![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#4301 | |
Member#: 255716
NWIC
Vehicle:04.5 v9 STI in wrx clothing, covered in PSM. |
You prob haven't driven on them much but how do the "New" struts feel?
#4302 |
Member#: 79983
MAIC
Vehicle:2005 STI Aspen White |
![]() ![]() Finished up the cleaning process and put the seats back in. Ahhh finally a super clean interior. Now to tackle the exterior. |
#4303 |
Member#: 304662
MAIC
Vehicle:2001 Impreza L coupe Sedona red Pearl |
Tightened down my lateral link bolt, yea the 10 inch long one. That damn bolt is so hard to move, but it was loose for whatever reason.
![]() This is how I did it lol. Floor jack holding the wrench on the 'nut side' so it doesn't move, and a steel pipe on the ratchet for the bolt side. I also got my estimate for the deer damages. $2800 to repair the front fender, drivers side door, and rear quarter panel. My car's value isn't much over $4000, if that, so it COULD get totaled out! 75% of the value right? Gonna be close! Last edited by ManualOverAuto; 01-05-2013 at 03:18 PM. |
#4304 | |
Member#: 85565
Vehicle:05 RS Sport |
#4305 |
Member#: 6850
MAIC
Vehicle:Lots of ESP cars '06 IAG WRX & LT1 Z28s :) |
Had the first break in oil change done in the WRX. Gotta go put some more miles on it for the next one and the retune for next week!
![]() Did a brake job on the black Camaro. Discovered that the inner pads on the front were separating from the backing plate. On the passenger side, it was bent and completed separated on one side. I guess that explains the weird vibration under braking. The new Hawks (HP+ up front, HPS in the rear -- keeps the axle hop that a Z28 is prone to doing minimal) are great so far. ![]() |
#4306 |
Member#: 74392
MAIC
Vehicle:2013 BRZ DGM |
Installed the whiteline steering rack bushings. My arms are dead.
#4307 |
Member#: 261832
MAIC
Vehicle:06 WRX TR WRB |
Put new speakers in the Forester.
#4308 |
Member#: 107000
MAIC
Vehicle:2008 STI <3 TXS and 2011 F150 Andrewtech |
Tore down my heads to send off. My house smells of oil. : /
#4309 | |
Member#: 145105
MAIC
Vehicle:2007 WRB WRX Limited |
#4310 |
Member#: 6850
MAIC
They actually have plenty of backing material, it's just not all firmly attached to the backing plate.
The vibration started recently, and with the suspension work I'd been doing piece meal (the control arm bushings, then the shocks/springs), I wasn't sure what the cause was initially. |
#4311 |
Member#: 137791
MAIC
Vehicle:2002 Impreza WRX WR Blue |
I took some detailed pictures of emergency brake before I took them apart this time.
![]() I really hate drum brakes ![]() |
#4312 |
Member#: 342676
NESIC
Vehicle:11' lexus isf sti sold 2011 Lexus isf |
Fixed a small gas leak from my perrin fuel rail. crimp ring must have loosened up a bit combined with really cold weather equals leak. couldnt fit anything other than needlenose pliers in their to crimp it but it worked (for now)
#4313 |
Member#: 342676
NESIC
Sweet! I have feal struts(tarmac) with zerk fittings paired with rce blacks and they are awesome! Sounds like a sweet setup
#4314 |
Member#: 239638
MAIC
Vehicle:2007 WRX TR UGM 02 MR2 EGM |
Put on the HKS flat flange downpipe. Going from a 5 inch divorced wastegate to this makes a world of difference. Getting the old one off was a pita because the bottom nuts are obstructed by the EWG. Install was a snap.. but I should have put an extra gasket on the DP-> Catback flange. Will have to fix that in the AM. Definitely heard an exhaust leak coming from there.
Also have an AOS to install tomorrow. |
#4315 |
Member#: 131379
MAIC
Vehicle:2003 354 ftlb@3k rpm justablue hatch |
washed outside and cleaned inside windows of our 2 subarus. 03 hatch and wife's '13 outback.
#4316 | |
Member#: 6850
MAIC
#4317 | |
Member#: 239638
MAIC
Fixed the exhaust leak best I could considering I didn't have a new gasket. |
#4318 |
Member#: 74392
MAIC
Washed it. Jeeeeeeeeesus it's cold outside.
#4319 |
Member#: 310254
MAIC
Vehicle:04 Forester XT Silver? |
Jim (the undisputed subaru whisperer) helped me install my new grimmspeed thermostat, drilled and slotted rotors, and cabin filter. i am eternally grateful for your expertise in subarus.
one of the bolts in the rear caliper seized and broke, so jim and i got to experience the least entertaining task of drilling, torching, threading, etc... also this weird phenomenon: |
#4320 |
Member#: 310527
MAIC
Vehicle:2012 WRX Hatchback DGM |
Washed her and put on the winter setup. All i need now is the snow
![]() ![]() Wintermode by itcouldonlybeme, on Flickr ![]() Winter wheels mounted! #wintermode #wrx #subaru #awd #turbo #snow #tires by itcouldonlybeme, on Flickr |
#4321 |
Member#: 145105
MAIC
#4322 |
Member#: 41447
MAIC
Vehicle:---- _________ |
#4323 |
Member#: 145105
MAIC
#4324 |
Member#: 288292
MAIC
Vehicle:2004 sti wrb. the blue one. |
#4325 |
Member#: 145105
MAIC
| Thread Tools | |
| Display Modes | |
| What did you do to your car today? | Jester808 | Texas Impreza Club Forum -- TXIC | 2959 | Today 01:00 PM |
| what did you do to your car today? | Schrecken | Bay Area Impreza Club Forum -- BAIC | 11 | 09-25-2012 03:08 AM |
| What did you do to your Scoob today? | Sheehan | North West Impreza Club Forum -- NWIC | 27 | 11-23-2007 12:02 PM |
