Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 01-03-2013, 03:42 PM   #8376
09subi2.5i
Member#: 331636
09 impreza
paprika
Just got quoted $1185 at dealership for full break servicing(fluids,pads, re-cut rotors). Throttle bottle cleaning. Cabin. Filter new crank belt. Is that sketchy?
09subi2.5i is offline   Reply With Quote
Old 01-03-2013, 03:46 PM   #8377
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Tell them you want a detailed invoice with labor and parts quotes.
Yeah that is ridiculous. Do you need the rotors re-worked? Are they warped? If not, they just need to be lightly scuffed up, or actually just put the pads on the existing rotors with no surfacing. That's what I am going to do when the time comes. My rotors are fine.
BWX is offline   Reply With Quote
Old 01-03-2013, 04:00 PM   #8378
trishHUYNH
Member#: 248840
2011 Impreza
My spoiler is here! I pulled off my panels and figured it would be a direct plug and play and then I get this...
The spoiler
The car
I have never soldered before, but I figured this is a great time to learn. What is the best way I can go at this? I'm stopping by the store later tonight to pick up a soldering iron and solder. Do I need anything else?
And for the life of me, I can't even disconnect the brake light cable. Help?
trishHUYNH is offline   Reply With Quote
Old 01-03-2013, 04:03 PM   #8379
premier00000
Member#: 251060
2008 Impreza Outback
The spoiler
The car
I'd say try to see if the dealer has that plug by it self or if you can find one aftermarket. That should make it much easier.
Old 01-03-2013, 04:15 PM   #8380
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Originally Posted by Sellars21 View Post
I think you need to pay more attention, he doesn't state the name brand or the cost of the struts shown in the picture.
Originally Posted by Fendyman View Post
No, he didn't but the pic says it all... it's yellow & 'Koni' on it.
FYI, there aren't many shock/strut options for 3G Impreza.
Yeah. It is pretty obvious that is says "Koni" in the photo.
Hacking up as in cutting and welding, or just reusing parts from stocks? I swapped out my springs not to long ago, it's not to hard. I did it alone In about 2.5 hours. I'm somewhat familiar with the stock struts.
Cut and drill the front struts.
http://forums.nasioc.com/forums/show....php?t=1219607
Originally Posted by BWX View Post
Warning about crap e-15 gas..
http://video.foxbusiness.com/v/2000862202001/
BTW Ethanol is not Gasoline.
That whole report is retarded. Nothing but the best from Fox.
You shouldn't be putting Ethanol in your car unless it's specifically tuned for it or if it's a Flexfuel vehicle.
Old 01-03-2013, 05:16 PM   #8381
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
The spoiler
The car
Don't solder it just cut the ends and attach quick-connects.
All you need is a wire cutter/stripper, male/female quick-connects.
Edit: and electrical tape!
Old 01-03-2013, 05:29 PM   #8382
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
What Dillon said, otherwise get some Flux.
Old 01-03-2013, 05:51 PM   #8383
trishHUYNH
Member#: 248840
2011 Impreza
Thanks! That sounds even easier. Just a question though, is there something wrong with soldering? I always read that it was the best way to make a connection.
And for the wiper fluid cable, do I just pull it apart?
Old 01-03-2013, 05:57 PM   #8384
woWRX
Member#: 207901
2010 2.5i Prem
NBP
Sorry, I know this is really off topic and probably annoying but I fail at using nabisco's search. Is there a detailed write up floating around somewhere on how to install an aftermarket HU in the 2010 2.5i? I have no experience with wiring or installing. Thanks for the help.
woWRX is offline   Reply With Quote
Old 01-03-2013, 06:04 PM   #8385
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Search for 08 WRX. You're not going to find anything for 2.5i.
http://forums.nasioc.com/forums/show....php?t=1399151
That shows you how to take everything apart. All you need to do is remove the bezel around the stereo. Pick one of the corners and pull.
Old 01-03-2013, 06:43 PM   #8386
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
You will need a wire crimper/cutter (can be had for cheap at a hardware store/home depot/menards/lowes, etc)
Step 1:
-Connect your aftermarket HU harness to your harness adapter
-Do this inside at a table and take your time. You can use heat shrink, solder the wires, or do what I do and use butt connectors (18-22ga works fine) and then wrap all the way around with electrical tape (that way you can make sure everything is working properly. That's the way I do my HU's and have never had a problem.
Step 2:
- Take off the bezel around your HU with a flat head screwdriver. Wrap it with a cloth so you don't scratch the bezel
- If you look closely at the bottom right hand corner of the bezel you will see a small notch in the bezel where a flat head will fit. You can use some force and it will pop off.
- Unscrew the bracket screws holding the HU in place
- Pull out the HU and disconnect the harness (1 big white plug) and small black plug which is the antenna (I think that's our car at least)
- Remove the brackets from stock HU and attach them to the new HU (or use aftermarket brackets if applicable). It's a couple small phillips screws that hold each bracket on. One on the left and one on the right.
- Connect new HU harness to your cars harness and ground the black wire to one of the bolts that is touching metal behind your HU. You can either use a ring terminal or just wrap the wire around the screw and tighten.
- Test your connections! Play around with the fade from left to right and front to back to make sure each speaker is working. Check out if the remote works. Check everything you can on the unit.
- Snap bezel back in place and enjoy.
Old 01-03-2013, 06:45 PM   #8387
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
That's a good thread. But it doesn't explain how to install a new HU. It simply shows how to disassemble the entire dash and what stuff is.
Old 01-03-2013, 06:53 PM   #8388
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Do you know what e-10 is? Without google? Because you don't sound like you know WTF you are talking about. BTW name one thing they said that is retarded (as usual from fox).. Let me guess.. you watch MSNBC for all you're hard news.
They were basically just letting people know about this anyway- http://www.usatoday.com/story/news/n...-cars/1735793/
Old 01-03-2013, 07:10 PM   #8389
Digital Dillon
Member#: 288727
2008 WRX premium
Nothing wrong with soldering! I like quick connects because it's easy and cheap
You cut the clip off and strip 1/2" of insulation. Put the exposed wire into the quick connect and clamp it down on the wire real tight. The male/female ends plug right into each other and then tape it or shrink wrap the connections to protect them.
Old 01-03-2013, 08:12 PM   #8390
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
It's actually blend of 15% Ethanol & 85% gasoline... but we don't have to worry about it because it doesn't exist here in CA.
Fendyman is offline   Reply With Quote
Old 01-03-2013, 09:16 PM   #8391
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Just a question but are any of you running pencil beam style lights? I'm looking to get some because i do allot of back road driving at night and am looking for something that throws light really far. If anyone has any or knows of a good kit besides HELLA let me now thanks.
Slow Scoobie is offline   Reply With Quote
Old 01-03-2013, 09:23 PM   #8392
Digital Dillon
Member#: 288727
2008 WRX premium
I had HELLA 500FF's with 3000k HID's and they worked great for the price.
Old 01-03-2013, 09:45 PM   #8393
DirknJirkn13
Member#: 249696
2010 Outback Sport
Yes. Just lightly pull on the rubber hoses. Be careful some fluid will probably come out.
DirknJirkn13 is offline   Reply With Quote
Old 01-03-2013, 09:54 PM   #8394
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
e-10 is technically standard fuel. Does that make you feel better? However, Standard fuel is not called "e-10" nor is it sold as a "Flexfuel". In the Fox report they show e-15 being sold as a flexfuel. AKA, it's not a real issue. If you're dumb enough to put flexfuel in your standard car you deserve the damage. It's clearly a slow news day if they are regurgitating a AAA bulletin.
For the record, MSNBC is just as bad as Fox. I don't rely on any one single source for my news. No one source always gets it right. But I know that there are sources, like Fox, and are pretty consistent at twisting the truth, generally being misinformed and spreading misinformation.
But I suppose we should thank you for passing this valuable information along. You know, since it applies to so many people when the fuel in question is only being sold in a few states. Or because the information is so current because the bulletin and broadcast are from November.
Old 01-04-2013, 12:22 AM   #8395
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Never herd of the brand before, for someone that doesn't know the brand it's not that obvious considering I didn't know how long the logo is...sorry I'm not omni-knowledgeable
Old 01-04-2013, 01:51 AM   #8396
theoutbackdream
Member#: 301179
2013 WRX Limited
wtf.....
Do the TB cleaning yourself... $4 for a can of TB spray.
Cabin filter, $20 from amazon, do it yourself.
I'd buy new rotors instead of re-cutting them..
Old 01-04-2013, 04:47 AM   #8397
theoutbackdream
Member#: 301179
2013 WRX Limited
As i was cleaning car, I noticed there was water inside the cabin at the footwells on the carpet.. I thought it was nothing, but made sure id check a week later..
well.. the carpet is still watery... Anyone know where/how I can start to examine where this water is coming from?
Old 01-04-2013, 09:11 AM   #8398
premier00000
Member#: 251060
You haven't heard of Koni before?? I kinda find that hard to believe...
Old 01-04-2013, 10:34 AM   #8399
Digital Dillon
Member#: 288727
2008 WRX premium
Pull the carpet up.
Old 01-04-2013, 03:01 PM   #8400
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
So when you said ethanol isn't "gasoline", that had nothing to do with anything. Right. You probably have e-10 in your car right now, and the EPA would love for it to be e-15 with no extra labels or warnings.
I'm not going tp clog up this thread further with a stupid argument, I just thought it was an interesting article. But you being an *** hole about it, great stuff.. well done.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 03:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 12:57 PM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 03:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 03:35 PM
