Old 01-05-2013, 01:10 PM   #1
Kevwa451
Member#: 314408
2011 WRX Stage 2
Default Dust caps
I bought a set of 16x6.5 steelies off tirerack for my 2011 WRX and didn't realize until I got them that there's no dust caps to cover the axle nut. I saw pictures of a car just like mine wit the same steelies and it didn't look like he had any dust caps. Should I not worry about it? That nut seems to be sealed but I don't want any salt and **** in there. I searched and only found 1 thread from 2001 with 3 replies that didn't help much. Thanks for any help you can provide.
Kevwa451 is offline   Reply With Quote
Old 01-05-2013, 01:43 PM   #2
vision.dynamix
Member#: 139955
# OneBoston
Half of NASIOC doesnt use center caps. Even with center caps it doesnt seal that chamber off.
vision.dynamix is online now   Reply With Quote
Old 01-05-2013, 02:16 PM   #3
Kevwa451
Member#: 314408
2011 WRX Stage 2
Thank you sir, that's all I needed to hear.
Old 01-07-2013, 11:17 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Showin' off those rusty axle stubs is JDM-tite, y0!
Old 01-07-2013, 11:23 AM   #5
vision.dynamix
Member#: 139955
# OneBoston
My axle stubs, axle nuts and hubs aren't rusty and the track doesn't allow center caps. Your argument is invalid.
Old 01-07-2013, 11:47 AM   #6
sc00by4life
Member#: 97135
steelies typically don't have center caps in the first place.
get a set of hub caps if you really care?
theres nothing wrong with not using them..
Old 01-07-2013, 11:56 AM   #7
hakira
Member#: 74211
SSM WRX 4DR
You actually got brake clearance with that size?
hakira is offline   Reply With Quote
Old 01-07-2013, 02:48 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
You must have the aluminum axles stubs, nuts, and hubs - even more JDM-tite, y0!
Which track is "the track"? None of the ones I've gone to care.
I didn't realize there was an argument being made. How about "because racecar"?
Old 01-09-2013, 09:41 PM   #9
Kevwa451
Member#: 314408
2011 WRX Stage 2
Plenty of brake clearance on the rears, probably 3/8's of an inch to half on the fronts.
Old 01-09-2013, 10:13 PM   #10
hakira
Member#: 74211
SSM WRX 4DR
/me starts to dig out and clean up some old 16' rims for rallyx
Message Board Statistics All times are GMT -4. The time now is 07:50 PM.
