Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 01-08-2013, 02:48 PM   #26
hoffmanEstates
Member#: 122043
04 wagonier
psm
Used you should find a decent cbe but new yeah
Good luck
hoffmanEstates is offline   Reply With Quote
Old 01-10-2013, 12:15 AM   #27
blk05wrx
Member#: 180559
2016 WRX STi Limited
You could find a used borla for $300. I've seen them on here. I think someone has an spt for sale now and thise sound good and are great quality. Since most aftermarket pieces are stainless you shouldn't have to worry about rust. After 8 winters mine is still great, even the connector like was mentioned earlier only has surface rust.
I have the adapter for the borla I never used. It's brand new, you can have it cheap if you buy a hush. You'll need it for almost any dp besides stock or cobb, which is what I have.
blk05wrx is offline   Reply With Quote
Old 01-10-2013, 05:15 PM   #28
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
So I need a special adapter, going from a 3in DP, to a 3in CBE? What sense does that make? How would they not mate up?
04scoobywrxwagon is offline   Reply With Quote
Old 01-10-2013, 06:08 PM   #29
hoffmanEstates
Member#: 122043
04 wagonier
psm
Typically a dp mates with a cbe. I run a Turboxs stealth back and a devil axle back, so if i want a thermal,hks,tanabe,ect....cbe i.need. a special midpipe adapter so i can run.them. Or if you run a jdm dp some of those are funky
Old 01-10-2013, 11:16 PM   #30
blk05wrx
Member#: 180559
No, most 3 in dp's and 3 in cbe will match up. The borla hush needs a 2.5 in. or 3 in. adapter depending on the dp. I just happen to have both but only used the 2.5 to match up to my cobb. Sorry for the confusion.
But, you should make sure your dp will mate up with your stock cbe if you plan on running that while you look for an aftermarket 3in cbe.
Old 01-11-2013, 05:59 PM   #31
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Ups just dropped off the invidia v3, today I'm going to wait til the cbe shows up(should be Monday) then ill have to wait til next weekend to put it on. Thanks a lot work. Pretty pumped to finally get some Subaru rumble though, I'm honestly not worried about hp numbers or how much faster the car will be, I just want the Subaru rumble for now, then if I feel like it (which I know I will) ill do other upgrades but for now ill be happy enough with full 3in exhaust(after turbo) I want to do up pipe too but I heard aftermarket up pipes make turbo spool real slow(late) maybe a used sti up pipe will be as much as ill do
Old 01-11-2013, 06:30 PM   #32
hoffmanEstates
Member#: 122043
04 wagonier
psm
Remember stay out of.boost as.much.as.possible and get a tune.ASAP.
Old 01-12-2013, 01:24 AM   #33
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Cobb AP...
Old 01-12-2013, 09:38 AM   #34
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Cobb AP...
......with a catless Invidia DP. Hope that isn't a CobbAP with an off the shelf map. Although an OTS map is better than no tune at all while you wait for a specific map, still drive cautiously if you must. Get a specific map from a reputable e-tuner or pro-tune by a reputable local tuner. Good luck, I'm sure you will be satisfied with the results.......and only a short matter of time before you are planning your next mods.
Not sure which cbe you purchased. But in regard to the Borla, it ships with the 2.5" adapter that will mate to the OEM dp or one of the OEM-like aftermarkets ones (i.e. Cobb). The reason some of us mentioned the 3" adapter is due to having to buy that separately (use it in place of the 2.5" adapter) when you are using a dp with the 3" outlet flange (i.e. Invidia).
Old 01-12-2013, 09:43 AM   #35
hoffmanEstates
Member#: 122043
04 wagonier
psm
6* (6 star in schaumburg) has a tuner i might have his contact info.
Old 01-12-2013, 03:29 PM   #36
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
6* is too far ill be going to ET Tuning cause that's decently close
Old 01-13-2013, 07:46 PM   #37
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
so i have the invidia v3 3in divorced dp here, the gimmick v3 vband cbe will be here tomorrow morning, i have a new rear 02 sensor, gaskets, dei wrap for the dp, and 3 kartboy long hangers for the gimmick muffler(wagons have crappy clearance i heard). Couple little questions, I hear that with a catless dp, the rear 02 sensor will still throw a code bc its now going to be measuring uncatted exhaust, theres a threaded extension I read about that you can thread into the DP then thread the new 02 sensor in.. worth it or a waste of time. Also, I plan on doing an uppipe soon due to the catted stock uppipe, i dont want the cat internals to break apart and EFF up the turbo fins(or worse). I was thinking an aftermarket up pipe,(suggestions?) which I will also DEI wrap, w/o 02 sensor bung then doing the 2.2Kohm resistor mod for the CEL. Is this a decent fix or are there better ways. I have a Cobb AP, I will obviously be putting on the stage 2 tune right after I get all the exhaust on, and I know it will be overall beneficial to get an actual tune from a shop (ill be going to ET Tuning(union, mo)) which is about an hour and a half away however I wont be able to go for a little while. Will the stage 2 tune from an AP be enough for now until I can get to ET Tuning?
Old 01-13-2013, 08:38 PM   #38
hoffmanEstates
Member#: 122043
04 wagonier
psm
Once.you go to get.tuned he.will.turn off all.unnecessary c.e.l
Old 01-13-2013, 09:10 PM   #39
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Ok sweet then ill deal with the cel til they take it off, I hate having a cel on so it'll bother the shiz out of me and motivate me to go get a proper tune sooner, will hitting any decent amount of boost before I get the tune hurt anything?
Old 01-13-2013, 10:49 PM   #40
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Don't hit any boost if possible it's not worth the risk.....
Shortpersonbk is offline   Reply With Quote
Old 01-14-2013, 07:56 AM   #41
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Forget the O2 sensor spacer and that EGT resistor. You have an AP. Install ATR and mask out the rear O2 and uppipe EGT related faults on the OTS Cobb map. Drive cautiously on the OTR map. I still highly suggest not putting off the actual tune.
Do the uppipe before the tune at that shop. Like mentioned before a good used STI, 2006-07 WRX uppipe, or any reputable aftermarket one will be fine. If it has a flex joint in it, do not overwrap that portion.
Old 01-20-2013, 09:26 PM   #42
hoffmanEstates
Member#: 122043
04 wagonier
psm
How's it running?
Old 01-21-2013, 11:31 AM   #43
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
Don't have the up pipe in yet, but with the invidia v3 divorced waste gated catless downpipe and the gimmick vband catback, it sounds great, runs great on the Cobb ap stage 2 tune. I have an exhaust leak at the vband connection and I've already tried messing with it but its still leaking, not sure what to do
Old 01-21-2013, 01:13 PM   #44
hoffmanEstates
Member#: 122043
04 wagonier
psm
Use gaskets? Pm me we can talk
Old 01-21-2013, 04:47 PM   #45
04scoobywrxwagon
Member#: 340432
2004 Wrx Wagon
I got sick of it and I'm up at a shop right now having them mate it up better then I can in the parking lot at my barracks, I'm tired of messing with it so they will get it fixed I never do this but I'm over it
