Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 12-29-2012, 05:24 AM   #51
Lrn2Corner
Member#: 246224
2012 WRX Sedan
12 Rav4 V6
The whine has been there since day one and for me is only noticeable during hard acceleration. It was really noticeable during AutoX due to never getting past 2nd gear. It is normal.
as someone explained earlier they beefed up 1st and 2nd gear and gave them a straighter cut which in turn causes the noise.
Lets hope this dealer is not trying to pull one over on you.
Lrn2Corner is offline   Reply With Quote
Old 12-29-2012, 05:34 AM   #52
CrazyOC949
Member#: 330460
2012 WRX Hatch
The way I see it, I get a free rental car and I'm not putting miles on my car. It's all covered under warranty.
CrazyOC949 is offline   Reply With Quote
Old 12-31-2012, 04:32 PM   #53
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Seems like normal gear mesh noise to me. Every Jeep transfer case I've heard in 4 Lo has a whine to it as well, and that's chain driven. A gear driven transfer case is going to make some noise, especially at high rpm's.
dcorn is offline   Reply With Quote
Old 12-31-2012, 04:48 PM   #54
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
You've heard the OP's transmission then I assume? If not I don't see how it seems normal if you can't hear it. So many people are convinced it is the normal whine without ever hearing the possible noise in the first place.
SenorDucK is offline   Reply With Quote
Old 12-31-2012, 04:59 PM   #55
CrazyOC949
Member#: 330460
2012 WRX Hatch
Went in today and took a pic of the gears. To me it looks like all the gears are helical cut. Except reverse of course. What do you all think?
http://m1296.photobucket.com/albumvi...l?o=1&newest=1
Old 12-31-2012, 06:38 PM   #56
killeraxemannic
Member#: 322111
2012 Base WRX
Dark Grey
Those look better than mine did. Don't see any difference between those and mine with the way they are made. I don't notice any wine in my car though.
killeraxemannic is offline   Reply With Quote
Old 01-01-2013, 01:02 AM   #57
Slurpyy08wrx
Member#: 256155
Didn't op say he has after market shift bushings? I do front and rear shift bushings and my 13 wrx "whines" some from 1-3 gear or the start of 3rd
Slurpyy08wrx is offline   Reply With Quote
Old 01-01-2013, 02:42 AM   #58
CrazyOC949
Member#: 330460
2012 WRX Hatch
Right, but my car wines from 1-2 and even before I did the shifter bushings.
Old 01-01-2013, 02:56 AM   #59
Slurpyy08wrx
Member#: 256155
Mine did slightly as well, but I can't hear it anymore since stage 2 only when I was stock completely
Old 01-01-2013, 02:56 AM   #60
Slurpyy08wrx
Member#: 256155
Idk stop worrying I'm stage 2 in my 13 wrx with 5k miles something goes wrong? Ill cross that bridge when I get to it.
Old 01-01-2013, 03:50 AM   #61
CrazyOC949
Member#: 330460
2012 WRX Hatch
That's good for you. I plan on going stage 2 soon also. But like I stated above, the car is already in the shop with the transmission torn apart at the moment.
Old 01-01-2013, 03:38 PM   #62
Slurpyy08wrx
Member#: 256155
I see, hope your **** gets worked out.
Old 01-01-2013, 08:17 PM   #63
CrazyOC949
Member#: 330460
2012 WRX Hatch
Thanks, I hope so too
Old 01-02-2013, 09:14 AM   #64
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Helical gears are definitely quieter than straight cut gears, but still make noise. Check out a car with a centrifugal supercharger. I've had two different Vortechs, one with straight cut gears (V1) and one with helical (V2). The straight cut were much louder, but the helical still had a decent whistle to it. The noise is a little more extreme because the gears are spinning really damn fast, but the same factors apply.
The 'normal whine' is pretty damn loud if you compare it to a rwd or fwd car.
And the OP asked for people's opinions about a problem he was having, so we're giving them based on our personal experience. That's how a forum works. So go chastise people somewhere else.
So did both WRX's I test drove. So did mine, from the day I bought it, especially under hard acceleration.
Old 01-02-2013, 11:15 AM   #65
SenorDucK
Member#: 327511
13' WRX 6 Speed
I know how a forum works.
I suppose I take things literally as they are written. I understand the difference of suggestion and what the majority of these replies are. Half the thread is guaranteeing that it's normal without ever hearing it! A better reply would carry a disclaimer of "...but I can't hear how loud your particular case actually is, so maybe it actually is bad..."
maybe I give people too much credit? I assume that most people bothering to make a thread about gear whine after reading threads on it being common may actually be concerned theirs is different.
Sorry to to rub you the wrong way.
Old 01-02-2013, 09:21 PM   #66
RVA_Ninja
Member#: 318219
2012 Impreza WRX
Obsidian Black Pearl
Originally Posted by WRBoxer11 View Post
1st and 2nd gear whine because racecar.
RVA_Ninja is offline   Reply With Quote
Old 01-03-2013, 09:10 PM   #67
CrazyOC949
Member#: 330460
2012 WRX Hatch
Update
Main shaft came in today. Hopefully my car will be ready by tomorrow or Saturday. Irvine Subaru said they are going to be doing transmission bushings also. All under warranty.
Old 01-08-2013, 05:39 PM   #68
CrazyOC949
Member#: 330460
2012 WRX Hatch
Update
Spoke to Bryan at Irvine Subaru. He stated that they had a problem with one of the gears. He also said that my car should be done tomorrow. Well I called them yesterday and he said that they were just going o finish up today, that everything was already set to be put back in the car. He stated that it would be done today. We shall see what happens tomorrow. Thanks for all your responses. I am eager to hear what they will tell me next.
Old 01-08-2013, 10:11 PM   #69
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
im betting the car sounds the same when you get it back.
gsrcrxsi is offline   Reply With Quote
Old 01-09-2013, 02:46 PM   #70
CrazyOC949
Member#: 330460
2012 WRX Hatch
Update
Just got a call from Brian at irvine Subaru. My car is "ready". I'm eager to hear how it runs now.
Old 01-09-2013, 02:56 PM   #71
RoadKillDMD
Member#: 284792
2011 STI
Blurple
RoadKillDMD is offline   Reply With Quote
Old 01-09-2013, 02:57 PM   #72
Rex_BoostNY
Member#: 220306
2015 WRX Limited
Derp
+1, very common whine with subarus. If its same whine most of us are thinking it is...its normal. You'll come to know and love how noisy our cars are eventually lol
Rex_BoostNY is offline   Reply With Quote
Old 01-09-2013, 04:46 PM   #73
CrazyOC949
Member#: 330460
2012 WRX Hatch
Final update!!!!
Guess what?? The tranny still whines, but not as loud as before. It is way quieter. And yes my aftermarket front and rear shifter bushings are still on. Thanks for everyone that posted on here.
Old 01-09-2013, 04:53 PM   #74
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Before and after video.....?
blehhh is offline   Reply With Quote
Old 01-09-2013, 05:01 PM   #75
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Being 'not new' to the internet or forums, I'm very surprised you would give people that much credit lol. I'm just used to jeep forum where there is a post a day about "what lift should I get?" or "can I run XX" tires on a XX" lift?" without reading the 40 threads below theirs that answer the same question. This guy just took it to the extreme by doing little research and taking the car straight to the dealership.
