Old 01-08-2013, 09:30 PM   #1
rbkkennedy2000
Member#: 332067
1993 Impreza L awd
white
Default ej20 swap into 93 impreza L?
I am thinking about putting a jdm ej20 into my 93 impreza L and I have a few questions
!. what are the pros/cons of rebuilding my stock transmission and leaving it in vs. throwing in the turbo transmission?
2. Is it more cheapier to buy the whole front clip or just buy the engine, harness, and hood?
3. hom much of a bitch is it going to be to do the wiring?
4 if I just get the engine where can I find a harness?
rbkkennedy2000 is offline   Reply With Quote
Old 01-09-2013, 08:05 AM   #2
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
For starters all of your questions have been answered 1000 times on nasioc so be sure to use the search feature. Also be sure to proofread your posts especially since you are a noob on nasioc and are not going to get any respect to begin with.
!-rebuilding may be the same cost as buying a used turbo transmission but the wiring might be different.
2-Usually buying each piece is gonna be cheaper but will take longer
3-If you have to ask if wiring is hard you are better off not even trying.
4-a harness can be found in the classifieds on Nasioc but also many vendors sell wiring harnesses that are made for swapping in a turbo motor. They are about $600. Check out http://www.eastcoastswappers.com/main/
Good luck oh and you have a PM
King of Poop is online now   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 10:14 PM.
