Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Mid Atlantic Impreza Club
Closed Thread
Old 01-05-2013, 09:54 AM   #4301
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Originally Posted by end_of_silence View Post
Installed FEAL rebuilt (gravel) 04 STI struts/ OEM springs, Whiteline end links front/ rear, eBay rear strut bar and a Primitive skid plate with stinger option. Can't wait for rallycross season!
Pics or gtfo. You prob haven't driven on them much but how do the "New" struts feel?
ImNOrobo is offline
Old 01-05-2013, 10:22 AM   #4302
I WANT AN STI
Member#: 79983
2005 STI
Finished up the cleaning process and put the seats back in. Ahhh finally a super clean interior. Now to tackle the exterior.
I WANT AN STI is offline
Old 01-05-2013, 03:45 PM   #4303
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Tightened down my lateral link bolt, yea the 10 inch long one. That damn bolt is so hard to move, but it was loose for whatever reason.
This is how I did it lol. Floor jack holding the wrench on the 'nut side' so it doesn't move, and a steel pipe on the ratchet for the bolt side.
I also got my estimate for the deer damages. $2800 to repair the front fender, drivers side door, and rear quarter panel. My car's value isn't much over $4000, if that, so it COULD get totaled out!
75% of the value right? Gonna be close!
ManualOverAuto is offline
Old 01-05-2013, 05:25 PM   #4304
end_of_silence
Member#: 85565
2005 Saab 92x Aero
DSM
Can't comment on how they feel quite yet. Gonna wait to get the alignment done before I go for a good drive. But anything is going to be an improvement over the original 146K struts! Here is a crappy pic of one corner that I took on my phone. They must be real because they have the sticker on them, right?
end_of_silence is offline
Old 01-05-2013, 06:34 PM   #4305
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
Had the first break in oil change done in the WRX. Gotta go put some more miles on it for the next one and the retune for next week!
Did a brake job on the black Camaro. Discovered that the inner pads on the front were separating from the backing plate. On the passenger side, it was bent and completed separated on one side. I guess that explains the weird vibration under braking. The new Hawks (HP+ up front, HPS in the rear -- keeps the axle hop that a Z28 is prone to doing minimal) are great so far.
CamaroFS34 is offline
Old 01-05-2013, 06:41 PM   #4306
infinite012
Member#: 74392
2015 Forester
Installed the whiteline steering rack bushings. My arms are dead.
infinite012 is online now
Old 01-05-2013, 07:00 PM   #4307
Lurch33
Member#: 261832
06 WRX TR
Put new speakers in the Forester.
Lurch33 is offline
Old 01-05-2013, 07:09 PM   #4308
Matt_H
Member#: 107000
2015 BMW X1
Tore down my heads to send off. My house smells of oil. : /
Matt_H is offline
Old 01-05-2013, 07:10 PM   #4309
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Why wait so long to replace them?
96accord is online now
Old 01-05-2013, 07:51 PM   #4310
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
They actually have plenty of backing material, it's just not all firmly attached to the backing plate.
The vibration started recently, and with the suspension work I'd been doing piece meal (the control arm bushings, then the shocks/springs), I wasn't sure what the cause was initially.
Old 01-05-2013, 08:54 PM   #4311
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
I took some detailed pictures of emergency brake before I took them apart this time.
I really hate drum brakes
ThatGy is offline
Old 01-05-2013, 09:00 PM   #4312
chrispsti
Member#: 342676
11' lexus isf
sti sold 2011 Lexus isf
Fixed a small gas leak from my perrin fuel rail. crimp ring must have loosened up a bit combined with really cold weather equals leak. couldnt fit anything other than needlenose pliers in their to crimp it but it worked (for now)
chrispsti is offline
Old 01-05-2013, 09:08 PM   #4313
chrispsti
Member#: 342676
11' lexus isf
Sweet! I have feal struts(tarmac) with zerk fittings paired with rce blacks and they are awesome! Sounds like a sweet setup
Old 01-05-2013, 11:01 PM   #4314
spintheground
Member#: 239638
2007 WRX TR UGM
Put on the HKS flat flange downpipe. Going from a 5 inch divorced wastegate to this makes a world of difference. Getting the old one off was a pita because the bottom nuts are obstructed by the EWG. Install was a snap.. but I should have put an extra gasket on the DP-> Catback flange. Will have to fix that in the AM. Definitely heard an exhaust leak coming from there.
Also have an AOS to install tomorrow.
spintheground is offline
Old 01-06-2013, 09:22 AM   #4315
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
washed outside and cleaned inside windows of our 2 subarus. 03 hatch and wife's '13 outback.
mhoerath is offline
Old 01-06-2013, 01:34 PM   #4316
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
Found out from a fellow F-body owner last night that the bending of the inner front pad is evidently a "common" occurrence. He told me that he's never had one not bend until he upgrading to a BBK. Weird, since I've never had it happen until now. I wonder how much of the damage was done when I had the car out on the Shenandoah Circuit?
Old 01-06-2013, 03:01 PM   #4317
spintheground
Member#: 239638
2007 WRX TR UGM
Holding off on the AOS. Might as well wait since the motor comes out soon.
Fixed the exhaust leak best I could considering I didn't have a new gasket.
Old 01-06-2013, 07:49 PM   #4318
infinite012
Member#: 74392
2015 Forester
Washed it. Jeeeeeeeeesus it's cold outside.
Old 01-06-2013, 09:42 PM   #4319
gaedikus
Member#: 310254
04 Forester XT
Jim (the undisputed subaru whisperer) helped me install my new grimmspeed thermostat, drilled and slotted rotors, and cabin filter. i am eternally grateful for your expertise in subarus.
one of the bolts in the rear caliper seized and broke, so jim and i got to experience the least entertaining task of drilling, torching, threading, etc...
also this weird phenomenon:
gaedikus is offline
Old 01-06-2013, 09:43 PM   #4320
mdot1203
Member#: 310527
2012 WRX Hatchback
DGM, 281hp/316tq
Washed her and put on the winter setup. All i need now is the snow
Wintermode by itcouldonlybeme, on Flickr
Winter wheels mounted! #wintermode #wrx #subaru #awd #turbo #snow #tires by itcouldonlybeme, on Flickr
mdot1203 is offline
Old 01-06-2013, 09:50 PM   #4321
96accord
Member#: 145105
Thanks! Since you put the winter setup we won't get snow!
It's suppose to be in the low-mid 50's by the end of the week
Old 01-06-2013, 09:58 PM   #4322
STiWanabe
Member#: 41447
---- _________
U can thank me as well. I sold him the wheels and mounted/balanced the tires. Doing what I can to keep the snow away
STiWanabe is offline
Old 01-07-2013, 09:23 AM   #4323
96accord
Member#: 145105
THANK YOU!
Mid 50's all week and low 60's by the weekend
Old 01-07-2013, 09:29 AM   #4324
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
THANK YOU!
No I want SNOW!!!!!
lilblue619 is offline
Old 01-07-2013, 10:20 AM   #4325
96accord
Member#: 145105
Originally Posted by lilblue619 View Post
No I want SNOW!!!!!
Yuck. Cold/Wind/Snow meh :-/
I will take 50's/60's this week awesome January weather ^_^
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 01:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 04:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 01:02 PM
