Old 01-05-2013, 03:10 PM   #1
subie bro
Member#: 327229
2005 Wrx
Default question on how to
Im trying to upload this custom map that was sent to me via email and when i open it to save it, it opens in notepad, then when drag it to my accessport it says its successfully uploaded but when i plug it into my car and click change maps its not there. i had this problem before and i forgot how to solve it, im pretty sure it has to do with how i save it. please help someone.
subie bro is offline   Reply With Quote
Old 01-05-2013, 03:54 PM   #2
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
can you open it in access tuner race and then save it from there changing the extension?
SenorDucK is offline   Reply With Quote
Old 01-05-2013, 04:36 PM   #3
subie bro
Member#: 327229
2005 Wrx
i dont have access tuner race...
Old 01-05-2013, 05:27 PM   #4
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
I assume you are doing an e tune? I just got done getting tuned by Torqued Performance; before loading any maps I received from them onto my AP, I had to first load the map into Access Tuner Race and then save it (please note that when I did this i did NOT change anything with the map or its filename; I just had to go to the FILE menu, select LOAD MAP and then once its done loading go back to FILE then select SAVE; I didnt mess with the name of the file at all). Once I did that, I could then load the new saved map onto my AP and then flash it to my ECU. I think this could be what you need to do. The Access Tuner Race software can be obtained for free from Cobb. You just have to fill out a form on their site (you will need the serial number of your AP). Once you submit the form, you will receive a download link via email. (I think Cobb says it could take up to 24 hours to receive the link, but I got mine in less than 30 minutes).
EDIT: here is the link to the Subaru Access Tuner Race software (you should see another link on this page which will take you to the request form. I forgot to mention that in order to install the software, you will also need to have your AP on hand; at least I did)
http://www.cobbtuning.com/Subaru-Acc...-p/atr-sub.htm
CO11WRX is offline   Reply With Quote
Old 01-05-2013, 05:58 PM   #5
subie bro
Member#: 327229
2005 Wrx
thanks a lot, yes i am getting e tuned from phatbotti he send me a base map on email and its a ptm file once i click it to save or open it it pops up in notepad with a bung of jiberish and symbols, when i save it to my accessport it says its their but its really not when i try to flash the map. so your saying dont save the map click on it then click search for maps on my ap manger and then save it? also download accesstuner race? im a little confused tell me if im on the right track thanks
Old 01-05-2013, 07:36 PM   #6
Blusubman
Member#: 304059
06 WRX
Default bla
im 90% sure u need to change the format of the file you trying to install onto the AP of yours. im not to sure what it is at the moment but it would be something of .ptm as the format and you would change it to what ever format the ap use so that way you see it when you try to flash onto your ecu.
let me know if this works
Blusubman is offline   Reply With Quote
Old 01-05-2013, 07:52 PM   #7
subie bro
Member#: 327229
2005 Wrx
i know your right but i dont know what you have to change it to, its .ptm right now
Old 01-05-2013, 08:05 PM   #8
Blusubman
Member#: 304059
06 WRX
right now it would be hard to determine what you have is good because you cannot view it with accesstuner. best thing i can tell you is make sure you follow the directions on how to download and flash the map on to the ecu. did you fill out the app for accesstuner yet? its about 24 to 48 for cobb to respond.
Old 01-05-2013, 11:42 PM   #9
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
all of my AP maps have been a .ptm file extension. I do believe you will need access tuner race before you can do anything with the custom maps you receive. I think your next step should be to fill out the ATR request form and wait for Cobb to get back to you. They seem to be pretty quick when responding.
Old 01-05-2013, 11:53 PM   #10
subie bro
Member#: 327229
2005 Wrx
i fixed it =)
Old 01-06-2013, 12:19 AM   #11
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
i fixed it =)
Good news! How did you fix it if you don't mind me asking?
Old 01-06-2013, 02:36 AM   #12
subie bro
Member#: 327229
2005 Wrx
My turner re sent it and I saved it as a different name and .ptm at the end even tho it was like the same thing lol
Old 01-06-2013, 10:34 PM   #13
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
Right on...glad you got everything worked out!
