old 01-02-2013, 10:20 PM   #2
250SilverSti
Member#: 306017
2004 WRX STi
Thank you so much. I really hope you are right. Im gonna do you did and see if that works. What downpipe are you running on your car. I really appreciate all this information. It sounds like what my car has been doing . Look for update soon
250SilverSti is offline   Reply With Quote
Old 01-03-2013, 10:21 AM   #3
Darth Sleader
Member#: 293322
2008 WRX Sedan
Dark Gray Metallic
Hey!
My downpipe is a Perrin (I have their turboback exhaust setup). The O2 sensor was inserted into the UPpipe, which is also a Perrin.
I hope that helps!
Jer
