Old 01-07-2013, 11:07 PM   #1
Imprezid
Member#: 320777
2005 STI
Default 05 STI wont start P2021
HELP. I did a complete 05 STI swap to my 02 WRX coupe. Engine, tranny, axles, brakes, interior, wiring harness, front end, etc... literally everything. The engine is in and its turning over but it will not start. The cruise control light continues to flash so i scanned the car and it read a code P2021 Intake Manifold Runner Position Sensor and something about Switch Circuit Low Bank 2. Im guessing this means the TGVs (Tumble Generator Valve) Sensors. It looks like the owner before me already switched out the TGVS on the passenger side near the turbo, but maybe it was done wrong? I know there difficult to put on. I checked the coil packs on the passenger side and there not getting spark. If a TGVS goes bad can that cause me to not get spark? Im so lost now and would love to solve this issue. Sorry for the long write up. I hope somebody can help me. Thanks.
Imprezid is offline   Reply With Quote
Old 01-07-2013, 11:36 PM   #2
tanner20
Member#: 327401
2006 STI
Check the driver side tgv's. the code p2021 came up for me when the sensor popped off of the tgv. As for no spark I'm not totally sure I'd check wires fuse's and all connectors and try starting it again. Maybe you'll need new coil packs.
tanner20 is offline   Reply With Quote
Old 01-08-2013, 07:17 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
check wires around starter
Old 01-08-2013, 02:31 PM   #4
Imprezid
Member#: 320777
2005 STI
I checked the with spare coil packs i have and not getting spark on te passenger side. Still need to check driver side. What fuses should i be checkng for spark and tgv issues?
