Old 01-03-2013, 09:33 PM   #1
Manny830
Member#: 317111
2002 Wrx impreza
Rally blue
Default Up pipe broke, need help
Ok so I'm a noob and wanted advice on this issue. When I was installing (used) turbo on my bugeye I noticed that my invidia uppipe had cracked along the weld that holds the up pipe and flange for the turbo side. Can I just take this to a muffler shop and have it welded back together or better yet have an expierienced buddy at welding weld this for me. Thanks for any advice.
Manny830 is offline   Reply With Quote
Old 01-04-2013, 12:46 AM   #2
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
Yes but it should be TIG welded.
Surb00 is offline   Reply With Quote
Old 01-04-2013, 08:38 AM   #3
bluemk3
Member#: 263694
I've welded up several for myself and friends with a mig. Seems to work fine... Just grind the old weld out pretty good first
bluemk3 is offline   Reply With Quote
Old 01-04-2013, 08:43 AM   #4
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Remember to drill out the ends of the crack.
Old 01-04-2013, 06:53 PM   #5
bmw325ix
Member#: 204652
agreed, drill the crack at the ends, and TIG. Anything pre turbo I like to have the inside as clean as possible. I am more then willing to help if you want to ship it out to the east coast. Just offering.
bmw325ix is offline   Reply With Quote
Old 01-04-2013, 09:47 PM   #6
Mr. Wagon
Member#: 244383
Steel or stainless?
Mr. Wagon is offline   Reply With Quote
Old 01-05-2013, 12:11 AM   #7
Manny830
Member#: 317111
2002 Wrx impreza
Rally blue
First thanks for the replies,and it's stainless if I'm not mistaken. Also, is this something common that happens or more of a rare thing. Thanks for the offer bmw325ix. What do you mean by drilling out the cracks at the ends. Do you mean grinding out the break.Thanks Again
Old 01-05-2013, 06:28 AM   #8
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
You are going to have to "v" the crack. But where the crack ends you should drill a 1/8" hole to prevent further cracking. Do this on both ends.
Old 01-05-2013, 06:28 PM   #9
Mr. Wagon
Member#: 244383
If its stainless(or steel for that matter) and an exhaust part going through heat cycles, TIG it. No real need to v the weld out unless you want it to look pretty. Start the weld a quarter inch before and end it a quarter inch past the end of the crack. Lay it in with a bit more heat than normal and use a 309 stainless rod.
Old 01-05-2013, 09:45 PM   #10
Manny830
Member#: 317111
2002 Wrx impreza
Rally blue
Man sorry guys i should have explained myself a lot better. When I said that the up pipe had cracked I meant all the way around. Like all the weld that holds the up pipe to the flange that connects to the turbo.
Old 01-07-2013, 11:57 PM   #11
Mr. Wagon
Member#: 244383
In that case use the jagged edge to align the flange to the pipe. Tack it up at 12, 3, 6 and 9 o'clock. TIG it back together with more heat than normal using 309 fill rod without releaving the original weld.
