#1 |
Member#: 101926
BAIC
Vehicle:06 Subaru WRX STI OBP |
2006 STI has roughly 110K miles. Took it in for a service few thousand miles previous, cylinder #2 had broken valve and spark plug. They also did general 100K maintenance (replaced timing belt, water pump, and tune up). Cost roughly 2.8K.
Engine was making noise and took it back. They said the main bearing was worn due to excess pressure from broken valve. They say I need a new engine. Is there any other solution besides a rebuilt or new engine? If not, what would be the best route to go; replace with stock engine and components or upgrade. If upgrade, what should I upgrade and where should I take it? What would the cost be of stock replacement compared to other solutions? Thanks for the help. I live in the Bay Area, if you could recommend a shop or two I would appreciate it.
#2 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
LIC up in Novato is a great shop. GST in Hayward. I hear Auto HQ is good but have no experience. Same for Speed Element. Start with the first two D they will recommend closer shops if needed
#3 | |
Member#: 327401
Vehicle:2006 STI WRB |
#4 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
Or a rallispec street spec short block is a great one too.
#5 |
Member#: 342331
Vehicle:2003 wrx blue |
im wondering how they could hear a worn main bering ???? a rod bearing yes,but a main bearing
#6 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
maybe OP misunderstood what the stealership told him.
#7 |
Member#: 170439
Vehicle:I <3 Lamp |
excess pressure from a broken valve!? sounds like a load of BS to me.
