Old 01-04-2013, 03:13 PM   #26
Equilibrium Tuning
Member#: 26933
2006 STI
Are they running E85 with the 340?
Yep most of them are running E85. I haven't seen a single failure from those pumps to date.
-- Ed
Old 01-04-2013, 03:34 PM   #27
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
From what I read the Evo guys had tons of problems with them. I'm looking for more options to get more fuel out of my 08+ plastic housing setup and that seems like the best answer, if it works... Or the new Walbro 465, but I don't know if it will fit.
Old 01-04-2013, 04:16 PM   #28
AkumaMotorsports
Member#: 214570
Originally Posted by KurtP View Post
ah....changing with the times and going from the "heart breaker" to the "sweet heart" calibration.
In Ed's defense he held out for true numbers more than most did, and people around this forum are starting to call their local dynojets and 'wheels-off' variants "heart breakers".
The last people I knew of using real mustang type numbers were Akuma, EQ, and STM. Pretty sure Akuma is on the dynojet calibration now too for the same reason.... I guess, though, if other shops are using the inflated numbers it makes it harder to compete when you say they can make "300" and the other place is saying they can make "350".
Ah well.
We are not running Dynojet Calibration. I personally do not like to compare numbers as we all know numbers on one dyno is not necessarily comparable to another. Its better to compare them on the street, line them up and see what happens. Minus any driver error a good old race should reveal the faster car. Its about the tunes performance, longevity and reliability. Im sure we can all agree on that.
-Kevin
AkumaMotorsports is offline   Reply With Quote
Old 01-04-2013, 04:34 PM   #29
apetron
Member#: 146874
07 STI Flared
E85 422/457, 13 Forester
Originally Posted by Equilibrium Tuning View Post
Actually closer to 496whp I believe. I'll have to check it out. The nice thing is I can reprint anyone's dyno chart from the past with the new calibration.
-- Ed
Damn!!
Thats like 530tq then... lol
When's the next dyno day/bbq??
(Seriously though, I want that turbo.)
apetron is offline   Reply With Quote
Old 01-04-2013, 07:30 PM   #30
PROcede
Member#: 293500
11' WiderBody Hatch
Originally Posted by apetron View Post
Damn!!
+1...
PROcede is offline   Reply With Quote
Old 01-04-2013, 07:39 PM   #31
KurtP
Member#: 44836
1999 Fozzy
-Kevin
Absolutely and you guys do a good job. I had just thought you all had changed your calibration. I know John was explaining to a few GTR owners another shop's inflated numbers.
Old 01-05-2013, 12:05 PM   #32
Equilibrium Tuning
Member#: 26933
2006 STI
Originally Posted by PROcede View Post
+1...
I'll try to set one up soon!
-- Ed
Old 01-05-2013, 12:06 PM   #33
Equilibrium Tuning
Member#: 26933
2006 STI
I think Akuma is one of the only shops left at this point using the factory Mustang calibration.
-- Ed
Old 01-05-2013, 12:35 PM   #34
Purple Drink
Member#: 237470
2007 Varis WB STI
P. Silver
what injectors are you using by chance and what CC?
Purple Drink is offline   Reply With Quote
Old 01-05-2013, 02:51 PM   #35
Equilibrium Tuning
Member#: 26933
2006 STI
Injector Dynamics 2000cc.
-- Ed
Old 01-05-2013, 07:59 PM   #36
Purple Drink
Member#: 237470
2007 Varis WB STI
P. Silver
thanks!
Old 01-06-2013, 12:13 AM   #37
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
-- Ed
Wow really? I just figured they got a new dyno or changed there settings as my buddies 11 stage 2 sti on 93 made 310/327. Those are Amazing numbers in that case, I didn't know the newer models made power like that.
Nice numbers ed that graph looks clean
Slimsti is offline   Reply With Quote
Old 01-06-2013, 01:00 AM   #38
Equilibrium Tuning
Member#: 26933
2006 STI
Hmm that's pretty high but I could see it on 93 and a really healthy stage 2 setup. Does he have headers?
Old 01-06-2013, 10:41 AM   #39
Equilibrium Tuning
Member#: 26933
2006 STI
Btw... Anyone notice this thing is making 300ft-lbs by about 3700RPM? I think this is the area where the GTX turbos really shine by filling in the curve before peak torque.
-- Ed
Old 01-06-2013, 03:43 PM   #40
bilt2run
Member#: 134211
^^^yea this..but I think the 3071r you did a while back was at 3400rpm or so
bilt2run is offline   Reply With Quote
Old 01-06-2013, 05:10 PM   #41
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
-- Ed
my FP black hit 300wtq at 3350rpm.... yes on the 2011 STi tranny
Do you recommend running a catch can Ed?
Old 01-06-2013, 09:41 PM   #42
idratherbesurfing
Member#: 282972
No. its my car catless invidia downpipe, p&l catback, aem intake, dw65 fuel pump
idratherbesurfing is offline   Reply With Quote
Old 01-06-2013, 11:57 PM   #43
Equilibrium Tuning
Member#: 26933
2006 STI
With the new dyno calibration it would actually be around 3200-3300RPM but its not an apples to apples comparison. That was done in a taller gear (4th gear on 08+ 6MT) and that car was running a TMIC. Either way, that turbo does spool faster in general, but this GTX3076 still has quite a bit more power left in it while the 3071 was nearly maxed out. Both are great turbos depending on what power and spool characteristics you're looking for.
-- Ed
Old 01-07-2013, 12:00 AM   #44
Equilibrium Tuning
Member#: 26933
2006 STI
Yea... This 3076 would also do that if I made a pull in 5th gear on the road .
Catch cans are good for higher power, higher boost cars and especially if they're being tracked. I'm not a big fan of AOS's, however, unless you have a ton of oil consumption for some reason. And then it's basically just a decent bandaid.
-- Ed
Old 01-07-2013, 12:02 AM   #45
Equilibrium Tuning
Member#: 26933
2006 STI
Sounds like a nice healthy motor. I've seen up to 280whp with that setup on 91 on the old mustang calibration, so 310whp wouldn't surprise me too much on 93 on a nice cold day.
-- Ed
Old 01-07-2013, 01:44 AM   #46
silverbullet415
Member#: 186457
2010 Subaru STI SE
my gtx3071 turbo is awesome, it may be time to upgrade to something bigger lol
silverbullet415 is offline   Reply With Quote
Old 01-07-2013, 04:46 PM   #47
Equilibrium Tuning
Member#: 26933
2006 STI
Let me know
We can go one step up with the 3076, or could try the 3576 although I haven't tried that yet.
-- Ed
Old 01-07-2013, 05:51 PM   #48
idratherbesurfing
Member#: 282972
-- Ed
It was a pretty cool day as well as 93 oct. good numbers ....but we always want more haha it truly is a sickness
Old 01-08-2013, 02:57 AM   #49
Irv Weissmanhowerton
Member#: 278519
KBiz KeeganLB 30rSTI
phatron tuned
Let me know
-- Ed
handle that please, would love to see the results
could you explain some more details about this turbo, thanks
Old 01-08-2013, 06:19 PM   #50
Equilibrium Tuning
Member#: 26933
2006 STI
I'd love to try it out... just need the right customer .
Its supposed to be somewhere between the GTX3582 and GTX3076.
-- Ed
Message Board Statistics All times are GMT -4. The time now is 11:15 PM.
