Old 10-23-2012, 07:22 PM   #426
Jdub.csu
Member#: 283784
2013 EVO X GSR
Originally Posted by RallySport Direct
Hahahaha, sure
Next time you place a order, call in and ask for me. ill throw in a free hat for you
Kirill
RallySportDirect.com
Woot to bad I just did my huge order not that long ago. But...
There is always room for another part haha
Jdub.csu is offline   Reply With Quote
Old 10-23-2012, 07:25 PM   #427
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Actually lets just make life easy
Im shooting you a PM , ill just send one out to you hahaha.
Kirill
RallySport Direct is offline   Reply With Quote
Old 10-23-2012, 07:33 PM   #428
Jdub.csu
Member#: 283784
2013 EVO X GSR
I like easy =)
Got the hat! Fits great
Old 12-13-2012, 08:40 PM   #429
RallySport Direct
Member#: 33174
We are Open Late!
Loooky look what we got today from Cusco for our 2011 STi!
Should be a good way to get some more rigidity out of the chassis and match the other Cusco bracing, control arms, lateral links and sway bars that are already on the car. Hoping if time allows that I will be able to drive the car for a few min after each part gets installed for some good feedback.
Putting this stuff on tomorrow first thing in the AM
Can anyone guess the items?
Here is a hint
http://www.rallysportdirect.com/cata...2&src=p7gy3cop
Kirill
Old 12-13-2012, 09:31 PM   #430
Jdub.csu
Member#: 283784
2013 EVO X GSR
That's easy without the link lots of cusco chassis bracing parts
Old 12-17-2012, 06:35 PM   #431
RallySport Direct
Member#: 33174
We are Open Late!
Got a chance to take the car for a spin, and what a difference!
Turn in is crazy sharp, and the front end is now very stable. Turn the wheel and the car just goes. The back is very eager to follow and the car seems to be more planted and much more predictable. Its a bit cold out today (low 40's at best), so the tires did not offer much grip to say the least. Around one of the corners the back end stepped out, so I shut it down of any farther testing until the weather warms up. Should have pictures posted up shortly of a couple of the braces.
Kirill
__________________
Old 12-18-2012, 05:06 PM   #432
RallySport Direct
Member#: 33174
We are Open Late!
First of, I would like to apologize as for the time being for the lack of images of some of the items. We are in the process of getting the lift put up and it did not get here in time for when these items got installed. So some of the under car bracing images will be posted as soon as the lift goes up.
First off we have the Cusco Front Cross Member Power Brace 692 492 M. We installed this in conjunction with Cusco Front Lower Arm Bar Type II 692 477 A. Install was straight forward and didnt require any specialty tools. One thing I noticed was that this brace is BEEEEEFY! About 2 times heavier then the dinky stock unit. Overall driving impression was that the front end of the car was way more stable. Turn in was smoother and more planted, and the car did seem to give a little more feedback through the front end as well. Which is always nice to know what the car is doing.
Next we added the Cusco Rear Strut bar 692 541 A with the brand new Cusco Quick release latches 00B 540 C. I must say that the latches are freaking slick! No more having to worry about messing up the bars finish if you have to throw stuff in the trunk, and the anodized aluminum caps look amazing!
Next is Cusco Front Member Brace 692 492 FM. This ties into the upper and lower radiator support, and sits right behind the OEM crash beam. The brace has even a little bracket to re-locate the temp sensor!
We also installed the Cusco Rear Member Power Brace 692 492 RM, Cusco Power Center Floor Brace 692 492 C, Cusco Rear Member Side Brace 687 492 RS. Promise as soon as our lift is up we will get more images of these individual braces
Very glad to have a chance to work with Cusco on this project and try out many of the braces to get some real life feedback. Now only if the weather will warm up!
Kirill
Old 12-19-2012, 12:32 PM   #433
RallySport Direct
Member#: 33174
We are Open Late!
People had some more questions about this brace.
So here are some "better" pictures to show the fitment of the front member brace
This is the mount before I put on the crash beam. (The hardware was not tight, so dont pay attention to the holes not being 100% straight for the bolts behind the crash beam)
And as you can see this thing sits quite flush
Kirill
Old 12-19-2012, 12:34 PM   #434
Jdub.csu
Member#: 283784
2013 EVO X GSR
Same location as most FMIC use
Old 12-19-2012, 12:55 PM   #435
RallySport Direct
Member#: 33174
We are Open Late!
That is what the reason for the images.
Thing that is a bit of a issue with FMIC's is they replace crash beams, which 1) reduces chassis stiffness 2) Gets rid of a crash beam, and makes it so the car is more likely to sustain frame damage in a low speed accident.
Kirill
Old 12-23-2012, 06:18 PM   #436
Matt5462
Member#: 340134
looks great
Matt5462 is offline   Reply With Quote
Old 12-24-2012, 01:26 AM   #437
Pearly_Whites
Member#: 164714
2007 WRX TR
Kirill
You would be suprised at what causes frame damage; even under 10mph. Getting rid of the 'crash beam' isnt a good idea.
Pearly_Whites is offline   Reply With Quote
Old 01-05-2013, 07:05 PM   #438
JLD13
Member#: 330696
05 Saabaru V7ej207
Awesome build. I've bought a quite a few things from you guys, great service and support (the online chat is awesome).
When is the Cusco quick release latches 00B 540 C going to be available for purchase?
JLD13 is offline   Reply With Quote
Old 01-05-2013, 07:10 PM   #439
RallySport Direct
Member#: 33174
We are Open Late!
Thank you for the kind words
We have them in stock, just waiting to get them shot and posted up on the site. Give us a call and we can get a set going for you
Kirill
Old 01-05-2013, 07:11 PM   #440
RallySport Direct
Member#: 33174
We are Open Late!
The STI is away for winter in our new showroom!
Its about 15 degrees outside, so we keep her nice and warm.
Kirill
Old 01-09-2013, 12:25 PM   #441
Extreme Dimensions
Member#: 264277
Kirill
now this is beautiful! Congrads guys on the build.
Extreme Dimensions is offline   Reply With Quote
Old 01-21-2013, 04:25 PM   #442
RallySport Direct
Member#: 33174
We are Open Late!
http://www.rallysportdirect.com/Suba...r&src=0h6j9hqg
So what does everyone think?
Keep it off?
Put it on un-painted?
Put it on and get it painted?
We cant agree at the shop and need your input!
Kirill
Old 01-21-2013, 04:37 PM   #443
easterbran
Member#: 307359
'05 STi Stage II
http://www.rallysportdirect.com/Subaru-OEM-E751SFG300-Vortex-Generator&src=0h6j9hqg
Keep it off?
Kirill
Put it on unpainted! It looks great with the spoiler.
Old 01-21-2013, 04:44 PM   #444
Sti_Kent
Member#: 290645
2011 Sti Hatch
I'd suggest matching to the roof spoiler and other parts (like mirrors and whatnot), then keeping them all carbon.
Good luck with the choice.
Sti_Kent is offline   Reply With Quote
Old 01-21-2013, 09:17 PM   #445
DiOdE_EE
Member#: 263726
2011 STI Limited
PBP
Is it functional or just bling? If the later, leave it off: if the former, leave it as is. :-)
DiOdE_EE is offline   Reply With Quote
Old 01-22-2013, 11:06 AM   #446
RallySport Direct
Member#: 33174
We are Open Late!
Its 100% function. Looks wise I am not in love with it, but the increase in rear wing downforce generation is substantial enough that I am wanting to do this for 100% functional aspect.
Kirill
Old 01-22-2013, 11:16 AM   #447
jburton2
Member#: 312078
02 STi swap
Sedona Red Pearl
Keep it un-painted. Looks good with the spoiler.
jburton2 is offline   Reply With Quote
Old 01-22-2013, 01:52 PM   #448
joshuaj
Member#: 216249
2011 STI Sedan
Kirill
How much did it increase the downforce?
joshuaj is offline   Reply With Quote
Old 01-22-2013, 01:59 PM   #449
RallySport Direct
Member#: 33174
We are Open Late!
We do not have any exact numbers for this as it requires a full scale wind tunnel which simply is not an option for us to have access to for testing something like this.
The theory behind this product has been proven by large automakers along with many universities and government programs. The vortex generator induces the air flow to turn from laminar to turbulent as soon as the flow contacts it. This turbulent flow sucks the air flow to the rear window, and reduces the separation wake which allows the flow to follow the contour of the rear window and the trunk. This flow is now attached to the window and trunk, which proceed to flow under the airfoil. The higher the mass flow of air on the underside of the airfoil the more downforce it generates as a result from the pressure gradiant difference from the top and bottom air flow difference.
You do have a slight increase in drag which is generated from the air flow being turbulent vs laminar, however by inducing additional flow under the wing you are increasing the efficiency of the wing with very minimal increase in drag.
Kirill
Old 01-22-2013, 02:40 PM   #450
joshuaj
Member#: 216249
2011 STI Sedan
Fair enough. It just sounded as though you had some measurable change.
AVO's 2011 STI Sedan is here! AVOturboworld Member's Car Gallery 192 01-29-2011 04:55 PM
2011 STI sedan on the 'Ring BlueLGT General Community 5 06-09-2010 10:57 AM
2011 STi Sedan at NY Auto Show Interior Flair Texas Impreza Club Forum -- TXIC 54 04-05-2010 07:31 PM
2011 STi sedan remotehuman New England Impreza Club Forum -- NESIC 55 04-04-2010 10:48 PM
