Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 12-21-2012, 07:23 PM   #151
creative wrx
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
how much longer do you expect before these kits will on on the market
creative wrx is offline   Reply With Quote
Old 12-21-2012, 09:36 PM   #152
induction addiction
Member#: 340643
There is way more flow capacity, with that filter/elbow setup, than that turbo will ever need. I don't see it as a choke point. We'll see if things change with the GTX3576-R, but I'd be really surpised if it did.[/quote]
Is room an issue with running a 4 inch inlet on the turbo??
induction addiction is offline   Reply With Quote
Old 12-28-2012, 03:15 AM   #153
blk25rsti
Member#: 211942
1999 2.5RS coupe wht
01 2.5RS coupe BRP
Subscribed. Very interested to see what's to come!
blk25rsti is offline   Reply With Quote
Old 12-31-2012, 07:12 AM   #154
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It feels like it's taking f-o-r-e-v-e-r!!! Having to have a second built motor is what's causing the delay. Being the engineer that I am, I can't just leave well enough along. I'm way more involved with the building process than I should be, adding my own changes, tweaks and so forth to the build. So it's just taking a long time.
Is room an issue with running a 4 inch inlet on the turbo??[/quote]
From this pic you can see, there is room of you don't mind making a minor cut for some clearance. This is something we did on the very first go around and I never liked it. I was very skeptical to CNC mill the compressor housing and use the inlet reducer, but having access to engineering resources as Garrett is handy for things like this. The data showed no reduction in flow and a bit of an improvement in surge characterisitics
Performance wise, we saw no difference. I somewhat expected the turbo to sound different is some way, but there was zero audible difference in air sucking, turbine/compressor whine, etc.
Us too! We're working on something else, very preliminary too. Unfortunately (I think so far), it will only be for GRs, but if we can get the goemetry to work there will no longer be any comparisons (performance wise) to other kits. For the GDs, it's starting to look like, what you see is what you get, which isn't exactly a bad thing. More torture testing to come.
Old 12-31-2012, 11:11 AM   #155
creative wrx
Member#: 141754
04 stock wrx ;)
It feels like it's taking f-o-r-e-v-e-r!!! Having to have a second built motor is what's causing the delay. Being the engineer that I am, I can't just leave well enough along. I'm way more involved with the building process than I should be, adding my own changes, tweaks and so forth to the build. So it's just taking a long time.:
Well if and when you want to start testing the kit on other cars let me know. I've been very interested in the kit from day 1 and it would save me a lot of time instead of having to of done my own low mount kit.
Old 01-01-2013, 07:36 PM   #156
vinnie_vegas10
Member#: 292705
hi im intrested in this setup. where could i buy it??
vinnie_vegas10 is offline   Reply With Quote
Old 01-01-2013, 08:47 PM   #157
Gigs90
Member#: 306719
2003 S204 Wagon
Read the thread , Its still a prototype setup.
Gigs90 is offline   Reply With Quote
Old 01-03-2013, 08:13 AM   #158
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Cool. I really appreciate your willingness to make a leap into the semi-unknown Our first 'beta' batch will be small and there are some criteria we'll be looking for as well in testers. You're not too far away, so you've already got that in your favor
See below
Something else I've been thinking about. Much easier on the GRs since there's more space, but maybe... maybe... TS
Old 01-03-2013, 10:53 PM   #159
creative wrx
Member#: 141754
04 stock wrx ;)
Keep me posted by the summer i should i have my new set of heads all done as well as some other supported goodies.
Old 01-06-2013, 06:10 PM   #160
chris keefe
Member#: 270312
2005 WRX STI
subscribed! want to run a similair setup on my 2.35L with built heads!
chris keefe is offline   Reply With Quote
Old 01-07-2013, 08:32 AM   #161
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We've purposely retained OEM spec heads because that is likely what the majority of the market will be. If they are built, results should only get better
Very cool!
Old 01-09-2013, 12:11 AM   #162
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Subscribed, would be awesome to have an EFR TS on the GR's!
Tyrial is offline   Reply With Quote
Old 01-14-2013, 07:28 AM   #163
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We're not designing around the EFR turbos. They are just too freaking big/long for that location as this kit should for the most part not require and fabrication to the car.
That being said, I'm sure anyone with a BFH/saw and some fab skills could make it work.
Old 01-29-2013, 03:55 PM   #164
BMWidmer
Member#: 205427
2000 RSTI w/ hta68
Army Green
Still in line to get the GC kit rolling. Chris i have not forgotten about this and i hope you didn't forget about our emails! Sent you a pm
BMWidmer is offline   Reply With Quote
Old 01-30-2013, 03:42 PM   #165
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Any updates?
Old 01-30-2013, 07:16 PM   #166
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Awesome looking kit, makes me consider waiting longer to see where it goes. I'd certainly be up for helping test cool stuff out instead of buying the same setup off the shelf that everyone else goes with.
ResidentR is online now   Reply With Quote
Old 01-31-2013, 07:34 AM   #167
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
My memory often needs a rattling so don't ever hesitate to do so. I refreshed my memory and now recall our conversations
Originally Posted by Tyrial View Post
Any updates?
The car has been sitting for a couple weeks with the bumper off. Nothing major, I just want to get the A/C condenser back in before summer. Waiting on the built engine's parts to come in and off it will go for another transplant.
Here's where we're hoping it goes... Testing with current GTX3071-R with 0.63 Tial turbine housing (baseline), then back to the 0.82 turbine housing for comparison. From there we'll install the GTX3576-R (likely the 0.82 Tial turbine housing) and see what she does. Depending on how everything goes, we may also test a couple different fuels (E85 and race fuel).
Old 02-01-2013, 02:27 PM   #168
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Awesome, ETA on the new motor?
Old 02-01-2013, 08:13 PM   #169
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
That 3576 should be nice turbo for the low mount. I know you want to test it with stock cams but it would really come alive with some cams and head work!!
Old 02-05-2013, 04:28 PM   #170
BraveSTi
Member#: 262030
Very clever. Looks good!
BraveSTi is offline   Reply With Quote
Old 02-07-2013, 09:03 AM   #171
spintheground
Member#: 239638
2007 WRX TR UGM
02 MR2 EGM
Sent you an email Chris.
spintheground is offline   Reply With Quote
Old 02-07-2013, 10:43 AM   #172
steverx05
Member#: 128269
'13 VW Golf R
Amazing kit. Glad you went with Garrett for it. Had a GTX3076 on my old s2000 and that thing was a blast.
Have you had any electrical issues (blown fuses) with your kit yet with running the scavenge pump and aftermarket radiator fan? Will you offer any wiring relay kits with your setup if they are required?
steverx05 is offline   Reply With Quote
Old 02-07-2013, 01:42 PM   #173
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Hoping by the end of Feb.
The GTX3071-R pushed over 400whp with the 0.82 housing so the GTX3576-R should be pretty good step in power.
Thank you
I will get a reply headed your way once I get a decent chunk of time to put some thought into.
I really like the Garrett turbochargers too. They have also been extremely usefull with providing engineering support as well.
On the electrical side, the only issue I've come across was due to my own stupidity (firing it up without the scavenge pump fuse in once). Besides that, it's been rock solid reliable. Wiring is pretty simple, and this says a lot as my skills are weak electrically. I plan to provide a BOM to exactly what we have into the kit, but electrically, there's nothing that can't be had at your local AutoZone.
The radiator fan we're using is still under the current draw rating for the OEM circuit that it's tied to. So far so good.
Old 02-07-2013, 07:11 PM   #174
kpadill2
Member#: 266208
Any room at all for a turbo larger than a GTX3582R?
kpadill2 is offline   Reply With Quote
Old 02-07-2013, 07:54 PM   #175
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Not with the GC/GD, unless you're not afraid to modify the chassis some.
