Old 01-02-2013, 12:32 AM   #1
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Default Could a 10-15% leakdown and low compression cause a slight hesitation?
Hey Guys,
So my motor needs a new set of rings and a hone. Hopefully I can get away with that. Currently they are 99.75, worst case I go to 100mm if need be.
I do have a question, I've always had a slight hesitation on my built shortblock and was wondering if it was because of the high leak down and compression being low.
Cylinder 1 = 117
Cylinder 2 = 117
Cylinder 3 = 105
Cylinder 4 = 105
Cylinder 1: 5%
Cylinder 3: 12%
Haven't done the remaining cylinders but I assume the worst.
CP 8:2:1 Forged Pistons
Manley Turbo Tuff I Beam Rods
Nitrated Crank
MAP H11 head Studs
New Gasket/Seal kit
Rebuilt heads
FIC 1100cc injectors
The hesitation is off boost at 2-3k rpm. If I go into slight boost its a dream to drive. A/F are a solid 14.7 while this hesitation occurs. So it always baffled me and I always tried to tune it out. Its a 2004 STI swap, no air leaks (smoke tested), Fuel trim under 2%. So I'm leaning towards the bad motor build.
Also, might as well ask. Cylinder 4 sparkplug has a slight white residue, compared to the other cylinders that are brownish. I haven't checked the leak down on that cylinder. Usually people have issues with cylinder 1 and 3. Could be the injector being lower in cc, I'll get those cleaned out and retested (bought used). It could be the injector for all I know.
Any thoughts would be awesome! If I missed any crucial information, please ask. I'll edit the first post.
Thanks!
OC_Nooby is offline   Reply With Quote
Old 01-02-2013, 11:46 PM   #2
OC_Nooby
Member#: 311781
2003 WRX w STI V8
bumpers
Old 01-03-2013, 10:39 AM   #3
Tripintaz
Member#: 245218
2013 STI Limited
yes, yes it could
Old 01-03-2013, 10:57 AM   #4
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
Most people have issues with #4 cylinder, not 1 and 3. Before my rebuild I was getting blow by and that was causing hesitation as well. Assuming it was a reputable shop and their good at what they do, take it back and ask them.
WRXSteye20008 is offline   Reply With Quote
Old 01-03-2013, 03:27 PM   #5
OC_Nooby
Member#: 311781
2003 WRX w STI V8
That's why I'm thinking the injector might be a tad dirty? Or just lower cc. Cylinder 4 is the first in the supply chain is it not?
Regardless I'll send the injectors back for a clean/retest when the sb is pulled.
