Old 01-05-2013, 06:34 AM   #1651
B1Ad3
Member#: 311829
06 sti
18x9 +27. Will this fit ? If so what will be required ? Bit of camber and fender roll?
What will be the best option for tires ? 245/35 ?
Thanks.
B1Ad3 is offline   Reply With Quote
Old 01-05-2013, 08:28 AM   #1652
sc00by4life
Member#: 97135
Originally Posted by B1Ad3 View Post
06 sti
Thanks.
To run that much tire...depends on ride height hut at the very least a roll in front and trim the rears. How much you need to pull depends on camber and ride height.
Old 01-08-2013, 04:19 PM   #1653
dmt2012
Member#: 342858
2008 WRX Premium
08 wrx sedan
Looking at getting a set that are
17x8 +48
what Tire profile will give me good performance and clearance?
dmt2012 is offline   Reply With Quote
Old 01-08-2013, 04:27 PM   #1654
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Originally Posted by dmt2012
08 wrx sedan
17x8 +48
OEM size 235/45/17
Old 01-08-2013, 06:09 PM   #1655
sc00by4life
Member#: 97135
Originally Posted by Digital Dillon View Post
OEM size 235/45/17
Actually oem size for his car is 205/50/17.
I'd do a 235/40.
Old 01-08-2013, 07:44 PM   #1656
Digital Dillon
Member#: 288727
2008 WRX premium
I'd do a 235/40.
Ohhh **** idk why I thought that. Widebody tire size? And 09-10 they did a wider tire.
Go with what sc00by4life said!
Old 01-08-2013, 08:16 PM   #1657
Ridebmx08
Member#: 253032
2005 Stroked Saabaru
Kind of a challenging question but I have a Saab 9-2x wagon that had a 06 STI front clip when I bought it a while back. I was thinking of getting some 18s but I want something wider that will fill the sedan front fenders up because right now I have 04 sti bbs and I hate how they sit so far in. How wide of rims should I get and what size tire? I know I'll have to roll the rears and that's fine, I just really want to fill up the fronts.
Ridebmx08 is offline   Reply With Quote
Old 01-08-2013, 10:03 PM   #1658
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
18x8.5 +48 will fill those right out. Run a 225/40 and you'll be good to go.
flat4LGT is offline   Reply With Quote
Old 01-09-2013, 05:54 AM   #1659
RealEurotrash
Member#: 341873
Would this setup work?
13 STI wagon
18x9.5 e32 Rota PWR
(http://www.wheeldude.com/catalog/pro...oducts_id=6784)
265/35/18 Star Specs
Mild drop on BC BR coilovers, thinking 1.8/1.5 camber. I wouldn't mind rolling the rear fenders. If the 32 offset is not possible, would 38 work? I don't really like the color option for 38... but I guess I can always get them powdercoated...
thanks!
RealEurotrash is offline   Reply With Quote
Old 01-09-2013, 06:17 AM   #1660
sc00by4life
Member#: 97135
13 STI wagon
18x9.5 e32 Rota PWR
thanks!
you'll most likely need to roll all around. and AFAIK, there is no camber adjustment in the rear for your car. you'll be stuck with whatever you get. When diving into wide wheels/low offsets it REALLY helps to have full control of your alignment parameters....
Old 01-09-2013, 07:34 AM   #1661
mattdrake27
Member#: 242925
2006 STi
Steel Grey Mettalic
Good morning gentlemen. I am considering a new wheel set up. Currently I am on 17x8 Enkei PF01s +45 235/40r17.
Car: 06 STI
Suspension: H&R springs, assuming stock struts.
Fender mods: None
Want to run an XXR 530 with a deep concave look. Probably an 18x9 at least. Any suggestions on offset and what kind of fender mods ill need. I also apologize. I'm a wheel/suspension noob. Thanks.
mattdrake27 is offline   Reply With Quote
Old 01-09-2013, 08:02 AM   #1662
cuztomimportz
Member#: 97904
Car: 06 STI
Fender mods: None
XXR 530's come in 18x8.75 not 18x9. That said, you will probably want the 18x8.75 +35 or +20. Both have the exact same concave face but the 20's will poke a lot more than the 35's and be harder to fit. For tires you should go with 245/40-18's. They fit that wheel perfectly. You will definitely need to roll all the fenders and probably pull at least the rears possibly the fronts since you are on lowering springs. You will also need some camber bolts or plates and probably about -1 to -2 degrees.
cuztomimportz is offline   Reply With Quote
Old 01-09-2013, 08:58 AM   #1663
mattdrake27
Member#: 242925
2006 STi
Steel Grey Mettalic
Thanks for the quick reply and information. I will def look into preparing for this possible set up.
Old 01-10-2013, 08:13 AM   #1664
zolaman
Member#: 299059
12 WRX hatchback
I'm planning on getting xxr 522 18.9.5 +38 on 2012 subaru wrx hatch. I believe I need to get rear fender rolled but can I run these on stock suspension and alightment?
zolaman is offline   Reply With Quote
Old 01-10-2013, 10:40 AM   #1665
sc00by4life
Member#: 97135
You haven't researched at all. You haven't provide enough information.
And obligatory you have a brand new car and want to put <$500 junk wheels on it.
Old 01-10-2013, 11:50 AM   #1666
meifert
Member#: 301676
2009 Forester XT
Good point. why wreck you car when they fail?
meifert is offline   Reply With Quote
Old 01-10-2013, 12:16 PM   #1667
ChrizTi
Member#: 278547
2005 STi
^^ they're right. Do some research before buying. I personally never had XXR wheels, but friends of mine have had. And I didn't hear nothing but complaints.
IMO buy a GOOD set of wheels for your car. You can find great deals of used wheels in perfect conditions here. wheels that are made for our cars. With the right offset. Avoid wheels with low offset. Those are wheels made for Evos.
And if your planning to upgrade the suspension, also get good stuff.
Brotha treat your new ride good. If it was a clunker I wouldn't have said nothing. Good luck.
ChrizTi is offline   Reply With Quote
Old 01-10-2013, 08:31 PM   #1668
lolsteven
Member#: 336500
I've been looking around for some rims and a spec came up in particular that threw it off for me. How is the fitment if it were 18x10 +30? I heard that anything above 8 width would be difficult to pull off, but what if the offset was 30? What kind of fender mods would be required?
lolsteven is offline   Reply With Quote
Old 01-10-2013, 09:05 PM   #1669
sc00by4life
Member#: 97135
lots. try searching.
if you are new to wheel fitment, that will be difficult for you.
Old 01-10-2013, 09:23 PM   #1670
Digital Dillon
Member#: 288727
2008 WRX premium
Tons of pulling, stretched tires, lots of poke, and about -4 camber or more.
Think hellaflush, slammed, stanced.
Old 01-10-2013, 09:43 PM   #1671
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
nice photo
JokerGT is offline   Reply With Quote
Old 01-10-2013, 10:43 PM   #1672
zolaman
Member#: 299059
12 WRX hatchback
Currently I have volks te37 18x7.5 +44 on 215/35/18 painted tiffany blue.
I don't like the width and the tires are too thin....... I was thinking about selling these and get the xxrs. Or better off can someone tell me what I should do to make my car sexier?
Old 01-10-2013, 11:15 PM   #1673
sc00by4life
Member#: 97135
are you ****ing kidding?
going from Volk...one of the most respected wheel manufacturers, to the VERY VERY VERY bottom of the barrel **** ass XXR's?
Give me your volks. I'll pay for shipping. You dont deserve them.
Old 01-10-2013, 11:16 PM   #1674
B1Ad3
Member#: 311829
My cars low but its not tucking.
The wheels on this car are 18x9 but im unsure of the offset, possibly a +27? This is what im after.
Old 01-10-2013, 11:42 PM   #1675
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
If you want to keep legit wheels, I've got a set of Rays Gramlights up for sale in the classifieds. 18x8.5+48 with 235/35 summer tires on them. You get essentially the same brand, a wider wheel, and more tire. The fitment is perfect for any 5x100 Subaru.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
