Old 10-15-2012, 11:48 PM   #51
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Someone got their hands on an EFR 9180 with ewg ts hotside!
06rexwagon is offline   Reply With Quote
Old 10-16-2012, 12:06 AM   #52
SharpTuning
Member#: 333363
Awesome! Can't wait to see some plots of this turbo. I'm hoping its available for my next build.
SharpTuning is offline   Reply With Quote
Old 11-02-2012, 03:19 PM   #53
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
just stuck slightly toward 1st. I'll need to press the gears off again to see what the problem is.
Sorry a bit off topic but it seems you do your own trans work? ie replacing synchros, do you have special tools like synchro protective rings to remove/install, etc?
I have some issues with 3/4 synchros due to drag duty and would love to do the work myself.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 11-02-2012, 04:07 PM   #54
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
pm me some info on the bensons sleeves!!! like cost and what you think about them. I might be sleeving another block soon.
Old 11-05-2012, 05:43 PM   #55
06rexwagon
Member#: 114730
[email protected]
I take the transmission apart and take the gear sets to a local shop that my buddy runs. They do the pressing off of the gears and such because I don't have the tools to do it.
Old 11-08-2012, 01:31 AM   #56
Half Crazed
Member#: 321842
2008 STi
Damn, that was quick.
Half Crazed is offline   Reply With Quote
Old 11-14-2012, 10:28 AM   #57
ScoobySubyDoo
Member#: 329311
Satin Black
WOW, at 5400 feet too.
ScoobySubyDoo is offline   Reply With Quote
Old 11-14-2012, 01:55 PM   #58
eg33GC
Member#: 206851
56 Belair
Pro Street
knock that 60 down!
Old 11-14-2012, 04:29 PM   #59
MRF582
Member#: 48219
. Always drive
the race line .
The wrist pin worked out far enough to drag along the cylinder wall which was the probable cause of the bearing failure.
Any idea on why the circlip came off? Any chance it was compressed too much during assembly?
MRF582 is offline   Reply With Quote
Old 11-14-2012, 04:53 PM   #60
06rexwagon
Member#: 114730
[email protected]
I'm honestly not sure. The engine ran for 13-14k miles without being torn down (other than removing the heads once for larger valves) so I would have expected it to come out sooner. I made dozens of drag passes on that block.
Old 11-14-2012, 05:01 PM   #61
06rexwagon
Member#: 114730
[email protected]
Originally Posted by eg33GC View Post
knock that 60 down!
I've cut a handful of 1.63 and 1.64 60's but always miss a shift or the clutch gave out. One of these days I'll match the right shifting with a decent 60'.
Old 01-08-2013, 09:02 PM   #62
06rexwagon
Member#: 114730
[email protected]
Breaking in new sleeved motor and added a new Treadstone fmic.
Currently the fastest and highest hp subaru in NM.
I'll dyno on the old 9179 and then throw on the efr9180.
Old 01-08-2013, 10:53 PM   #63
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
The benson block is treating you well??
Old 01-08-2013, 11:03 PM   #64
06rexwagon
Member#: 114730
[email protected]
Had some issues the first time around but he took care of it. He's been great to deal with.
I did have to take it down and replace the bearings and crank because of a decking issue that led to the pistons tapping the heads on one side of the block only.
Old 01-08-2013, 11:17 PM   #65
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Damn that sucks. I think that's who I'm going to have do my block if the current sleeved one doesn't work.
Old 01-08-2013, 11:26 PM   #66
06rexwagon
Member#: 114730
[email protected]
Is yours running yet?
Old 01-08-2013, 11:33 PM   #67
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Nope. Valves shipped from swaintech a few days ago and Moore performance is almost done with ts header and up pipe.
So just need fuel cell and big Weldon pump and 2 44mm wastegates and I'm ready.
Old 01-08-2013, 11:45 PM   #68
06rexwagon
Member#: 114730
[email protected]
What turbo?
Old 01-09-2013, 12:29 AM   #69
bestfromnw
Member#: 281835
2008 STI
1990 mk2 GLi vdub
great run
bestfromnw is offline   Reply With Quote
Old 01-09-2013, 03:17 AM   #70
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
What turbo?
Borg Warner 67mm fmw
Old 01-20-2013, 01:08 PM   #71
06rexwagon
Member#: 114730
[email protected]
The car is back and running stronger than ever. Was only able to run 28psi on the dyno because one of my 044's died but it made more power at 28 psi than it did at 34psi last year. The efr9180 is bolted on and add soon as the new pump gets here I will head back to the dyno.
Old 01-20-2013, 01:12 PM   #72
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Hell ya man! Well what did it do at 28 psi and when does new pump come in!?
Old 01-20-2013, 01:27 PM   #73
06rexwagon
Member#: 114730
[email protected]
632 uncorrected. New pump will be here Wednesday.
Old 01-20-2013, 01:31 PM   #74
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Wow that's really serious power!! Do you remember about what it was picking up per psi of boost?
28 to 34 is 6 psi if I added correctly!!
If you pick up say 10 hp per pound that's
692.
Old 01-20-2013, 01:49 PM   #75
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Its an extra $1700 through MPS with upgraded case bolts and all machining done (line bore)
FS/FT: Version 4 JDM WRX wagon with a ton of mods martystoked Private Vehicle 'For Sale' Classifieds 7 04-02-2010 12:29 AM
F/S NC 04 WRX Wagon 10,900 OBO 118k miles ajwrxwgn Private Vehicle 'For Sale' Classifieds 0 08-05-2008 09:43 PM
testing waters 4 sale WRX Wagon 03 beachbear Private Vehicle 'For Sale' Classifieds 4 01-24-2004 10:57 PM
1/4 mile- when to shift into 4th? Br0kWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-22-2002 08:16 PM
Nice WRX wagon in my parking lot at work... Layman Mid Atlantic Impreza Club -- MAIC 2 06-15-2001 11:26 AM
