Old 06-19-2010, 02:02 PM   #51
STIStalker
Member#: 92783
2004 WRX
Anybody know the correct part number for the AVCS solenoid O-rings?
My car is leaking either from the cam sensors or the AVCS solenoid.
Its not leaking much but it is for sure coming from one of these two spots.
If I remember correctly there wasn't any o-rings on the cam sensors, they just sit in the holes.
Thanks.
STIStalker is offline   Reply With Quote
Old 09-30-2010, 05:38 PM   #52
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
I just put together a big list of seal part numbers for the 2.0, 2.5, and dual avcs motors, any interest in a new version of this thread?
AQ Motorsports is offline   Reply With Quote
Old 10-13-2010, 11:30 AM   #53
n8t_dog
Member#: 132583
02 stock
white
Yes please.
n8t_dog is offline   Reply With Quote
Old 12-21-2011, 01:16 AM   #54
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Where is it?
ciper is offline   Reply With Quote
Old 02-28-2012, 12:27 AM   #55
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Hey guys, what is this gasket for? I am building a 2.12l EJ205 and haven't yanked the motor yet, so I haven't seen this one before.
Crazykev is offline   Reply With Quote
Old 03-19-2012, 08:50 AM   #56
scoobydo2.0
Member#: 261290
2004 WRX, 05 LGT, 97
LGT Wagon, 91 MR2, 92 DSM
That is the gasket for your oil cap.
scoobydo2.0 is offline   Reply With Quote
Old 03-22-2012, 08:10 AM   #57
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Hahaha! I never would have even thought of the oil cap. I've had a Prodrive one for 6 years.
Thanks!
Old 03-22-2012, 10:33 PM   #58
scoobydo2.0
Member#: 261290
I actually need a new one if you wanna get rid of it?
Old 03-28-2012, 05:39 AM   #59
ciper
Member#: 15543
90BJ Legacy LS ABS
I also didn't realize this. Now I have a use for the three or four left over from engine builds.
Old 03-30-2012, 11:51 AM   #60
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
No problem, PM me your info and I'll mail it out.
Old 04-23-2012, 05:06 PM   #61
rip25rs
Member#: 226199
2005 Legacy 2.5gt
anyone know part numbers of these orings. im kinda stuck.
rip25rs is offline   Reply With Quote
Old 08-21-2012, 10:43 PM   #62
Quiksmith
Member#: 266230
2006 WRX STI
Gah what happened to the photos from the OP??? They arent working
Quiksmith is offline   Reply With Quote
Old 10-09-2012, 04:20 PM   #63
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Bump for fixing the pics
aboothman is offline   Reply With Quote
Old 12-31-2012, 03:02 PM   #64
Type2
Member#: 200436
2004 Forester XT
looking for these pics as well. I have an engine gasket kit, but the 4 black ones that fit don't appear to fit perfect. Also, looking for pics of gasket that fit on AVCS cam seal cap.
Type2 is offline   Reply With Quote
Old 01-06-2013, 11:53 PM   #65
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Shoot me a PM and I can get you pics and part numbers tomorrow
Most of the orings don't fit perfectly and are a bit large
Old 03-11-2013, 10:41 PM   #66
Juice66
Member#: 340526
2004 WRX STi
HTA86
Bumping this. OP have the pics??
Juice66 is offline   Reply With Quote
Old 03-29-2013, 10:36 PM   #67
Justin V
Member#: 98747
07 WRX
I've got one out in the garage I'm trying to piece together. I'll try and get new pics but I'm lost with all the O-rings. the kit I have is for a 08+.
Here's whats left of my gasket kit, Outfront built the block so they used the rear main and the case half O-rings. I already put on the oil pump crank seal too. Head Gaskets are Cometic but stock ones should be included.
Intake manifold gaskets
Intercooler, Header/ Exhaust, and Oil pump - O-ring looks like 2 o-rings connected within each other (minus oil pump crank seal)
Water pump, Oil pan (rear drain tube o-ring has a channel around it (not sure which side face up), and Misc
Valve seals (Black=Intake, Green=Exhaust), Cam seals, Valve cover gaskets, and crush washers for turbo oil feed and water lines and AVCS Solenoids
Timing covers, 7x o-rings go to rear covers where it bolts to the heads and block, Long rubber seals are for the center cover, and Foam trim sticks to the back of the covers.
Unknowns, Rear main is big and brown and like a cam seal (my last kit had 3x), Oil pump crank seal is smaller than the cam seals and brown (should be the only one that fits in the pump)
Labeled O-rings A-F, if they can be identified I'll update it next to the letters:
A) (2x)
B) (2x)
C)
D)
E)
F) (2x)
Justin V is offline   Reply With Quote
Old 04-12-2013, 01:02 AM   #68
Serkan
Member#: 180514
2004 Sti
A- AVCS exhaust cam gear cap gaskets (for 08+ wrx/sti)
B- AVCS intake cam gear cap gasket
C- Oil warmer/cooler gasket
D- ??? Could be oil fill tube O ring
E- ???
F- Oil dip stick o rings
Serkan is offline   Reply With Quote
Old 01-06-2014, 03:08 AM   #69
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
Good info in this thread, thanks for posting those pictures since the originals are missing.
Speaking of missing, this kit doesn't include the aluminum washers to seal the various plugs that go into the short block. Does anyone know specifically what is needed for these, and what the part numbers are?
edit: found my answer:
(6x) 0370S*B - part number 037018200
(2x) 0370S*A - part number 037010200
(3x) wrist pin access hole washers – part number 803928010
Large Coolant Plug on bottom drivers side of motor does not use a washer, pass side coolant port in block next to oil cooler also does not use a washer
TROLL is offline   Reply With Quote
Old 01-07-2014, 04:41 PM   #70
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
Can anyone ID the following from an 07 STi gasket kit? I was able to ID the others using the photos in the thread but havent confirmed these. Looking to confirm 100% so please only respond with info if you're positive!
(I grouped and bagged these for easy reference, they all came in one big bag together).
more detailed pics:
http://i324.photobucket.com/albums/k...psjjq0hzx5.jpg
http://i324.photobucket.com/albums/k...psiuiqko8y.jpg
Old 09-22-2014, 04:53 PM   #71
LYHTSPD
Member#: 26374
2004 WRX Sedan
San Remo Red
Just wanted to bump this since I am working on an EJ205 rebuild, and thread helped a lot. Any further into on the last couple of posts?
LYHTSPD is offline   Reply With Quote
Old 05-06-2015, 07:50 PM   #72
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Specifically which ones were you wondering? If you number the pic I can tell us what a buncha them are. But being on my phone I can't really edit the pic to label it
cowboy_Rob is offline   Reply With Quote
Old 06-17-2015, 10:41 AM   #73
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Not sure on the ones in yellow...
bluescoobywagon is offline   Reply With Quote
Old 07-22-2015, 01:00 PM   #74
wrx4her
Member#: 204459
06 WRX TR
I'm tearing down my engine due to a cylinder 2 misfire I can't seem to fix. While it's apart, I'll be installing the VF39, and sti downpipe. Will the STI 10105AA590 gasket kit work for my 06 wrx with the upgrades?
Thank you!
wrx4her is offline   Reply With Quote
Old 10-03-2015, 04:31 PM   #75
subienewbie88
Member#: 431413
Default .
subienewbie88 is offline   Reply With Quote
2.5 USDM STi short block KZ_Scoob Private 'Wanted' Classifieds 7 10-03-2015 04:32 PM
Axis Stage 2 vs. USDM STi 2.5 Chad W Built Motor Discussion 14 04-29-2007 11:40 PM
V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads? saab-on-the-cobb Subaru Conversions 6 09-18-2006 07:03 PM
Pros/Cons of 2.0 JDM STI vs. 2.5 USDM STI engines TooSlow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 61 01-24-2005 12:14 AM
2.5 USDM STI Motor is strong! Race Tested! WorldOne Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 102 06-23-2004 12:42 PM
