Closed Thread
Old 01-07-2013, 08:21 AM   #2351
79letour
Member#: 302570
2013 XV
DGM!
16 years ago I was building VW flat fours.
79letour is offline
Old 01-07-2013, 08:23 AM   #2352
79letour
Member#: 302570
2013 XV
DGM!
Originally Posted by M45 View Post
did oil change at 1800 miles. seems like I got a little over 5 qts out (tough to estimate since one of my waste containers was an empty washer fluid container). Put a little over 5 qts in. I'm about 1/4" over the dot as far as I can tell. *crossing fingers*
yeah that sounds like everything is good!
Putting in just over 5 quarts puts me 3/16 or so over "full".
79letour is offline
Old 01-07-2013, 08:27 AM   #2353
79letour
Member#: 302570
2013 XV
DGM!
Glad you did it yourself??
Imagine taking it in to a dealer and leaving with 6+ quarts and oil spilled all over the engine....
79letour is offline
Old 01-07-2013, 08:33 AM   #2354
M45
Member#: 333446
2013 Impreza SL CVT
no regrets yet. I ended up using ramps which made it easier.
M45 is offline
Old 01-07-2013, 08:57 AM   #2355
79letour
Member#: 302570
2013 XV
DGM!
I made some ramps at work. They are definitely needed.
79letour is offline
Old 01-07-2013, 01:17 PM   #2356
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
79, since you seem to have tools to work on cars, do you have a compression or leak down tester that you can use? I am REALLY curious to know what the root cause could possibly be.
ST Eye is offline
Old 01-07-2013, 02:24 PM   #2357
79letour
Member#: 302570
2013 XV
DGM!
I personally dont but yeah I have access to everything. Finding the time to do it is a bit tricky but I'm getting a shop manual for the car and depending on how the plugs look at 25k miles and if oil re-pools around the cam position sensor cover. Honestly SOA or a dealer should be going through all this hassle, though. Not me. I bought a brand new car.
79letour is offline
Old 01-07-2013, 03:16 PM   #2358
ST Eye
Member#: 73068
True, but you seem to be reluctant to deal with the dealer for things. That said, I would do it yourself in your free time if possible. Data points as a result of these tests should be pretty important.
ST Eye is offline
Old 01-07-2013, 04:26 PM   #2359
nubsub
Member#: 313575
2012 Impreza 2.0i HB
for me, just driving onto a pair of 2x6s was enough. (ie, 1.625" gave me enough clearance to get to the drainplug easily...amazing what just a little more height allows)
nubsub is offline
Old 01-07-2013, 05:29 PM   #2360
79letour
Member#: 302570
2013 XV
DGM!
Yeah.
I Have used some 2x10's before but the ramps are steel versions of rhino ramps i sorta copied.
You are quite right though. The average owner could just fold the rear seats down and head to home depot and have some boards cut down to size. An inch or so is a big improvement and makes it doable.
But I do love having the extra six or so inches of clearance. I tidy up the underside as best I can while the oil drains.
79letour is offline
Old 01-07-2013, 05:33 PM   #2361
79letour
Member#: 302570
2013 XV
DGM!
I will get it done one way or another in the summertime. Data IS good!
If I pull the plugs, and there are any red flags, I'll likely put new ones in and take the car and the plugs to a dealer in another county. Somewhere that deals in high volume.
Until then, just watching the dipstick and that cam sensor seal.
And the injectors. Cant figure out why they would be oily (slighly) and nothing around them is.
79letour is offline
Old 01-07-2013, 06:19 PM   #2362
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Could be leaky o rings. Fuel does leave an oily residue
flyboy1100 is offline
Old 01-07-2013, 11:32 PM   #2363
79letour
Member#: 302570
2013 XV
DGM!
Yeah i suppose.
79letour is offline
Old 01-09-2013, 07:47 AM   #2364
O0 Ia
Member#: 341604
2013 Impreza
What's your oil consumption?
According to wikipedia, it appears that Subaru expects 1 quart every 1200 miles to be normal.
http://en.wikipedia.org/wiki/List_of...baru_FB_engine
"The FB has a 10% increase in gas mileage with the power coming on sooner and the torque band being broader. Despite these advances compared to the EJ series, it is common and expected for these engines to consume up to a quart of oil every 1200 miles."
O0 Ia is offline
Old 01-09-2013, 08:04 AM   #2365
M45
Member#: 333446
2013 Impreza SL CVT
that just sounds like a CYA statement that subaru is putting out there.
M45 is offline
Old 01-09-2013, 08:24 AM   #2366
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I don't think Subaru authored that content. Regardless, I went into Wikipedia's editing mode and deleted that last sentence because it's untrue. It's not "expected" that the FB engine consume 1 qt of oil every 1200 miles. Some of them do so, but it's not expected, and I doubt that Subaru would claim that oil consumption is an expectation.
Oil consumption was an expectation with Mazda's rotary engine. It's not an expectation with the Subaru FB engine.
sgoldste01 is offline
Old 01-09-2013, 08:24 AM   #2367
Zeeper
Member#: 299286
2015 WRX CVT
wikipedia allows anyone to edit it, so take that with a grain of salt. Or two grains.
Actually it looks like that final sentence has already been removed from the site.
For all you know, someone here added that passage. Most people here do not have cars consuming oil.
Zeeper is offline
Old 01-09-2013, 08:42 AM   #2368
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I don't know who added that passage (it wasn't cited), but I'm the one who removed it.
Old 01-09-2013, 09:36 AM   #2369
M45
Member#: 333446
2013 Impreza SL CVT
perhaps not. similar things have happened in the past though.
either way I wasn't referring to the wiki article exactly but subaru does say something similar in the official literature which is what inspired it. the use of the word "expected" is probably incorrect as was mentioned though.
M45 is offline
Old 01-09-2013, 11:38 AM   #2370
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
The measuring of the oil every other day reveals that my oil consumption problem appears to be fixed! I am doing my 23K oil change in the morning, and it will be to the engine wash after that, since my dealer did not even clean the oil my camshaft sensors where leaking. Since they did not change the oil after replacing the sensors, all they did is fill up a little over the second line. It has not consumed oil. At least it appears to be a lot better than before. I will keep the board posted.
ZURCALED12 is offline
Old 01-09-2013, 12:41 PM   #2371
79letour
Member#: 302570
2013 XV
DGM!
Wekcome to the discussion, but yeah thats all been discussed ad infinitum. I'm currently burning quart in roughly 1700 miles. A certain new model of subaru/toyota is actually "allowed" to burn 1.1 quarts in 600 miles!!!! Cya lawyer statements.
Whoever wrote that wiki stuff shoukd edit it to say that oil consumption of up to 1.1 quarts in 1200 miles is considered to be acceptable to Subaru. Thats the TRUTH!!!!
79letour is offline
Old 01-09-2013, 12:45 PM   #2372
79letour
Member#: 302570
2013 XV
DGM!
Keep us posted,ZURCALED12. Glad youre looking like youre good to go.
I too have had to clean up after techs.
Well good luck, glad you're not stressed anymore about the engine.
79letour is offline
Old 01-09-2013, 12:50 PM   #2373
79letour
Member#: 302570
2013 XV
DGM!
Hmmmmmm....
I hadnt thought of adding any "data" to wikipedia. Thats a great idea, and yall know it would be CITED id I added it
I'm going to look into it.
79letour is offline
Old 01-09-2013, 01:03 PM   #2374
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Hmmmmmm....
I'm sure THAT would be unbiased content!
Old 01-10-2013, 11:50 AM   #2375
79letour
Member#: 302570
2013 XV
DGM!
Not about 2012's, but heres a more typical oil consumrption discussion. Less fanfare that on a manufacturer specific site. More or less shows the general feeling automotive forums typically show about the subject.
http://forums.motortrend.com/70/3865...tic/index.html
79letour is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
