Old 12-26-2012, 09:50 PM   #1
scx89
Member#: 269388
2011 Impreza WRX
obp
Default Boost leak help -11 WRX
Mods are
Catback
COBB OTS stage 1
Boost gauge
Oil Pressure gauge
I was hitting boost on a fwy on ramp and I started noticing this weird noise - similar to a failed silent fart.
I just installed the defi boost gauge about a week ago and flashed to stage 1.
(was previously stage 2 w/DP but took that off)
Where does that boost leak sound like it's coming from? I hear it on the left front driver side - so I imagine it's the T connector. I have the T connected mounted about 2.5 inches after the BPV -> T --< Sender & whatever else it connects to lol. I checked the T connector today and it looks okay to me, I took off the crappy zip ties on the tubes and replaced it with 18lb tensile str zip ties but I'm still getting the noise.
Here's a video
I don't think it's the TB --> intercooler because I've had it on stage 2 before and it was all good at 17 psi. I'm only on 15psi w/OTS stg 1
If you look at the video, it rises up to almost 15, makes the fart, then drops to 10 and rises again, and farts and drops.
Any input is well appreciated..
scx89 is offline   Reply With Quote
Old 12-26-2012, 10:06 PM   #2
arrowscooby
Member#: 176615
??? sleeper
rex
check the bpv gasket, or check all your hoses again.
arrowscooby is offline   Reply With Quote
Old 12-26-2012, 10:13 PM   #3
stanrc
Member#: 266177
2006 MX-5
RED
Have you messed with the TMIC at all? Check the throttle body hose, each side has a rubber piece that is known to wear. My car was making that noise and this was what mine looked like:
Just take the pieces off each end of the throttle body hose and put it all back together nice and tight.
stanrc is offline   Reply With Quote
Old 12-26-2012, 10:22 PM   #4
scx89
Member#: 269388
2011 Impreza WRX
obp
awesome picture
Throttle body hose is the thick hoses that comes out of the intercooler right?
I just take it off and put it back together? o.0
Do I have to take off the intercooler to access the hoses?
Old 12-26-2012, 10:27 PM   #5
stanrc
Member#: 266177
2006 MX-5
RED
Yes, it is the one that connects on the driver side. You will most likely have to take the TMIC off to get to it, and unfortunately because of the position you can't really confirm if thats the problem until you take it off. But if its like me (and a few others on here) once you unbolt the TMIC, it will just slide right off because those rubber things have come lose or ripped.
If you have the stock TMIC, it should only take 30-45 minutes, and even thats being liberal with time. Take the intercooler off, you will see the throttle body hose, each end has the worm clamp and the rubber piece, just take the rubber piece out, then put it back together.
Old 12-27-2012, 12:38 AM   #6
scx89
Member#: 269388
2011 Impreza WRX
obp
The throttle body rubber hose connector was loose! just like you said stanrc!
I have a couple concluding questions at the end though
For those with a similar noise here are some pics for reference
When I took off the intercooler the rubber connector was stuck on the intercooler and I can also see the side of the throttle body hose coming off
I could tell from the white gooey looking thing on the TB hose
intercooler removal was easy - take off bracket bolts with 12mm and bpv with 11 or 10 mm i forgot. There werent any gaskets on the turbo->IC or IC->BPV so nothing to worry about there. Then you just yank it toward passenger side and it should come right out.
The End
I saw some oil where the BPV opening to the IC opening and also inside the TB hose
should i be concerned or is that normal just to grease stuff up?
Old 12-27-2012, 06:39 AM   #7
stanrc
Member#: 266177
2006 MX-5
RED
Glad that was the fix and great pictures. As for the oil, that is the usual blow by from these engines. That shouldn't be anything to worry about.
Old 01-10-2013, 10:01 AM   #8
matigas_TT
Member#: 322775
2012 WRX-4Dr
Hmmmm same problem im having...
matigas_TT is offline   Reply With Quote
Old 01-10-2013, 11:39 AM   #9
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
These are good pictures and a very common problem. Even at stock boost this can occur, but any increase in boost makes it much more likely. A bit of oil in these components is normal. I wouldn't worry about it, but maybe check it once in a while because that does look like a somewhat decent amount.
EVERY 08+ WRX should remove those rubber end caps from BOTH ends of the throttle body hose. You should also add a zip to to the vacuum line that goes from the top of the BPV to the back of the intake manifold. The nipple on the intake manifold does not have a barb and can easily slide off.
Old 01-10-2013, 12:37 PM   #10
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
I wonder when Subaru will finally make a production change to rectify this issue. It seems there are three common problems people have when increasing boost (they can even occur on stock cars as you noted)
1. Bypass Valve leaking
2. Plastic end tanks separating on the stock TMIC
3. This problem (throttle body/IC hose popping off)
Fortunately the TB/IC thing seems to be an easy fix. I will most likely follow your advice and remove those POS end caps. I will probably invest in some t-bolt clamps as well.
CO11WRX is offline   Reply With Quote
Old 01-16-2013, 01:47 AM   #11
scx89
Member#: 269388
2011 Impreza WRX
obp
What exactly is the oil from? I've read that it's blow by and it's a result from the ringlands seals not being perfect and oil slipping past them. Shouldn't it be no oil at all? I need to find a good read on this
Old 01-16-2013, 08:24 AM   #12
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That's a good plan.
Those are all common.
Also the hose that goes from the top of the BPV to the back of the intake manifold can pop off the intake manifold. Needs a zip tie to hold it on. if this pops off it causes a pretty bad boost leak. I don't see this one as much on stock cars. Usually higher boost (20+ psi).
It's blow by. Some cars have more than others.
Old 01-16-2013, 11:35 AM   #13
Tripintaz
Member#: 245218
2013 STI Limited
90% of these complaints are due to the Throttle Body to Intercooler hose. The OEM one is crap and breaks open over stock boost levels. I think Subaru did it on purpose.
Old 01-16-2013, 11:41 AM   #14
GT3782
Member#: 343587
Have you thought about installing an oil ketch can?
GT3782 is offline   Reply With Quote
Old 01-16-2013, 12:18 PM   #15
scx89
Member#: 269388
2011 Impreza WRX
obp
Yeah, i was wondering whether to get a catch can or air oil seperator. They look like a pain to find a place to mount them
Old 08-07-2013, 02:07 AM   #16
bwoon
Member#: 364613
I am also experiencing this same problem regarding boost leak, but I haven't taken the intercooler off yet. Just out of curiosity, does anybody know if there is an after market hose that can be attached in order to avoid these leaks in the future? Or will the stock hose be sufficient with the damaged rubber portion taken off?
bwoon is offline   Reply With Quote
Old 08-07-2013, 04:24 AM   #17
gmorcos37
Member#: 274903
2011 WRX Sedan
Dark Gray Metallic
Here are some aftermarket ones that look promising. Never experienced them myself, so can't give my review.
http://www.avoturboworld.com/avoshop...hose-p-33.html
http://www.tomiokaracing.com/index.p...legacy-gt.html
gmorcos37 is offline   Reply With Quote
Old 08-07-2013, 06:57 AM   #18
rquinn19
Member#: 341182
SSM
It should also be said BE VERY CAREFUL WITH THE TURBO-> INTERCOOLER BOLTS when removing the IC
rquinn19 is offline   Reply With Quote
Old 08-07-2013, 08:25 AM   #19
1wrxtra
Member#: 316364
This is good advice. Put some anti-seize on those bolts before you re-install the IC.
Old 08-07-2013, 09:25 AM   #20
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
As others have said, the oil is normal. The heads release the crank case gases through the PCV system, which is connected to the turbo inlet. This puts a pretty heavy pull on the system to allow for proper ventilation, and oil can subsequently be pulled with the air.
Do a boost leak test with a local subie owner
BeastianSTI is offline   Reply With Quote
Old 08-07-2013, 12:30 PM   #21
legacy377
Member#: 364650
Just a suggestion for future reference. You can make a fairly affordable boost leak detector with some pvc pipe and a schrader valve. It uses compressed air in the charge pipes with the engine off to detect for any air leaks.
legacy377 is offline   Reply With Quote
Old 08-07-2013, 02:15 PM   #22
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
ive seen these but i went with this one.
https://shop.bostonmotorsports.com/V...RX_p_1183.html
fit perfect, and i reused the oem worm clamps, held fine. ive since upgraded that POS stock IC though
this! i ended up cross threading one of the bolts, god what a nightmare that stupid IC is..
Old 08-07-2013, 08:12 PM   #23
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
you can also check the turbo inlet. They suck even more so than the IC->tb hose just because they're not the most fun to replace. Heres mine: 2011 wrx right around 28-30k miles when I finally found this issue
bluemax189 is offline   Reply With Quote
Old 08-07-2013, 09:00 PM   #24
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
jesus, what part of the intake/intercooler setup doesnt have to be replaced!
Old 08-07-2013, 11:30 PM   #25
SpoolinJon
Member#: 364291
13 WRX Limited
+1 on this. Mine slipped off very easily when i was installing my boost gague lol.
Had to call Eric at torqued Performance to find out where the hell it went, luckily he answered the phone seeing as it was 10 at night.
SpoolinJon is offline   Reply With Quote
