Old 04-23-2012, 07:44 PM   #51
sk8boylou
Member#: 246669
2002 V8 EJ207 6pd
hey so where did the other end of pin 14 for the AVCS Sensor Shield Ground go? I am stuck on that for my avcs re-wire.
sk8boylou is offline   Reply With Quote
Old 05-27-2012, 03:19 PM   #52
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Any updates on your swap... did u get AVCS sorted out? Looking forward to driving impressions...
Torquey is offline   Reply With Quote
Old 06-05-2012, 11:40 PM   #53
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
How will an 02 wrx ecu know how to control avcs?
BMXspears is offline   Reply With Quote
Old 06-06-2012, 12:57 AM   #54
Gam30vR
Member#: 289486
03 WRX
He got the jdm ecu with the the longblock.
Gam30vR is offline   Reply With Quote
Old 06-06-2012, 02:26 AM   #55
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Originally Posted by efiniluvr View Post
I wanted to share with you some of the differences regarding acessories. Here is the power steering line and reservoir difference.
The reservoir you have in this picture is for use with the spec-c power steering cooler. It angles downward as there is a hose the goes towards the front of the cars:
(The top cooler is for power steering, the bottom is oil)
The normal STI reservoir is exactly like our usdm.
BeBop86 is offline   Reply With Quote
Old 06-06-2012, 07:31 AM   #56
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Did you get that section of radiator, support and accessories with your swap?
Old 10-25-2012, 01:21 PM   #57
tippmannman7
Member#: 282933
2004 WRX
I know it has been a while since you posted but I am debating a swap in the future and wondering how everything turned out and if you ran into any more hiccups.
tippmannman7 is offline   Reply With Quote
Old 10-26-2012, 02:32 PM   #58
efiniluvr
Member#: 107170
2002 ver 7 EJ207 WRX
Default UPDATE: AVCS wired up....poorman's way at least
UPDATE: 10/26/12
Most of you will recall that I had a difficult time repinning the ECU pins, that is, I could not get the tiny pins out no matter what I tried, I even purchased the bmotorsports thin spade tool, and managed to break the tip of it trying to push the pins out. I was about to give up until I stumbled upon the new product introduced by who elso, iaperformance. The shop now offer not only hard to find V7 EJ207 parts, but now offer the Subaru ECU Female Pins, the exact pins that would fit into the ECU. Perhaps, iaperformance saw the market need for those DIY'ers who want to make their own AVCS harness kit and decided to offer this product. Lifesaver!!!! What that, I figured if I can't repin, than I'll simply cut those wires, solder on the ECU Female pins to those wires on the WRX bulkhead harness, and add them to the correct locations on the ECU plug.
To refresh your memory:
Follow the AVCS Install Document
I had the fortune to score a shielded EJ207 AVCS wires from the board, but if you want to make your own, you can purchase the shielded wires off ebay: http://www.ebay.com/itm/Shielded-Cab...item256673dcf7, buy the iaperformance Female ECU pins, and also source the pins for the engine block harness. I'll have to research more to find the engine block pins.
Below are the pics of my wiring job, excuse the poor focus, it's difficult to hold the camera and hold connectors at the same time.
Here is the driver side engine block harness where you need to repin the TGV wires
Pop off the white lock
With the lock popped off
Use a very thin precision flathead to unlock the pins. Viewing from the connector side, you'll see the pins are locked in place by a tiny lock, insert tool in between the lock and the top of pin to unlock, then pull from backside. Sorry no pics of that process
Here is what the harness looks like after repinning, if I remember correctly, all the pins were relocated one row up, from row 2.
Moving to the ECU side of the wiring harness:
Here, you'll want to unlock the ECU pins by propping the lock by inserting a tool to hold the unlock in position (see the red screwdriver in the pic). The ECU connector needs to remain unlocked for you to insert the new pins, so leave it there until you've completed the pin insertion. Be careful as the locking tab is rather fragile. As you can see, I've labeled the four wires that need to be relocated.
Before you proceed to cut the wires, make sure you label the wires with the pin location that you're moving them to. You may wonder what happens to the pins that remain in the ECU connector. Since the JDM ECU is not looking for the TGV's, then leaving them in there doesn't do anything as the ECU is not getting a signal from those pins anyways.
Here is what it looks like after I soldered on the pins
This is the "UP" orientation at which you'll insert the pins.
The above process assumes you already have a AVCS wiring harness (the four shielded wires, with the correct pins for the ECU connector and for the passenger side engine block harness. I took the poor man's route because I was too cheap to buy the iaperformance harness. Although I honestly believe they offer a superior product at a reasonable price that could've saved me alot of time, I decided to try it myself first. I ended up purchasing something from them anyways =)
Big thanks to NASIOC member Chromes for providing the link to the ebay shielded wires link and the bmotorsports tool link.
-Jeff
efiniluvr is offline   Reply With Quote
Old 10-26-2012, 02:45 PM   #59
efiniluvr
Member#: 107170
Default Post AVCS wiring, first driving impression
When people mentioned how smooth the EJ207 is, they're not exaggerating. I've been driving the car with a stock EJ205 downpipe (which contributes to the "roughness") and no AVCS. The car idles smoother than the EJ205, but now that the AVCS is wired up, I have no codes (YAY!!!!), the throttle response off line and the transition from off boost to boost is much much more linear. The car feels like it just wants to take off, a eager beaver if you will. It's actually a bit "touchy" with even the slightest throttle input. I am still adjusting to it, but I would rather have this than the lag-blast off feeling without the AVCS wired up.
I am still using the stock downpipe as the JDM downpipe was too short to mate up too the CBE, but once I bolt on the Invidia downpipe and have the car tuned (shortly), I imagine the car will be even more smooth.
I will let you know what the Dyno numbers after the car is tuned.
-Jeff
Old 10-27-2012, 04:11 PM   #60
ShinjiML
Member#: 257231
2011 STI
If the EJ207 you received has the engine harness intact (like mine), you just need to add a AVCS bulkhead harness, which you can either purchase from iaperformance.com AVCS Bulkhead wiring kit, or have someone on this board make one for you, PM me if you're interested.
I got lucky and bought the wiring from someone in the classified. And here is the DS1 AVCS wiring instruction. I'll take pictures when I wire mine up this weekend.
-Jeff
I'm planning to do a 207 swap as well, but I was under the impression that for the 02-03 years, all you need is the avcs wiring, since the 02-03 have the correct bulkhead harness?
ShinjiML is offline   Reply With Quote
Old 10-27-2012, 04:32 PM   #61
Gam30vR
Member#: 289486
03 WRX
.....That is what he said...
Old 10-27-2012, 04:39 PM   #62
ShinjiML
Member#: 257231
2011 STI
Oops, I misread.
Old 12-08-2012, 03:59 AM   #63
Seattle_WrxWagon
Member#: 334326
Hey man i am sort of in the same boat... i am nearing the end of swapping in a v9 jdm sti motor into my 04 wrx wagon and done with the mechanical side of the swap as well as installed the avcs wiring kit but still not able to get the motor to run smooth as it should... When I fire it up it has a really hard idle and the check engine light continuously flashes off and on...any idea as to what could be causing this?
[email protected]
Seattle_WrxWagon is offline   Reply With Quote
Old 12-08-2012, 04:11 AM   #64
PHruska
Member#: 214589
2002 wrx wagon
[email protected]
Are the green Connectors behind your fuse box connected? They shouldn't be. Checked iacv? Checked avcs is functional?
PHruska is offline   Reply With Quote
Old 01-04-2013, 10:30 AM   #65
tylerbryant
Member#: 292945
Midnight black pearl
i am doing the same swap. am i able to run the jdm motor with the usdm ecu without a tune and just leave the avcs unplugged?
tylerbryant is offline   Reply With Quote
Old 01-04-2013, 12:02 PM   #66
efiniluvr
Member#: 107170
You can do either, but unless you've wired up the AVCS, you'll get a CEL. If you're running both ECU's without a tune, I suggest you take it easy and stay out of boost as much as possible.
-Jeff
Old 01-05-2013, 03:03 AM   #67
tylerbryant
Member#: 292945
ill get a CEL on a usdm ecu? i think im just gonna run the usdm ecu for a while as i have to pass obdII emissions in my area and dont wanna fuss with it. where did you have your car tuned? what should i have done by the tuner exactly?
Old 01-05-2013, 10:46 AM   #68
efiniluvr
Member#: 107170
You'll get a CEL running the USDM ECU because it is looking for the TGV's, which the JDM engines do not have, that's why you need to repin the TGV wires at the ECU and convert those wires to AVCS wires. Without repinning, the ECU will not "find" the TGV's and throw the CEL. I doubt you'll be able to pass the OBDII emission if the CEL is there.
Old 01-05-2013, 01:08 PM   #69
tylerbryant
Member#: 292945
yea i knew that is there a way to have the ecu tuned so that it doesnt look for tvg?
Old 01-05-2013, 02:10 PM   #70
efiniluvr
Member#: 107170
If you use open source on the ECU, with a tactrix cable, then yes, you can clear the TGV CELs to readiness.
Old 01-10-2013, 02:00 AM   #71
tylerbryant
Member#: 292945
what did you end up doing with the plug on the jdm manifold?
Old 01-10-2013, 07:48 PM   #72
efiniluvr
Member#: 107170
I didn't have do anything, it was already capped
Old 01-13-2013, 08:39 PM   #73
chrisagu28
Member#: 263220
2005 Wrx / Sti conv.
2014 XV Crosstrek
I am really liking this thread. I am planning on doing a EJ207 swap when i get home from deployment and this the perfect guide and motivation i need. I subscribed
chrisagu28 is offline   Reply With Quote
Old 01-13-2013, 10:36 PM   #74
tylerbryant
Member#: 292945
did you have any issues with having to pass emissions? if so how did you get around them.
Old 01-18-2013, 12:27 AM   #75
tylerbryant
Member#: 292945
what oil do you run?
2005 STI into 2002 Bugeye Swap psychorunner Subaru Conversions 20 03-08-2012 08:28 PM
My STI swap into 02 Bugeye Tweeder Member's Car Gallery 19 06-04-2011 03:13 AM
JDM V7 ej207 into my 05 WRX CamTunedSti Built Motor Discussion 6 11-10-2010 04:40 PM
I have some questions regarding - Version 7 v7 EJ207 into USDM 2004 STi STepeci Subaru Conversions 8 09-18-2009 07:26 PM
dash/interior swaps into 02 bugeye? ricky05 Interior & Exterior Modification 4 01-25-2007 04:03 AM
