Old 12-12-2012, 09:17 PM   #1
jdm_palomino
Member#: 335755
2005 Wrx Hybrid
Default misfire issue... help?
I have changed all spark plugs and switched around the coil for cylinder #4 and I keep getting a cel for cylinder 4 misfire, it stays on and sometimes it flashes. What could cause this?
jdm_palomino is offline   Reply With Quote
Old 12-12-2012, 09:36 PM   #2
chris07sti
Member#: 177312
2005 STI
Aspen white
this has been covered a lot. Have you done a compression and leakdown test? can also be injector. Fuel, Spark, rings...try and search there is a lot of info.
chris07sti is offline   Reply With Quote
Old 12-19-2012, 12:14 PM   #3
tekhnogod
Member#: 250957
2008 Impreza Outback
Hi,
I have a 2008 Subaru Impreza Outback Sport with 94k miles (have always done oil change, 30k and 60k service on time). The check engine light started to blink while I was driving. Within .5 mile, I was dead in the water. I towed it to my Subaru dealership and they said the sparkplugs (100k mile life expentancy) failed which caused the coils and spark plug seals to break. After they performed the work, the car still will not run. The speculate that its the right cylinder head that needs to be replaced but will have to charge $700 just to diagnose the problem. What do you think is going on? It sounds like we have a similar. Thanks.
Note: I know little about cars so I'm desparately seeking advise.
tekhnogod is offline   Reply With Quote
Old 12-19-2012, 02:43 PM   #4
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
What code did they get?
Does the engine turn over when trying to start?
Spark plugs should last between 30K and 60K.
CRAZYHAWK is offline   Reply With Quote
Old 12-19-2012, 03:34 PM   #5
tekhnogod
Member#: 250957
After the new spark plugs were installed and everything. They told me that the computer read out is good. However, the car still will not start.
They told me that the spark plugs were platinum tipped so it should last 100k miles.
Old 01-03-2013, 05:14 PM   #6
GigglesTheBugeye
Member#: 309935
This is what I am going by for mine. Good luck! http://forums.nasioc.com/forums/show...g+knock+sensor
GigglesTheBugeye is offline   Reply With Quote
