Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 11-10-2012, 04:52 PM   #26
STi MAN86
Member#: 287906
2006 STi
I wonder what this would be like on pump 93 for spool up?
STi MAN86 is offline   Reply With Quote
Old 11-11-2012, 10:47 AM   #27
Kastley85891
Member#: 127704
2013 Hybrid
Needs an 05STI
Awesome work - TMIC lover here......
Can you get a pull in third for comparo ?
Old 11-13-2012, 08:25 PM   #28
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I got two 3rd gear pull from my old 5-sp and my 2011 STi tranny
5-sp.....4000rpm 18psi, 4100rpm 21psi 4300rpm 27psi
6-sp.....4000rpm 16psi, 4200rpm 22psi, 4600rpm 27psi
Old 11-13-2012, 08:36 PM   #29
Kastley85891
Member#: 127704
2013 Hybrid
Needs an 05STI
Thats great dude, must be a blast ;-)
Old 11-14-2012, 10:11 AM   #30
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
Sweetness Juan! Good work
Old 11-14-2012, 08:21 PM   #31
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
whats injectors are you running?
What are the IDCs?
Old 11-14-2012, 08:41 PM   #32
Equilibrium Tuning
Member#: 26933
2006 STI
That looks pretty good Juan, but honestly I'm not super impressed with the spool of this turbo. We just did a street pull in the car you were comparing this to and here is the boost plot:
That's 20psi by 4000RPM and 25psi before 4300RPM and this is a GT35R with .82 housing with a FMIC. Of course this is a rotated setup, so its not a direct comparison. Oh and this is 4th gear in an 05 STI. The car did 475whp on our dyno (558whp Dynojet).
-- Ed
Old 11-14-2012, 08:53 PM   #33
juanmedina
Member#: 133146
07 FPgreen 7.37@95
What are the IDCs?
I have to look at my logs
-- Ed
I am confused in fourth gear STi I hit 27psi by 3960rpm... third gear 5 sp WRX it spools just like that STi. I think if I decide to lean it out and turn up the timing it should made about the same power as that car.
I am very happy with this stock location 68lb/min turbo... Do you have any FP reds that can compare?
Thanks Ed
Old 11-14-2012, 09:14 PM   #34
Equilibrium Tuning
Member#: 26933
2006 STI
Thanks Ed
Juan,
You hit that in 4th gear with the 07+ STI gearing. This is an 05 STI 4th which is similar to the 5MT 3rd where you're hitting full boost around 4500RPM.
Not trying to rain on your parade or anything here. You were just boasting about your spool and I noted that it was misleading because of the 07+ STI gearing.
I did an FP Red recently and was not impressed with the spool either.
-- Ed
Old 11-14-2012, 11:55 PM   #35
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
My HTA86 hits 27psi by 4400 rpms
Crystal_Imprezav is offline   Reply With Quote
Old 11-15-2012, 07:24 AM   #36
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Juan,
-- Ed
I think we should look at torque at 4000rpm for comparison. Torque is what makes a car feel good and fun.
This is my car on your road dyno, 5sp 3rd gear, FP black 68lb/min stock location.
EQ - 05 STI, EQ Built Block, GT35 Rotated, E85 - 473whp ...65lb/min rotated
EQ - FP Red on E85 - 456whp! 65lb/min stock location
As far as power goes I have no doubt that I will make around the same power if I raise the timing to 26*
you probably hit 300wtq by 5000rpm
Old 11-15-2012, 10:02 AM   #37
Equilibrium Tuning
Member#: 26933
2006 STI
Ok. Lets look at torque. The rotated 35r car hits 400ft-lbs by about 4700RPM and keeps going to 460ft-lbs while your car doesn't even hit 400ft-lbs. Also remember that you're comparing your road pull to my dyno pulls. On the road these cars spool a good 300-400RPM sooner than on the dyno in the same gear. I also highly doubt that you would hit the same power with more timing. Your system has significantly more back pressure which means you will hit MBT at a lower ignition advance. I could be wrong of course, but you can't just assume that you're going to pick up 50whp+ without trying it.
Again, I'm not knocking you or your tuning, just saying I'm not a big fan of the current FP turbos. Including the laggy FP red you posted that I tuned.
-- Ed
Old 11-15-2012, 10:27 AM   #38
juanmedina
Member#: 133146
07 FPgreen 7.37@95
-- Ed
Even if you shift the graphs to the left by 500rpm my car will still make more torque than those cars at 4000rpm. I have stock rods so I am keeping my torque down intentionally. If I wanted I could make this thing make tons of torque. You don't think I can make 30whp (compare to red) or 50whp (compared to the 35r) with a EWG and 5* of more timing?
Understand, I know we are not discussing tuning but we are discussing turbos and setups. This turbo is very good in IMO and I am very happy with it. I don't consider my setup laggy at all, I respect your opinion.
Old 11-16-2012, 01:24 PM   #39
Chako
Member#: 287272
Juan, ED - speaking of stock location turbos: How do you think this compares to ATP's GTX3576r (65lb/min) and Blouch's DOM 5.0 (65lb/min)?
I think these are the competition to the FP Black HTA. Similar flow & price point
Chako is offline   Reply With Quote
Old 11-20-2012, 11:10 AM   #40
Chako
Member#: 287272
Bump, considering this turbo or atp gtx3576r. Please help with the decision
Old 11-20-2012, 11:40 AM   #41
renosubby
Member#: 152576
2006 STI 10.8@ 129
www.Mayhemtuning.com
I have always had better results with FP the ATP. Spool and power both
Old 01-06-2013, 05:39 PM   #42
juanmedina
Member#: 133146
07 FPgreen 7.37@95
UPDATE
The car is still running strong no issues at all. It has been about 10 months since I installed the engine.
I lowered the timing at peak torque like Crystal suggested for safety of the stock 09 STi rods and increased the timing by one degree at redline. 12* at peak torque and 22.5* at redline 7500.
I lost some mid range but It gained about 10whp from 6000rpm to redline. The TMIC is getting head socked as you can see... second pull . I am still running fairly rich 10.9-11.3 AFR from 4000rpm to redline.
So, what should I do next? This is a 68lb/min turbo it should be capable of making quite a lot more power. What should give me the biggest gains?
Old 01-06-2013, 05:50 PM   #43
rexblake
Member#: 178426
2010 Audi S4
Glad to hear its still running good! I'm surprised you haven't switched to a fmic yet, that should help quite a bit for power.
Old 01-06-2013, 06:51 PM   #44
WhatTurboLag?
Member#: 243992
2006 WRX TR
which compressor housing? 2.4 or 3 inch?
I want videos!!!
Old 01-06-2013, 07:58 PM   #45
juanmedina
Member#: 133146
07 FPgreen 7.37@95
how much whp? which one do you recommend? how much lag?
I want videos!!!
That video is with my 5-speed trans
I actually went to the 1/8th of the mile track a few weeks back and it wasn't pretty. Without launching, missing third really bad and hitting the rev limiter at the end, I still trapped 90mph
Old 01-06-2013, 08:41 PM   #46
KurtP
Member#: 44836
1999 Fozzy
what bpv are you running?
Old 01-06-2013, 08:45 PM   #47
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
I'm running a built block on a dom 3 with meth and on my tmic I was making 375/350 and was knocking past 23. I added a txs fmic and was able to run 26.5 safely and made 415/405 so the switch was a major change in power for me
Slimsti is offline   Reply With Quote
Old 01-06-2013, 09:03 PM   #48
CatfaceType-R
Member#: 81102
You need a fmic, Juan! Glad to see this motor still going strong.
Cheers, Carmi.
CatfaceType-R is online now   Reply With Quote
Old 01-06-2013, 09:38 PM   #49
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
FMIC and EWG.
EDIT: I was pressed for time but wanted to get my words in, if only to revisit them later. The FMIC will allow you to run safer, repeatedly. If you're seeing the power drop on a pull, I'm willing to bet its from post intercooler IAT's. Fix that.
EWG is also just eliminating a bottleneck in the system. I know you ported your Green out, but an EWG skips it altogether. It does not get better than that.
All that said, you're still on thin ice with those rods and the above parts or deeper tuning will more than likely spell the end.
Zee Biker is online now   Reply With Quote
Old 01-06-2013, 10:22 PM   #50
juanmedina
Member#: 133146
07 FPgreen 7.37@95
the stock one crushed. I used to have a Forge BPV but some how it cracked by the flange.
I don't see any knock at all right now. With my FP green I used to run 26* of timing daily and 30* on my race map without any knock. E85 is amazing, I just don't feel like pushing things but I want to make my setup more efficient.
Thanks Carmi
Cheers, Carmi.
Originally Posted by Zee Biker View Post
FMIC and EWG.
Ty
