Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 01-05-2013, 10:40 PM   #1
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Default Quick question
May be a stupid question and I've done some reading but can't find anything, I just ordered an invidia 3in DP, is it necessary or just a complete waste of money and time, to header wrap the down pipe. I don't half ass any work I do and I'm really thorough so I will be getting new gaskets a new 02 sensor(stock one is at 141k now, figure it could use a replacing) and use anti seize on the sensor threads. Any tips or info would be helpful thanks, haters comments save your breath please
04scoobywrxwagon is offline   Reply With Quote
Old 01-06-2013, 01:04 AM   #2
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Found a thread on it, never mind. Sorry
Old 01-06-2013, 10:59 AM   #3
hoffmanEstates
Member#: 122043
04 wagonier
psm
Wrap it. I had my wrap falling, and eventually i rewraped it and keeps engine bay cooler and exhaust gasses happy
hoffmanEstates is offline   Reply With Quote
Old 01-06-2013, 04:31 PM   #4
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Recommendations on a good wrapping technique?
Old 01-06-2013, 04:34 PM   #5
hoffmanEstates
Member#: 122043
04 wagonier
psm
I use dei wrap which is.found anywhere. I started at top and work down.
Old 01-06-2013, 07:05 PM   #6
Erittz
Member#: 282506
Just wrapped my down pipe tonight. I did turbo down, had my brother hold it tight as I wrapped it around the under side. I used 5 *not necessary* metal zip ties to hold it tight and on all the way down the wrap to the bottom of my firewall
Erittz is offline   Reply With Quote
Old 01-06-2013, 08:25 PM   #7
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
I heard its "better" to wrap it from bottom up, to have a "shingle" effect if water gets down in that area, so the water just runs down and off instead of in between the wrap..
Old 01-06-2013, 09:23 PM   #8
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
It is. It also makes the wrapping process more difficult. Harder to estimate your length required but still very doable. The difference is probably small in the big picture. Most of the people wrapping DPs go the turbine to cat-back direction and never think about this.
The best thing you can do is use the LR type wrap (i.e. DEI Ti wrap) and forget that old crap header wrap.
Yes on the new O2 sensor. Yes on the anti-seize on the threads. Just do not get anti-seize near the sensor's business end, it will affect it's accuracy and lifespan. Also notch the RHS manifold heat shield while you're in there, only takes quick snips or grind. Helps if you ever have to remove them again, no need to remove the O2 sensor first. I usually copper spray the turbine gasket for safe measure but it is not required. You could also modify your OEM DP heat shield and reattach it over your Invidia...more heat control and some elusiveness.
Good luck, tune the ECM for the DP, and enjoy
Old 01-06-2013, 10:45 PM   #9
hoffmanEstates
Member#: 122043
04 wagonier
psm
Yes key note tune must be performed unless you are 2002
Old 01-07-2013, 12:42 PM   #10
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Ya I know about not getting it on the o2 sensor itself except threads, I have an associates degree in automotive so general automotive stuff I'm pretty squared away on, just new to the turbo world. I also have a Cobb AP that's gonna be here tomorrow so that will be happening
Old 01-07-2013, 12:45 PM   #11
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Will the 1 roll of 2x50 dei wrap be enough?
Old 01-07-2013, 12:58 PM   #12
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Got the 2x50 dei wrap ordered I'm assuming 1 roll is plenty. Super excited to get a little bit of Subaru rumble
Old 01-07-2013, 01:48 PM   #13
hoffmanEstates
Member#: 122043
04 wagonier
psm
Wrap down as far as you can including midpipe and uppipe if you want to.
Old 01-07-2013, 07:46 PM   #14
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Still need to get an aftermarket up pipe, any suggestions? Also just want to thank you guys for not being a$$hats. You have been nothing but help and I appreciate it
Old 01-07-2013, 07:52 PM   #15
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
I literally just have the downpipe ordered, I'm going to want full tbe I know but I'm very indecisive as to what I want as the cbe, or what up pipe.
Old 01-07-2013, 08:39 PM   #16
hoffmanEstates
Member#: 122043
04 wagonier
psm
You can do sti up pipe. Grimmspeed helix ect......
Old 01-07-2013, 10:03 PM   #17
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Alright, another thing, as far as cat back goes, maybe it's just me but I'm huge against getting a "fart can" type axle back, I absolutely hate the look of them, so I've been looking for a decent (muffler, dual tip, or single non "fart can" type tip) if I absolutely can't find anything. Ill settle, but for some reason I despise those big ugly tips, only thing I can find that I like is the borla hush axle back but I don't want to spend $500 plus simply bc it's not a fart can :/
Grocery getter wagon problems
Old 01-07-2013, 10:04 PM   #18
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Correction $600+
Old 01-07-2013, 10:13 PM   #19
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Now checking out some gimmick cbe off eBay cause they are cheap and back there I don't need some crazy expensive "zomgawesome" piping
Old 01-07-2013, 11:54 PM   #20
blk05wrx
Member#: 180559
2016 WRX STi Limited
Get the borla. You'll be glad you did. I've been running mine for 8 years, still looks and sounds great. I also run a used sti up pipe for what it's worth. Great figment and already has heat shielding.
blk05wrx is offline   Reply With Quote
Old 01-07-2013, 11:55 PM   #21
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
I just can't justify spending $650 for just a cbe... That's really steep, but I don't really want to run a 3in catless dp into the stock wrx catback haha
Old 01-08-2013, 08:35 AM   #22
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Uppipe - As noted. On the cheap, used OEM 2006+ WRX/STI uppipe. If willing to spend some cash, a reputable aftermarket uppipe like Grimmspeed. Don't forget new gaskets.
Cat-Back - The cost directly affects the fitment. On the cheap you can try one of the lower cost cbe's but understand that it "might" have a higher chance of fitment compromise. I have seen a pretty good lower-cost cbe on a friend's car...I'll try to find out what it was and update my post. **Speed Tech and I think he said it was around $300.**
If you are willing to spend some cash, look at something like the Borla. The Borla Hush is a fine choice but you will have to buy the 3" adapter for your DP (or make it) which adds to the cost (~$50). The Borla also uses mild steel flanges and steel hanger clips which (in our area) will eventually rust, I've been running one since 2006. HERE If it was me, I'd pay a bit more for a MadDad Whisper, DONE.
Old 01-08-2013, 09:46 AM   #23
hoffmanEstates
Member#: 122043
04 wagonier
psm
I have a prodrive oval.tip.and a.devil axle Back. You can also.buy a genome axle back. Its nice subtle and has a rumble, or a simple sti muffler. If you are tired of Wagon i have a guy with a sedan looking to trade 04 in psm
Old 01-08-2013, 11:05 AM   #24
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
I am by no means tired of the wagon I think they look 10x better then wrx sedans, ill look into those exhausts when I get off work, I'm not a cheap person by any means but $650 is just ridiculous for a cbe, I won't need any 3in adaptor for any exhaust cause I'm gonna be putting on an invidia v3 dp, thank you guys for the help $300 range is a good price and I would pay that for sure for a good cbe
Old 01-08-2013, 11:17 AM   #25
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Pm'd speedtech looks like a decent exhaust
