Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Vendor Classifieds
Old 11-12-2012, 01:12 PM   #1
IAG Performance
Vendor Sales Rating: (62)
Member#: 158123
Default IAG Performance Service Thread & Current Specials!
Updates/Announcements:
-Currently running intro specials on Competition Clutch: We have recently started carrying the Comp Clutch lineup - PM or call us for install packages on all of their clutch and flywheel setups.
About Us:
IAG Performance is a complete performance & service center, able to take on the smallest or largest projects. At IAG, we are very familiar with the entire Subaru line of vehicles and you can feel comfortable knowing your STI, WRX, Forester XT, Legacy GT, or naturally aspirated Subaru is in good hands while work is performed. Our customers' satisfaction and comfort during service is our number one priority! We are not about inflated service tickets or one time visits... At IAG, we hope to build long-term relationships that last a lifetime!
A quick shot of our showroom:
IAG Performance Subaru Scheduled Maintenance Services
30,000 & 90,000 Mile Service - $399
-Oil change using your choice of Motul, Eneos or Valvoline Synthetics
-K&N or Purolator Pure One Oil Filter & new drain plug washer
-Replace Transmission Fluid w/ Motul 75w90 (Motul Gear300, Extra-S, and other fluids available upon request)
-Replace Differential Fluid w/ Motul 75w90 (WRX) or Motul PA 90 (STi)
-Coolant flush and inspect cooling system, hoses and connections. Global coolant w/ 1 bottle of Motul MoCool
-Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter)
-Flush & replace brake fluid w/ your choice of Ate SuperBlue or Motul DOT 5.1
-Inspect brake pads and rotors
-Inspect brake lines and check operation of parking brake
-Inspect Front & Rear axle boots and axle shaft joint portions
-Inspect clutch operation
-Inspect Steering & Suspension
-Inspect tires & rotate
-PCV Valve
-Top-off all fluids
-Replace fuel filter (vehicles vary) and inspect fuel system
60,000 Mile Service - $499
-All services performed in 30K Service
-Change spark plugs
105,000 Mile Service - $899
-Replace Timing belt
-Replace water pump & water pump gasket
-Replace thermostat & thermostat gasket
-Flush coolant & inspect cooling system. Global coolant w/ 1 bottle of Red Line Water Wetter or Motul MoCool
-Crank Seal
-A/C & P/S Belts
-Cam Seals
-Timing belt tensioner
Timing Belt/Water Pump Service Only - $499
Brake Packages
Stage 1
Hawk HPS Front/Rear Pads
Techna-Fit SS brake lines
Motul DOT 5.1 or Ate SuperBlue
WRX - $499 Installed
STi - $549 Installed
Prices vary - Also available for other Subaru models - Call/PM for details and pricing!
Stage 2
Techna-Fit SS Brake Lines
DBA 4000 Series Slotted Rotors
WRX - $1049 Installed
STi - $1199 Installed
Prices Vary - Also available for other Subaru models - Call/PM for details and pricing!
Suspension Services
Alignment/Corner Balancing
Performance Alignment - $99
Performance Alignment & Corner Balancing - $199
Install Springs/Coilovers (purchased @ IAG) w/ Performance Alignment - $299
Install Customer supplied springs & alignment - $349
Install Customer supplied coilovers & alignment - $399
*Coilover installation includes initial ride-height set-up. Additional changes to ride height are extra. Alignments are subject to additional charges for extra time (seized bolts/hardware, extreme fitment/aggressive set-ups, etc.)
Fender Rolling Services
CALL FOR DETAILS!
Guideline for our basic pricing can be found here:
http://www.iagperformance.com/fender...g_service.html
Fender rolling service pricing may vary depending on vehicle/extent of service - Call/PM for details and scheduling info!
Transmission Services
Exedy Clutch Specials
Exedy Stage 1 clutch package – w/ resurfaced flywheel & Motul or Eneos 75w90 fluid
02-05 WRX/04-05 FXT - $899 Installed
06+ WRX/FXT - $949 Installed
STi/SpecB - $999 Installed
Exedy Twin-Plate clutch package w/ performance flywheel & Motul or Eneos 75w90 fluid
WRX/FXT/LGT - $1999 Installed
STi/SpecB - $2099 Installed
ACT Clutch Specials
2002-2005 WRX/04-05 FXT Specials
-ACT Heavy-Duty Modified Street Clutch, resurface factory flywheel & choice of fluid
- $1049 Installed with your choice of fluids!!!
-ACT 6-Puck Sprung Clutch, resurface factory flywheel - $1019 Installed with your choice of fluids!!!
06-12 WRX Specials
- $1149 Installed with your choice of fluids!!!
-ACT 6-Puck Sprung Clutch, resurface factory flywheel & choice of fluid - $1029 Installed with your choice of fluids!!!
05-07 Legacy GT Special (includes flywheel)
-ACT Heavy-Duty Modified Street Clutch with your choice of ACT Streetlite or Subaru OE 06-07 WRX Flywheel & choice of fluids
- $1399 Installed with your choice of fluids!!!
-ACT 6-Puck Sprung Clutch with your choice of ACT Streetlite or Subaru OE 06-07 WRX Flywheel & choice of fluids - $1379 Installed with your choice of fluids!!!
04+ STI/07-09 Legacy SpecB Specials
-ACT Heavy-Duty Modified Street Clutch with resurfaced flywheel for 6-Speed & choice of fluids
- $1249 Installed with your choice of fluids!!!
-ACT 6-Puck Sprung Clutch with resurfaced flywheel for 6-Speed & choice of fluids - $1199 Installed with your choice of fluids!!!
Other Clutches
Other clutch purchased @ IAG installation prices (includes resurfacing flywheel and choice of synthetic transmission fluid)
WRX - $399
STi - $499
Install customer supplied clutch (includes resurfacing flywheel and choice of synthetic transmission fluid)
WRX - $499
STi - $549
Other Options & Add-Ons:
-Add Techna-Fit SS Clutch Line & Install to any clutch package: $50 parts & labor
-Add TSK (Transmission Sleeve Kit) to any transmission install for $
(See HERE for additional information on the TSK Kit)
Appearance Services & Window Tint
Window Tinting @ IAG Performance
Our window tinter has been in the business for over 15 years, and does an absolutely incredible job. We offer Johnson high quality window films, available in shades from MD legal all the way to limo dark.
Our tinting services come with a lifetime warranty against bubbling, peeling, fading, purpling, hazing, & more.
If you're looking for high-quality tint for your Subaru, shoot us a PM or call at the shop any time!
Check out our selection of used parts on our website!
Be sure to check out our used-parts section! We have a good number of quality used parts in stock. We buy/sell used parts here regularly -- Shoot us a PM for more info!
http://iagperformance.com/shopping_c...es.php?cat=891
IAG Performance
1203 Baltimore Blvd.
Westminster, MD 21157
410-840-3555
sales@iagperformance.com
__________________
See our 100% positive vendor review thread
/ 410-840-3555 /
IAG Performance is offline   Reply With Quote
Old 11-15-2012, 10:40 PM   #2
Bluemachine
Member#: 302496
2013 WRX STI
just sent you a pm!
Bluemachine is online now   Reply With Quote
Old 11-19-2012, 08:50 AM   #3
dcorn
Member Sales Rating: (1)
Member#: 107573
2012 WRX hatch
Ice Silver
Can I get a quote for the following services (separately) please? All for a 2012 WRX 5-door
~40% window tint
basic rear fender roll
red taillight overlays
dcorn is offline   Reply With Quote
Old 11-19-2012, 12:35 PM   #4
IAG Performance
Member#: 158123
Originally Posted by Bluemachine View Post
just sent you a pm!
PM replied.
~40% window tint
Sure, PM Sent!
__________________
/ 410-840-3555 /
Old 12-08-2012, 07:59 PM   #5
3G SYNDICATE
Member#: 239927
2008 WRX Premium
DGM Sedan
Can I get a quote for the following services (separately) please? All for a 2008 WRX 4-door
replace fuel filter
replace spark plug
coolant flush
3G SYNDICATE is offline   Reply With Quote
Old 12-10-2012, 11:20 AM   #6
gaedikus
Member Sales Rating: (5)
Member#: 310254
04 Forester XT
Silver?
can i get a quote for replacing my valve cover gasket and spark plugs on an 04 STI? (i have the gaskets, plugs, RTV, rotella oil and oil filter if that helps the price)
gaedikus is offline   Reply With Quote
Old 12-10-2012, 12:29 PM   #7
IAG Performance
Member#: 158123
replace fuel filter
replace spark plug
coolant flush
Sending PM's now!
__________________
/ 410-840-3555 /
Old 12-12-2012, 11:13 AM   #8
phenryiv1
Member Sales Rating: (34)
Member#: 91212
2011 WRX 5DR
Any parts specials, brake pads, etc.?
Old 12-13-2012, 02:07 PM   #9
IAG Performance
Member#: 158123
PM Sent!
__________________
/ 410-840-3555 /
Old 12-13-2012, 02:20 PM   #10
phenryiv1
Member#: 91212
2011 WRX 5DR
Originally Posted by IAG Performance View Post
PM Sent!
Replied- thanks, Rick!
Old 12-13-2012, 10:15 PM   #11
siks6
Member#: 290516
2007 sti
blue
~40% window tint price please for a 2013 wrx sedan
siks6 is offline   Reply With Quote
Old 12-14-2012, 10:13 AM   #12
IAG Performance
Member#: 158123
$199 and we are currently offering 10% off for the holidays!
Rick
__________________
/ 410-840-3555 /
Old 12-19-2012, 05:27 PM   #13
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Rick
Can I get 10% off of my tint as well? My car is the silver 2012 WRX hatch in your body shop getting the rear bumper replaced
Old 12-20-2012, 11:09 AM   #14
IAG Performance
Member#: 158123
The $199 on your hatch is actually an already discounted price (hatches are $239 regular price). Give us a buzz if you have any other questions.
__________________
/ 410-840-3555 /
Old 12-20-2012, 12:54 PM   #15
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Ah, no worries then, thanks!
Old 01-07-2013, 01:14 PM   #16
theEZV
Member#: 324205
'13 WRX hatch
Do you guys install Koni inserts?
theEZV is online now   Reply With Quote
Old 01-07-2013, 03:14 PM   #17
phenryiv1
Member#: 91212
2011 WRX 5DR
They do (or at least used to, as I called them abotu the install on my '11 but I then did them myself). Konis are great on the '11+. I have them with STi springs and love them.
Old 01-09-2013, 12:05 AM   #18
admiral snackbar
Member Sales Rating: (6)
Member#: 272810
2005 FXT
pm sent
admiral snackbar is offline   Reply With Quote
Old 01-09-2013, 09:04 AM   #19
IAG Performance
Member#: 158123
PM replied.
Originally Posted by admiral snackbar View Post
pm sent
Replying right now!
Rick
__________________
/ 410-840-3555 /
Old 01-31-2013, 09:48 PM   #20
Viethoang
Member#: 334728
2005 Wrx
Do you guy rolling fender ??
Viethoang is offline   Reply With Quote
Old 01-31-2013, 09:53 PM   #21
slayer44wagon
Member#: 300834
03 wrx wagon
Yes they do^^^^^
slayer44wagon is offline   Reply With Quote
Old 02-01-2013, 02:46 PM   #22
IAG Performance
Member#: 158123
__________________
/ 410-840-3555 /
Old 02-03-2013, 12:16 AM   #23
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
PM sent!!
scobbie-ts is offline   Reply With Quote
Old 02-03-2013, 11:20 PM   #24
wutsup
Member#: 345838
2005 WRX
Hey IAG, I'm interested in the Stage 1 Brake Package, but my only concern is that I think all my rotors are warped. So, I'm not sure how that would work out. I would go for Stage 2, but that is way out of my price range.
wutsup is offline   Reply With Quote
Old 02-04-2013, 02:42 PM   #25
IAG Performance
Member#: 158123
Originally Posted by scobbie-ts View Post
PM sent!!
Replied!
We can check the rotors out, but obviously if they are a problem, I would recommend replacing - What year/model car do you have? Shoot me a PM or email and I'll see what we can do to help!
Rick
rick@iagperformance.com
__________________
/ 410-840-3555 /
Message Board Statistics All times are GMT -4. The time now is 01:29 PM.
