Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 10-11-2012, 11:47 PM   #276
sc00by4life
Member#: 97135
Originally Posted by rocketperson7
unless it's speed density
:stirpot:
Or a MAP based system.
sc00by4life is online now   Reply With Quote
Old 10-11-2012, 11:48 PM   #277
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Thank you !! Haha
tjmmason93 is online now   Reply With Quote
Old 10-11-2012, 11:51 PM   #278
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Originally Posted by tjmmason93 View Post
Why isn't it tuneable ? I was always under the impression you can drop the fuel tables to control the amount of fuel and air pumped in through the car to safely get away from the half second rich moment after spool ?
The rich swing is after shifting, not after spool. There is no table to dynamically adjust fueling immediately after releasing the throttle, because the stock setup uses a BPV, so there is no need for that table.
Old 10-11-2012, 11:52 PM   #279
Member#: 51961
2005 STi
2012 WRX
That's what speed density is...or are you referring to something else?
Blow through can use an atmo BOV as well without any negative consequences.
Old 10-20-2012, 04:00 PM   #280
deXter90
Member#: 285515
2011 wrx sedan
black
ok i wa reading previous posts but couldn't find what i was looking for. i'm running a stock turbo on a 2010 wrx, with a perrin front mount and a injen intake. Would i be better off keeping the BOV i have, or should i upgrade it? I'm also going to get a tune after i install the FMIC.
deXter90 is offline   Reply With Quote
Old 11-10-2012, 10:26 AM   #281
shad0vvfax
Member#: 337163
2002 Subaru WRX
Default Greddy BOV question
I purchased a 02 wrx and it had a Greddy BOV on it. I notice that the car seems to run kind of poor until the turbo kicks in, almost like it has no get up and go. I do not have the stock recirc valve, but I noticed some of these BOVs can be used as recirc valves also. Can anyone give me any advice on this. If this is the case, can you describe to me how to hook it up as a recirc valve?
Also, if you have a cold air intake with a BOV, does this maybe even out the air/fuel ratio that the BOV is messing with. By adding more air, does it even out the fuel delivery. I have a full AEM cold air into the fender well.
shad0vvfax is offline   Reply With Quote
Old 11-10-2012, 10:37 AM   #282
Riz98
Member#: 329344
2006 Sti
http://forums.nasioc.com/forums/show....php?t=1602235
This will answer all your questions. The search feature on this site is very useful and will most likely answer any question you will come up with.
Riz98 is offline   Reply With Quote
Old 11-10-2012, 01:15 PM   #283
Member#: 51961
2005 STi
2012 WRX
Those BOVs have attachments that let you pipe the ventilated air into a hose, which you can then run to the post-MAF intake. Chances are your problem lies elsewhere though.
No.
Old 11-10-2012, 01:16 PM   #284
sc00by4life
Member#: 97135
they do not cause the same issue......
Old 11-11-2012, 04:33 PM   #285
shad0vvfax
Member#: 337163
2002 Subaru WRX
Yea, that did not help one bit, no offense. I asked how to hook up my Greddy BOV as a recirc valve, if it is possible that is. I also asked if my CAI would even out the extra fuel being dumped from my BOV as it is. Sometimes the stuff you search just does not answer the question you need answered.
Old 11-29-2012, 11:54 PM   #286
smurf juice
Member#: 338563
2009 wrx
wrb
I have a newbie question. I saw some bov's online that say they are sequential, what does that mean? Sorry for the stupid question.
smurf juice is offline   Reply With Quote
Old 11-30-2012, 12:27 AM   #287
sc00by4life
Member#: 97135
They have a primary and secondary valve to make sure the right amount of air is being released.
Old 11-30-2012, 10:56 AM   #288
Member#: 51961
2005 STi
2012 WRX
If you're talking about the HKS SSQV, skip it. It's known to leak, a lot.
Old 12-25-2012, 04:40 PM   #289
deXter90
Member#: 285515
2011 wrx sedan
black
running a stock turbo with a injen intake and perrin fmic looking into this BOV not sure if the right one to buy figured ill ask someone with more knowledge then messing something up .http://www.eurosportdesign.com/p-210...ating-bov.aspx
Old 12-25-2012, 08:53 PM   #290
sc00by4life
Member#: 97135
Your mod path has gone way off course. Forget about a bov. Ditch the intake. Pick up an AP/down pipe combo.
Old 01-08-2013, 06:30 PM   #291
KCWRX KU MED
Member#: 342982
Default This was very informative
thanks so much
KCWRX KU MED is offline   Reply With Quote
Old 01-08-2013, 11:47 PM   #292
mikey-WRX
Member#: 342915
2013 WRX Premium 4D
WR Blue Pearl
Impreza WRX's are recirculating bov? Did I read the original post correct saying running a atmospheric bov is safe? Pretty sure I misread that...
mikey-WRX is offline   Reply With Quote
Old 01-09-2013, 12:12 AM   #293
sc00by4life
Member#: 97135
technically its a bypass valve because it is fully recirculating.
is it safe? well its not "un safe", but it will most likely make your car run like ****. it wont blow up, but it'll suck to drive.
is the noise worth that?
Old 01-09-2013, 09:24 AM   #294
mikey-WRX
Member#: 342915
2013 WRX Premium 4D
WR Blue Pearl
Nope. I was just curious on what the first post mentioned. My VR4 is recirculating and I keep it like that. Running a open (atmospheric) BOV makes the 3000gt's run pig rich and I always kept my VR recirculating. Didn't want to have to throttle bump every second when I am at a light.
Old 03-14-2013, 02:41 PM   #295
kuntryquest
Member#: 278027
2005 Legacy GT
Pearl
How does on tell if they have a bad/weak Bypass valve?
kuntryquest is offline   Reply With Quote
Old 03-14-2013, 09:54 PM   #296
Dgwinner15
Member#: 348143
Love this thread. So if I go stage 2 sti with cobb accessport, short ram and downpipe. I'm safe staying stock bov and better off.
Dgwinner15 is offline   Reply With Quote
Old 03-16-2013, 10:12 AM   #297
chrisp0192
Member#: 350191
2003 WRX
Sonic yellow
this is a crap ton of good information all in one place
chrisp0192 is offline   Reply With Quote
Old 03-16-2013, 03:50 PM   #298
Roxxwell
Member#: 350378
SSM
Great thread!
Roxxwell is offline   Reply With Quote
Old 04-12-2013, 07:41 PM   #299
LOfrenemiesVE
Member#: 329014
2005 WRX STI
Please help.
Just got my car diagnosed. Was told my blow off valve was not recirculating. What should I do to?
Should I get the re-circulation kit? Or just buy a new bov/bpv completely? Or was told another way to go was go back to stock bov/bpv? Also, if I do have to buy one, either the kit/new, where can I buy them from? Base prices? Note: Forgot to say that my car came with a Blitz BOV when I bought it. I have not modified anything on the car.
I am more concerned in the health and longevity of my 2005 sti, more than mods at the moment until I can actually afford to lightly modify. PM me or post reply here.
Thanks,
Tam <3
LOfrenemiesVE is offline   Reply With Quote
Old 04-12-2013, 08:24 PM   #300
Member#: 51961
2005 STi
2012 WRX
Originally Posted by LOfrenemiesVE View Post
Please help.
Thanks,
Tam <3
Go back to the stock one. You can typically picked one up on the classifieds here for ~$20-30. It's going to be the cheapest, easiest, and best solution.
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 373 Yesterday 09:41 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 311 04-07-2015 09:11 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 290 12-20-2014 02:11 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 108 01-25-2014 01:28 AM
