Old 12-23-2012, 08:54 PM   #1401
byun
Member#: 258046
2011 Impreza WRX
Originally Posted by leopard print View Post
Nice! What camber settings are you running? I have the same suspension setup and I have rpf1s on order in the same size as your wheels. I was wondering if I needed anything else to make the wheels work on my car other than a roll in the rear.
Running -1.6 in the front and I think the rears were around -0.6 after installing the suspension with the rear one notch up from the middle setting. Nothing else needed just the rear roll.
byun is offline   Reply With Quote
Old 12-23-2012, 09:47 PM   #1402
leopard print
Member#: 313228
Awesome. Thanks for the reply.
leopard print is offline   Reply With Quote
Old 12-28-2012, 05:05 PM   #1403
d3rock
Member#: 313194
2011 WRX GV
[quote=Subie_Noob_Brian;36584432]2011 WRX
18x9.5 +38 Rpf1's 5x100
265/35-18 General Gmax AS-03 tires
Lowered on BC BR coils
Rear fenders rolled due to rubbing
McGard Spline lugs with matching locking lugs
Maxed front camber
Looks great! I just picked up a set of 18x9.5 RPFS too! Thanks for the photos!
d3rock is offline   Reply With Quote
Old 12-31-2012, 11:43 PM   #1404
DAPekboosted
Member#: 342189
98 240sx
black
my buddy just picked up a 2011 impreza what rim/tire size would look the best with stock ride hight?
DAPekboosted is offline   Reply With Quote
Old 01-03-2013, 08:24 AM   #1405
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
If it's not a WRX, you're in the wrong thread. And stock rim/tires will look the best.
dcorn is offline   Reply With Quote
Old 01-04-2013, 01:58 AM   #1406
iSpool
Member#: 328001
2014 STI
Need some help and advice here, I have a 2012 wrx and am looking for new summer tires and wheels, I want 18 inch and am at stock suspension but may get springs in the summer time... I don't want to roll my fenders but obviously don't want to rub either...what are my best options for a set up (tire size and make and wheels sizes)? What color wheels do you guys think goes well with SWP? Which wheel models?
iSpool is offline   Reply With Quote
Old 01-04-2013, 02:09 AM   #1407
sc00by4life
Member#: 97135
18x8-8.5 +42-48, 245/35/18.
Old 01-04-2013, 09:04 AM   #1408
badams118
Member#: 187209
2011 WRX Sedan
Gunmetal or flat black.
badams118 is offline   Reply With Quote
Old 01-07-2013, 12:58 PM   #1409
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Dude, go look around the site for more than a day before you ask questions. This thread is for fitment of wheels and I bet your question was answered in the first or second page. Go look at pictures in the pics section to see what you think looks good on your car. I guarantee there are people with white WRX's and aftermarket 18s.
Old 01-07-2013, 01:45 PM   #1410
paterick
Member#: 305207
2012 WRX Sedan
what he said.
paterick is offline   Reply With Quote
Old 01-07-2013, 02:17 PM   #1411
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Originally Posted by Subie_Noob_Brian View Post
Maxed front camber
test. just wanted to fix the linkback so i could see the pics
Old 01-11-2013, 11:30 AM   #1412
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
Alright gentlemen. I'm looking at getting:
18x9.5 Rota T2R - Flat Black (5x100/e38/56.1)
With a set of 245/35/18
I have a 2012 WRX 5-Door w/ stock suspension
Some questions
Will i need to roll my rear fenders on stock suspension?
How off will my spedo be?
Is there a better size option? If so what is it and why
Thanks for all the help
UndertoW101 is offline   Reply With Quote
Old 01-11-2013, 11:45 AM   #1413
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
^^^ no roll required at all.... Not until you get coils and lower it alot , and even then it will only be the rear ....
Speedo won't be off at all
ANR62NV is offline   Reply With Quote
Old 01-11-2013, 12:11 PM   #1414
J_Maher_WRX
Member#: 290307
Speedo will be off.... Tire/wheel diameter will be 24.7".. Stock is 25.3"... Therefore the gearing is made shorter.
J_Maher_WRX is offline   Reply With Quote
Old 01-11-2013, 12:30 PM   #1415
sc00by4life
Member#: 97135
which is a good thing for the wrx....since the new wrx's come with tires that are too tall from the factory in the first place....
Old 01-11-2013, 12:44 PM   #1416
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
Specification Sidewall Radius Diameter
245/40-17 3.9in 12.4in 24.7in
245/35-18 3.4in 12.4in 24.8in
Circumference Revs/Mile Difference
77.6in 816 0.0%
77.8in 815 0.1%
It's not significant .....
Gearing doesn't change either
Old 01-11-2013, 01:01 PM   #1417
sc00by4life
Member#: 97135
77.6in 816 0.0%
77.8in 815 0.1%
your post is not relevant to anything.
I understand what you're trying to do, but you need to compare the sizes that are being discussed....
235/45/17 vs 245/35/18.....
Old 01-11-2013, 01:18 PM   #1418
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
With these two tires sizes ^^ the difference on his speedo would be -2.3% ..... Or "slower" than actual speed of vehicle .... Or 1.38 mph @60mph
If the OP doesn't want much change he'd have to go with a 265-35-18 which would give a difference of -0.1%
Not significant .....
Old 01-11-2013, 03:40 PM   #1419
sc00by4life
Member#: 97135
Actually a smaller diameter reads faster, not slower.
There is also a pretty distinct gearing advantage with a <25" diameter on the 5spd.
Old 01-11-2013, 04:32 PM   #1420
badams118
Member#: 187209
2011 WRX Sedan
Smaller diameter means your spedometer will read too fast. Google miata tire size for a good tool to calculate this.
Old 01-13-2013, 10:31 AM   #1421
Boogaloo Shrimp
Member#: 315215
Rota grids
18x9.5 +38
265/35-18
Stock camber. Rolled and slightly pulled fenders
The rears need to be rolled even on stock height. I drove about 15 miles and the rears scraped at least 3 times during that drive down the freeway. From my experience I think it still wouldve scraped some even with 255s
Boogaloo Shrimp is online now   Reply With Quote
Old 01-16-2013, 08:17 PM   #1422
zolaman
Member#: 299059
12 WRX hatchback
2012 subaru wrx hatch.
rays gramlights 18.9.5 +38 Gunblue /w nexen n3000 255/35/18.
Stock suspension and no fenders rolled.
I think this is a good setup for those not wanting their fenders rolled.
I was clueless on wheel/tire until I read this thread.
Thanks Dan, I took your advice on page 34 and went with this setup
rear
zolaman is offline   Reply With Quote
Old 01-17-2013, 11:05 AM   #1423
texascanuck
Member#: 317045
2012 WRX Hatchback
Default red lug nuts
I like the red lug nuts ... thinking of doing the same.
Which ones are they?
texascanuck is offline   Reply With Quote
Old 01-17-2013, 03:09 PM   #1424
sc00by4life
Member#: 97135
Nexen's on rays?
Old 01-17-2013, 03:12 PM   #1425
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
Nexen's on rays?
Oh lord ^^^^ your one of those ....
