Old 01-09-2013, 09:41 AM   #26
Cobb Tuning
Member#: 4803
Originally Posted by bluesonicboomae86 View Post
What gear were these runs done in? Knock looks good - you have two counts of feedback knock in second log (first line - rest is just holding the correction), but it looks like that is from mashing the throttle (which is normal noise).
Bill
Old 01-09-2013, 09:45 AM   #27
bluesonicboomae86
Member#: 284297
2011 Impreza STi
WR Blue
Bill
These were done in 4th gear, and yeah to be honest in the second log I slammed into gear and punched it hard and made the car jump a bit, lol a mistake on my part. I will do another today, if weather permits me to,l. If not ill keep easy on the throttle until the weather calms and everything is dry
bluesonicboomae86 is offline   Reply With Quote
Old 01-09-2013, 09:57 AM   #28
Cobb Tuning
Member#: 4803
Some underboosting in these logs (more so in the first one) - may be that your boost situation is temperature related if these logs were done in higher outside temps than previous logs. If not, then you may be able to run the normal wastegate version of this 91 map.
Bill
Old 01-09-2013, 11:50 AM   #29
bluesonicboomae86
Member#: 284297
2011 Impreza STi
WR Blue
Bill
Well I live in Houston and the first logs I did prior to the ones I did yesterday, it was chilly out here. The ones yesterday it was a bit warmer I think around 63 degrees. The first ones I think weather was in mid 40's
Old 01-10-2013, 10:04 AM   #30
Cobb Tuning
Member#: 4803
Then I would stick with the LWG for now until it warms up in spring unless the mid 40's temps were unusual for your area during winter.
Bill
Old 01-10-2013, 02:17 PM   #31
bluesonicboomae86
Member#: 284297
2011 Impreza STi
WR Blue
Bill
Lol it comes and goes all the time so it may be 80 today and tomorrow it will end up being 40 degrees. That's how Houston likes to be
Old 01-11-2013, 08:31 AM   #32
Cobb Tuning
Member#: 4803
Well, then I would stick with the LWG map for now until temps heat up more consistently. Better to underboost a little than overboost.
Bill
Old 01-20-2013, 09:20 PM   #33
bluesonicboomae86
Member#: 284297
2011 Impreza STi
WR Blue
Old 01-21-2013, 09:24 AM   #34
Cobb Tuning
Member#: 4803
Logs look fine.
Bill
