Old 12-31-2012, 07:54 PM   #376
worksti
Member#: 117847
2005 Rotated DOM3XTR
460whp, 400wtq Pump Tune
Originally Posted by zakeswrx View Post
I don't think I've read any charts where someone had heads and cams done running the Dom 3.0xtr I'm thinking that will make a pretty decent increase in power
Dyno'd at 470whp with heads, cams, EWG 10cm, 3" Dom3XTR.
worksti is offline   Reply With Quote
Old 01-01-2013, 03:32 PM   #377
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
07 sti built shortblock meth tmic Dom 3xtr 2.4 8cm made [email protected] Then I added a txs fmic, 4bar map sensor and got a speed density retune on 26.5 and made 415/405. This turbo really comes alive past 22.
Old 01-01-2013, 09:20 PM   #378
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Lookin fwd to my results w/ my DOM 3.0xtr. Massive head work, Kelford 272's , Maxwell power destroked 2.5 long rod motor,running 110 oct
I'd be happy in the 400's somewhere.
sense of nature is offline   Reply With Quote
Old 01-01-2013, 09:42 PM   #379
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Great build
You should be in the 500's with that fuel/motor work.
jnorth85 is offline   Reply With Quote
Old 01-01-2013, 10:09 PM   #380
Slimsti
Member#: 155696
Depending on dyno you should easily be in the upper 400's
Old 01-02-2013, 01:37 AM   #381
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Results from any form of a 2.0 motor?
Old 01-02-2013, 03:04 AM   #382
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
http://youtu.be/qhe5N05zLgE
This video entertained me greatly. Awesome to see people getting such a kick out of the built monster process. Have fun out there
lancelucas is offline   Reply With Quote
Old 01-07-2013, 08:49 PM   #383
Slimsti
Member#: 155696
https://www.youtube.com/watch?v=Vyob...e_gdata_player
Quick highway pull on my dom [email protected] 415/405, nothing special just figured I'd share
Old 01-07-2013, 08:53 PM   #384
KurtP
Member#: 44836
1999 Fozzy
That video was annoying as ****.
KurtP is offline   Reply With Quote
Old 01-07-2013, 08:54 PM   #385
KurtP
Member#: 44836
1999 Fozzy
What cams did you go with and who did the heads?
Old 01-07-2013, 10:15 PM   #386
Slimsti
Member#: 155696
Kelford 264s. All the info is in the last 10 seconds of the vid
Old 01-08-2013, 07:48 PM   #387
thundercamel
Member#: 183360
2015 STi
CBS
Agreed.
thundercamel is offline   Reply With Quote
Old 01-08-2013, 08:18 PM   #388
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Ditto
Fierysun is offline   Reply With Quote
Old 01-08-2013, 08:36 PM   #389
KurtP
Member#: 44836
1999 Fozzy
yeah I found your build thread. Looks good. Why did you decide on the 264's over something like the 272's with as high as you are pulling? spool up?
Id be curious to see what the D3XTR twin scroll does, especially in lower gears and how fast it snaps back after a shift compared to the 10cm. I would think, in theory anyway, it would spool up like a 8cm but still pull like the 10cm?
Old 01-09-2013, 03:04 PM   #390
worksti
Member#: 117847
Larger Cams can act as an obstruction on turbo motors and generally aren't advised. Pistons and Heads are JE.
Old 01-09-2013, 06:33 PM   #391
KurtP
Member#: 44836
1999 Fozzy
That is absolutely un true.
They may alter the spool characteristics to a particular set up depending on overlap and duration, or may not yield full gains higher in the rev band because the turbo is too small, but they are absolutely not an obstruction.
I would argue that next to selecting the appropriate turbo charger for one's goals, cams are a close second.
Old 01-11-2013, 06:54 PM   #392
worksti
Member#: 117847
Regardless of your seemingly bigger is better argument, Kelford 264s are a good match for a Dom3xtr 10cm 3"... This is the Dyno Graph with JE Pistons / Heads on Methanol.
Old 01-11-2013, 07:11 PM   #393
jnorth85
Member#: 76785
SRP
What kind of boost is that on?
Old 01-11-2013, 08:11 PM   #394
KurtP
Member#: 44836
1999 Fozzy
im not knocking your set up. you have a good thing rolling. but you peaked at 6000ish and lost 70whp over the course of the next 1500rpm. imo its not enough cam for what you are pushing up top
Old 01-12-2013, 10:56 AM   #395
worksti
Member#: 117847
The Turbo peaked, need more lag (35R) to maintain power at high revs...
Old 01-12-2013, 10:57 AM   #396
worksti
Member#: 117847
23lbs Peak.
Old 01-12-2013, 11:49 AM   #397
jnorth85
Member#: 76785
SRP
23lbs Peak.
Barely in the efficiency range! Crank it up!
Old 01-12-2013, 01:36 PM   #398
worksti
Member#: 117847
Need some E85
Old 01-18-2013, 03:42 PM   #399
Slimsti
Member#: 155696
Here's a quick highway pull 60-115 on my dom 3xtr,8cm,2.4"@27psi
Does 60-110 in about 5 seconds
Old 01-19-2013, 12:26 PM   #400
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Default Dom 3.5XTR
On December 17th I was fortunate to have booked a time with Junior at PnL in Chicago to tune my new XTI build!
It's a new motor build with:
MPS Long Rod 2.5 SB
HP Techs in Detroit built D25 heads; CnC, PnP'd, Hand blended, Super Tech +1mm valve train, Kelford R199B, net 9.5/1 CR
Blouch 3.5XTR, 3"CH, 8cm HS, IWG welded shut
Killer B Holy Header with custom HP Techs, SL EWG up pipe
HP Techs custom built/ Cobb FXT V-banded 3" exhaust
Tial MVR EWG v-banded custom, SuperTrapp mufflered (can you say stealth) exhaust,
ETS TMIC w/ AEM IAT installed in front of the TB
AEM 3.5 bar MAP
Cobb SF intake with cold air box/ 4" ram air from bumper vent
Here are a couple graphs; 93 PG and E85, from my speed density tuning session with Junior at PnL! Junior held back on some timing because of balance issues with the DW 1100cc injectors I had installed at the time of tuning. My fueling system is working well with the Walbro 465, hi amp direct wired, Aeromotive FPR @50 psi and Perrin rails. We were at 80% IDC on E85 and my Blouch 3.5XTR.
I had DW 1100's older style injectors but they were new. I've got one that flows -12% off at 20 % IDC and it is causing fits at mosty lower rpm's but it's where you cruise and the hesitation stutter stuff 1500-3000 sucks big time on E85. It was not as bad on the PG but still there! DW made good on them, gave me an RA# and gave me some new EV14 1000's so that's good but a hassle!!! Junior did not want to push it any harder with the timing as he nor do I trusted the injectors.
Regardless my XTI made very good power even with conservative timing!
I now have ID 1K's and Junior revised the maps for the new injectors. I have been running some logs for him and we are still tweaking the tunes. The power curve is very flat all the way out to Junior's 7800 rpm red-line. It holds 21-22 psi on 93 and 26+ psi on E85 a the way to 7800 rpm. We will bump the rev limit as the motor is 8500 rpm capable and it seems to hold the power.
On one E85 log I saw 28.4 psi by 3640 rpm in 4th gear! That's 450 WTQ at 3600!!
On another E85 log in 3rd gear showed 12 psi of boost at 3500 and then 23 psi at 4000 building to 26 psi and holding that to red-line.
On 93 pump it makes 20 psi by 3700 and 21.5 by 4000 and holds it out to red-line!
I'm very happy with the build and especially the Dom 3.5XTR. I have heard people say the these bigger Blouch turbos are laggy! Laggy? I don't think so!! Do these graphs look laggy? My motor spools much faster on the street than what the dyno graphs show. I think that this build is very well balanced in the parts selection and execution, it breaths very well and the results show this!
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 10:58 PM
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 06-07-2010 12:04 AM
Dom 3.0XT-R and Dom 4.0XT-R Now Available Blouchturbo Engine/Power/Exhaust 17 02-04-2010 02:01 AM
Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts GTBGUY Normally Aspirated Powertrain 85 05-24-2001 07:33 AM
