Old 12-12-2012, 02:41 PM   #26
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I applaud King for seeing a potential problem and making an effort to engineer a solution. Marketing hype or not, at least they can defend the changes they made and why they made them.
In the end I'm with Turn In I just don't want to test something new on a customer engine or even on my engine when frankly there isn't a problem there for us to fix. Oiling issues (not related to g forces found in road racing) have always been a build issue and if you maintain adequate oil pressure you don't have a problem. Time and time again I see engines with inadequate oil pressure, I warn the customer, they don't listen, and the engine spins a bearing.
If these bearings can actually improve oiling without reducing oil pressure then maybe it's a winner. If oil pressure drops due to increased oiling it will lead to more failures, not less as we have a limited selection of bolt on oil pumps.
Thanks,
Phil Grabow
Old 12-13-2012, 10:25 AM   #27
3MI Racing
Member#: 200987
I agree that there isn't an issue to 'fix' and that build quality is the leading cause of bearing failure...that and tuners not having an understanding of MBT
However, that doesn't mean that there isn't room for improvement.
If they are improving oiling, as I was stating to Jeff and actually briefly spoke with him about last night, you aren't losing oil through the radius and out the chamfer (which drops oil pressure at the rod bearing). A higher percentage of oil pumped to the mains is getting to the rods instead of simply being spewed past the shells and back to the pan. So if you can sustain necessary pressure for the cams and mains, while maintaining essentially the same oil at the rods, what do you have to lose? It might actually allow a lower pressure.
I want to see a leak decay test results or to have done now. However I have a feeling this will just leave me to do my own testing...
Old 12-13-2012, 04:39 PM   #28
Serkan
Member#: 180514
2004 Sti
Isn't the company supposed to make all the testing and prove us where they made the improvement with the new design ? Instead of people being genuine pigs.
It's nice that there is a representative for the company but he is not showing us any proofs.
Did they even test them in an ej engine pushing good power ?
Serkan is offline   Reply With Quote
Old 12-14-2012, 10:28 AM   #29
3MI Racing
Member#: 200987
I really am curious to hear of what testing they did. I imagine for the claims that they're making, the would have done a decay test at least. We did this at Volvo Powertain to diagnose and analyze the oil system (flow and pressure) in the real world to study implemented changes.
As for the guinea pig bit; I'm an engineer, I always do my own testing.
Old 12-20-2012, 11:30 PM   #30
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Originally Posted by GideonZ View Post
Gideon Saslavsky
King Engine Bearings
Im curious if you guys ever shipped the old style bearings in the new packaging?
Old 12-21-2012, 09:52 AM   #31
3MI Racing
Member#: 200987
^^^makes me wonder why you're asking that.
I'm curious why Gideon hasn't replied. I know he's logged on since I posted my questions...
Old 12-21-2012, 05:02 PM   #32
EMS
Member#: 14116
Originally Posted by Crystal_Imprezav View Post
The Mahle bearings did the same thing a long time ago.
If they whould be available for Subaru that would be nice! AFAIK only the rod bearings are available from Mahle/Vandervell at the moment and they have "normal" looking tang.
EMS is offline   Reply With Quote
Old 12-21-2012, 11:26 PM   #33
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Got this from the other thread on this revised bearing http://forums.nasioc.com/forums/show....php?t=2431764
oh and also new packaging:
also would like to know, from what I see, it "appears" as though the new bearings came in this new package and were swapped before the customer got it. Reason I say this, is because the new style (both in same new box & same part # on label, purchased at same time) came shrink wrapped/never opened, and the old style w/out the ovaled hole came just as the bearings sitting directly in the plastic tray
btw, place items were shipped to and customer quoted above, wasn't directly purchased from you
If King could chime in on this question, Is there anyway old style bearings went in this new package? I guess from what jeff mentioned, this isn't the first instance for him
Old 12-21-2012, 11:49 PM   #34
Member#: 278519
30r E85 sti 450+whp
kb'izzle
glad to hear there's nothing wrong with the old style as they are in my motor now I haven't even got back yet
I would loved to have you build the motor just didnt have the scratch for the honeybadger & had to go fairly basic, Thanks for the phone call back answering all the questions, def a good guy to deal with here
Old 12-31-2012, 10:07 AM   #35
ron sledge
Member#: 340603
Default Performance & Technical Manager
No we will not ship the older style EJ Subaru bearings in the new packaging.
ron sledge is offline   Reply With Quote
Old 12-31-2012, 10:24 AM   #36
ron sledge
Member#: 340603
Thanks,
Phil Grabow
King tested the new design main bearings in a high horsepower engine and the result was at least 10 lbs of oil pressure increase. The new design stopped the leakage of oil at the main and forced more oil thru the crankshaft to the rods. The oil slots allow a better distribution of oil into the main bearing clearance space.
Old 12-31-2012, 10:44 AM   #37
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Any easier way to order these bearings for an 04 sti? I went on your site and didn't have much luck finding what I needed
cowboy_Rob is offline   Reply With Quote
Old 01-02-2013, 10:58 PM   #38
wrx1392
Member#: 342331
2003 wrx
blue
just put a set of these in my o3 ...they lasted 450 miles then #2 spun...the rest of the bearings are trashed ????? the car went 234,000 on the stock bearings
wrx1392 is offline   Reply With Quote
Old 01-02-2013, 11:14 PM   #39
Juice66
Member#: 340526
2004 WRX STi
HTA86
Probably because you cant build a motor
Juice66 is offline   Reply With Quote
Old 01-02-2013, 11:42 PM   #40
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Did you have oil pressure? Did you check clearances? Use assembly lube? You said the stock ones lasted 234000 so I'm assuming you had a bearing failure then rebuild it did you hot tank everything and replace the oil pump and oil cooler to get out all the metal shavings?
Old 01-03-2013, 02:53 AM   #41
wrx1392
Member#: 342331
2003 wrx
blue
the rebuild was due to a piston ring land being crushed , i wont even respond to the guy that just has to flame people.
cowboy ...yes i did every thing you said ,plus had the motor rebalanced when i put fordged pistons in head studs,plasti gauged it ,heads were done ,and crank was polished .i think i got a crapy oil pump is all i can figure .i'll have a pressure gauge on it next time . but i never had a oil light come on .been building engines since i was 15 years old .high school and college auto tech classes and GM school built a lot of motors ...never had one do this .Thanks for the tips
Old 01-03-2013, 11:07 AM   #42
wantsti
Member#: 134764
04 sti
java black pearl
plasti gauge is problem
wantsti is offline   Reply With Quote
Old 01-03-2013, 11:42 AM   #43
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
not ideal ^ for sure
Old 01-03-2013, 01:40 PM   #44
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Plastigauge works fine. Plenty of people use it all the time. I used it on my build and went 43k before I cracked a cylinder after changing turbos
Old 01-03-2013, 01:44 PM   #45
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya...whats +-.001" in your main clearances
Old 01-03-2013, 06:13 PM   #46
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
King, why haven't you mentioned that you worked with http://vtcar.com/ on these bearings. The company that builds all the cars these kiddies look up to haha.
All these pages and still no pictures? I have been using these bearings since the release and have yet to have an issue in the 10+ motors I used them in.
Here you can see the 360 groove, the smooth ID side where the tang indent would usually be, and the slotted oiling holes.
I would of kept using the NON-G bearings over the ACL anyways. King always has better tolerances for me, and the differences bearing to bearing are all within .0002"
I don't need to make a reason for people to buy them, the less people that believe in change is good, the more bearings for me. No dreaded backorder issues... ughhhh...
wrxadam05 is offline   Reply With Quote
Old 02-07-2013, 12:46 PM   #47
kakarot09
Member#: 182375
08 Sti
Wrbm
What sort of clearances has everyone been using with these? I notice there is no extra clearance option. My mains are stock tight. I'm okay with that but it would be nice to hear that someone else has done that also.
kakarot09 is offline   Reply With Quote
Old 02-07-2013, 12:48 PM   #48
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Ok guys - I'm willing to give the new bearings a shot on my personal motor that will be going together soon.
Problem is the King website is a nightmare to get to the catalog to figure out even the part numbers.
Can someone help me out?
Old 02-07-2013, 12:54 PM   #49
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
STD Main Bearings
MB3582XPG
STD Rod Bearings
CR4125XPG
Ive got a set in my personal motor, we will see how it goes!
jnorth85 is offline   Reply With Quote
Old 02-07-2013, 12:58 PM   #50
ILikeBeans
Member#: 173053
^^^ beat me by THAT much! I'm also putting these in my current build.
MB5382XPG are the mains in standard size, #5 thrust.
CR4125XPG are the rods in standard size, 52mm
Both are available in STDX for .001 extra clearance.
ILikeBeans is offline   Reply With Quote
