Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 12-17-2012, 07:43 PM   #1
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Default 04 WRX 16g tune
Catted dp, 255 pump, sti tmic and jdm pinks. How does it look?
nightcrawler60 is offline   Reply With Quote
Old 12-17-2012, 08:08 PM   #2
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
looks hella weak sauce, you should slam it on airbags with +15 offset 19" Giovanni's
murrdogg24 is offline   Reply With Quote
Old 12-17-2012, 10:40 PM   #3
2gnt2wrx
Member#: 123625
2002 wrx
2015 wrx gbp
It looks good, but you are being held back by those injectors.
2gnt2wrx is offline   Reply With Quote
Old 12-17-2012, 10:56 PM   #4
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
ja ja. Nope Im saving for da +2 Rota Gridz and ISC Race Coiloverz.
Yeah, I figured (thought) they would of been enough considering I have the small 16g. Oh wells.
Old 12-19-2012, 09:23 PM   #5
shano
Member#: 223839
2004 WRX
Java black
Do you have a catless up?
Seem's a little on the late side (full boost at 3750?) small 16g?
Seem's more like 18g territory as far as lag goes, but power seem's about right and curve is nice.
shano is offline   Reply With Quote
Old 12-20-2012, 04:34 PM   #6
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Yeah, around 3750ish. I have a catted Helix dp and the turbo is a smal Blouch 16g. Tuner said the dp put me back a little, guess I'll deal with it cause I'm not a fan of catless dp's. I was hoping for a little faster spool though.
edit: I must say though...a millions times more fun than the 215/230 stage 2 I was running before
Old 12-22-2012, 03:21 PM   #7
Kastley85891
Member#: 127704
2015 Focus ST
PB on E30
Spool is for sure slow, catted DP has nothing to do with it on a 16G
Old 12-22-2012, 08:32 PM   #8
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
+1 to that!
02rex62 is offline   Reply With Quote
Old 12-23-2012, 08:47 AM   #9
yerrow
Member#: 59094
04/7 wagon & fozzie
wrb/blk
don't forget that he's of 91 octane peepee water
yerrow is offline   Reply With Quote
Old 12-23-2012, 08:17 PM   #10
dux10
Member#: 235338
2002 Faggin Wagon
srp
and a dyno pak meaning the numbers should be higher...
numbers look low as does spool....
probably feels solid tho compared to the stg 2 setup. There's alot to be had tho...
EDIT:
for reference, I just tuned a customer's small 16g with FMIC and hit full spool right around 34-3500. Oh yeah- full spool was 21/22psi not 18... My personal car (20g on a two liter) hits 18psi at the same RPM as the OP's...
Last edited by dux10; 12-24-2012 at 02:02 AM. Reason: was too busy talking on the fone to post more info
dux10 is offline   Reply With Quote
Old 12-24-2012, 04:56 PM   #11
vteclol
Member#: 280855
I had a EvoIII 16g on my 05 wrx, my full boost was around 3350, my numbers were 285/258. I had 650 injectors, I think you need the same or bigger. And I do agree, it is more fun than stage 2 haha. Stupid 91 octane too, I was on 93.
vteclol is offline   Reply With Quote
Old 12-27-2012, 09:30 AM   #12
dux10
Member#: 235338
2002 Faggin Wagon
srp
What kind of dyno and what was "full boost"?
Old 12-27-2012, 10:09 AM   #13
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Haha very true Steve Gotta love 'full boost' of like 16psi
For reference, my vf34 2 liter car hits 21psi by about 4000 in 2nd... 4EAT 2nd that is
Old 12-28-2012, 07:54 PM   #14
shano
Member#: 223839
2004 WRX
Java black
I'm wondering if it's just the tuner being shy with the timing or possibly OP has not changed out his stock catted uppipe...?
Silicone y-pipe and a STi topmount may help with lag also.
Old 12-29-2012, 06:44 PM   #15
05Subie
Member#: 123862
00 2.5RS-X
BRP
OP needs a better steering wheel. That will help with the low end.
05Subie is offline   Reply With Quote
Old 12-29-2012, 07:12 PM   #16
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
PWN3D
I heard the Nardi steering wheels spool 500rpms fastar jaja
Old 12-29-2012, 07:53 PM   #17
dux10
Member#: 235338
2002 Faggin Wagon
srp
Ya know.... This isn't exactly the most load inducing dyno... I bet it spools about average on the street with a REAL load on it. Just a thought.
Old 12-29-2012, 08:03 PM   #18
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Most likely. Dynapacks don't really load the most realistic.
Old 12-31-2012, 09:04 PM   #19
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Im running a oem gutted uppipe, but I think I may have a small leak also, so Im about to swap it out for an Indvidia uppipe.
edit: Im currently running a STi TMIC and y-pipe also.
Heres my current data log I took today.
https://docs.google.com/spreadsheet/...hWi1kTnc#gid=0
Ja Ja,
No Poop Nardi
Old 01-04-2013, 03:43 PM   #20
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Dynapacks usually spool late. I'll bet money that on the street it spools faster.
Old 01-04-2013, 11:09 PM   #21
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Eh, it spools kinda late on the street also.
Old 01-06-2013, 04:22 PM   #22
shano
Member#: 223839
2004 WRX
Java black
Wait a minute... is this an ebay 16g? Cause that may explain everything.
Old 01-07-2013, 02:00 AM   #23
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
blouch turbo, you can't afford one pal
Old 01-07-2013, 02:04 AM   #24
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Blouch....brand spankin "NEW".
But anyway....I picked up an Invidia up-pipe this weekend to replace the gutted stocker I have. Probably be installed and retuned sometime next month, so I
l'll post up how that goes.
Old 01-12-2013, 10:09 PM   #25
2fst4you
Member#: 315052
2006 Impreza Wrx
What trans are you running?
2fst4you is offline   Reply With Quote
