Old 01-04-2013, 05:27 PM   #26
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
okay i obviously know there is damage but you guys are overdoing the damage I am a driver not a mechanic but still you guys assume the worst plus i just check the valves that connect to the Crawford oil seperater and there wet with oil just replaced. yeah was a blown engine cars running great now hahahaha you guys really know your stuff thanks anyways
albanhaj is offline   Reply With Quote
Old 01-04-2013, 05:50 PM   #27
bboylocob
Member#: 151809
2007 WRX
Haha ok dude u better hope there was still enough to not cause damage. Lol
1st always assume the worst and hope for the best
2nd u still probl. Have damage that will call for alot of work.
3rd that much oil should not becoming out of ur aos. Keep a look out.
bboylocob is offline   Reply With Quote
Old 01-04-2013, 07:51 PM   #28
stephens
Member#: 124581
I vote that you fill it with oil (even though you have not told us what oil you are using) and hit boost in third and fourth gear.
It will clear up all of your oil burning problems guaranteed.
stephens is offline   Reply With Quote
Old 01-04-2013, 10:44 PM   #29
tuzzio
Member#: 292532
05 STI
...Did you check your drain plug in the oil pan?
tuzzio is offline   Reply With Quote
Old 01-04-2013, 11:28 PM   #30
wrx1392
Member#: 342331
2003 wrx
blue
if it runs ok it could be a seal in the turbo ...all the oil leaks out and makes smoke come out the pipe .or it could be crushed ring lands and big damage.
wrx1392 is offline   Reply With Quote
Old 01-04-2013, 11:43 PM   #31
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
i didn't change the oil on it a shop did, i don't think you guys understand fact that car was never driven without oil. car just had a fresh oil change but its recently burning it all. i need is why its being burnt.
I don't think you understand that if the car has a problem that results in excessive oil consumption, then it is very possible that you drove the car with insufficient oil in the crankcase and caused further damage to the engine. One problem leads to another. You can't be certain that other internal damage to the engine was not done.
tibug is offline   Reply With Quote
Old 01-05-2013, 12:10 AM   #32
WRXSteye20008
Member#: 175565
2014 Sport Premium
Oh and a piston ring repair will only cost me about 600 to 800 bucks not to bad hopefully not thought and it just worn valves.
This would be you. You are getting excessive blow by from a ringland and a lot more. Your car will run fine, with a ringland failure, mine did until it sucked oil like crazy. I stopped driving the car and rebuilt the engine and sure enough that was the issue, you are past that point. I am glad you are trying to think positive, but you will come to realize we are right. If the sound of your engine was not the first indication that something was wrong, you should not own anything that has an engine in it. No one opens a Subaru engine and just repairs rings. 800 bucks, try $3,000+ You are WAYYYYYY past that point hoss. I sub'd to this thread for the entertainment as you see to not really be listening the the advice we are offering you. Best of luck.
WRXSteye20008 is offline   Reply With Quote
Old 01-05-2013, 12:58 AM   #33
Okay so the other day my 2002 wrx with a 06 Sti engine started smoking a lot from the exhaust and turned off. I got the car home and saw no oil on the dip stick. All my oil was burnt as soon as I added some oil into the car started right up but burns the oil like crazy. not sure exactly why. What could it be?? I the car doesn't seem okay to drive because the oil is burning pretty quickly and not sure why. Also smoke is coming from the valve that connected the crawsford oil seperator. not exactly sure what the problem could be. Any ideas ?
Here's a video of the car idling watch whole thing
Subaru sti 2.5l burns oil fast - YouTube
i didn't change the oil on it a shop did, i don't think you guys understand fact that car was never driven without oil. car just had a fresh oil change but its recently burning it all. i need is why its being burnt. and its technically only the first engine since the other one was perfectly fine but it was the 2.0 wrx engine. the car just got a oil change 200 miles ago. I understand your point you think the engine is "blown"if it is i don't care my question is what do you think caused it or what else it could be besides blown engine... do you guys only assume the worst on here or something? im amusing the turbo seals and you guys assume a blown engine when it has less then 15,000 miles on it regardless on how much it was beaten on and the car only has 44xxx miles on it... .
now...one dont match the other
Old 01-05-2013, 09:41 AM   #34
tuzzio
Member#: 292532
05 STI
OP = OPie
Old 01-05-2013, 03:41 PM   #35
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
i use 10/40 oil in winter and 20/50 oil in summer non synthetic. I have my friend specializes in subarus checking out car for any internal damage today hoping for the best!
Old 01-05-2013, 04:56 PM   #36
tuzzio
Member#: 292532
05 STI
I thought you said it was fine yesterday?
Old 01-05-2013, 06:27 PM   #37
corvallisbattery
Member#: 333030
'05 WRX
Uncle Scotty.... if your gonna lay into anyone this is the guy to do it to! Can't believe you've kept a bite on your tongue this long!!! Come on.. just this one last time...for ol time sakes
corvallisbattery is offline   Reply With Quote
Old 01-05-2013, 08:47 PM   #38
d0000000000000d
just get a gallon of gas and a match and pour the gas on the car and light it up
that would be a better end for it than have you drive it again
Old 01-05-2013, 09:31 PM   #39
DavC825
Member#: 201736
12 IS-F..its white
07 Sti Blk
My head hurts....Sorry brain cells.
DavC825 is offline   Reply With Quote
Old 01-06-2013, 12:44 PM   #40
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
The car is fine just need make sure nothing else is damaged and its perfect
Old 01-07-2013, 09:08 AM   #41
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
What makes you say this? Did it all of a sudden quit burning oil?
drivin blind is offline   Reply With Quote
Old 01-07-2013, 10:04 AM   #42
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Trolls be trollin'.
Why don't you understand this? You've come to this site asking for help. You get very thorough and knowledgeable responses from people who clearly know what they're talking about. You throw all of it aside and assume your car is fine, even though you destroy the very sense of common knowledge by running your car with known oil starvation. I just don't get it. You must be trollin.
Decipher is offline   Reply With Quote
Old 01-07-2013, 03:58 PM   #43
GrumpyPitbull
Member#: 313311
Originally Posted by Decipher View Post
Trolls be trollin'.
I've seen this a lot here recently. New guy asks for advice, and receives good advice .... Then proceeds to completely disregard the advice and do the opposite of what was advised.
Old 01-07-2013, 10:57 PM   #44
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
yeah you guys gave me advice thanks but your advice was wrong my engine isn't blown and is perfectly fine, this is what happened exactly since you guys probably didn't understand me. Oil separator went, oil got into turbo and piping and inter-cooler, it all got cleaned out along with turbo and i replaced the oil separator. Nothing was damaged at all as you guys claimed i had a blown engine. Only reason i came onto here was to see what other possible reasons this problem could happen. the engine and turbo are perfectly fine. thumbs up for a very well built car because if it wasn't this car would of been a goner. thanks anyways guys sorry for misunderstanding. Good Luck and may your Subies last forever
Old 01-07-2013, 11:43 PM   #45
just wait.......it WILL blow up
