#101 | |
Member#: 292364
MWSOC
Vehicle:2004 STi WRB |
#102 |
Member#: 190729
NWIC
Looks like you had too much knock on that cylinder. The top ring land looks like it's seen quite a bit.
You said you tuned it yourself, right ? How much knock were you getting ? I've had guys think knock was ok because they had forged pistons. Knock is never ok. |
#103 | |
Member#: 292364
MWSOC
#104 |
Member#: 190729
NWIC
.3 volts? What are you using for EMS?
#105 |
Member#: 292364
MWSOC
#106 |
Member#: 190729
NWIC
I can barely see it in the picture. It looked like a lot of small pits below the upper ring. Plus the wear on the wrist pin made me think detonation.
#107 |
Member#: 316296
Vehicle:2006 STIROID GT3794@30psi |
Were these upgraded wrist pins??
I'm not going to bash said shop but I do know for a fact they are a little timing happy on their tunes and based on the dyno sheets I have from the previous owner they aren't exactly the most well-versed in Subaru tuning. |
#108 |
Member#: 190729
NWIC
Is it safe to say that nobody verified the pin to piston clearance?
#109 |
Member#: 292364
MWSOC
They were not upgraded pins, I don't remember where timing was at. It made 450/449 on AMS's dyno. The tune really wasn't that great, drivability kind of sucked
#110 |
Member#: 340526
Vehicle:2004 WRX STi rotated hx35/850cc/93oct |
#111 |
Member#: 170097
South East
Vehicle:2007 WRX STi PTE6266 OBP |
If his issues were anything like mine...the car would cruise so lean it would hesitate if you stepped on the gas faster than a grandma on a Sunday drive. Throttle so touchy it looks like you just started driving your first stick shift car. Throttle accel issues out the azz.
#112 | |
Member#: 316296
Look at the ignition accel and decel tables. Mine were spaced out. |
#113 |
Member#: 292364
MWSOC
What they said^
#114 |
Member#: 292364
MWSOC
Would it be worthwhile to replace all the wrist pins with JE's upgraded pins? I'm wondering if the wrist pin bent slightly because of the extreme load
#115 |
Member#: 190729
NWIC
Pm sent
Stronger pins are always worth it. |
#116 | |
Member#: 316296
JE recommends the upgraded pins for over 500 hp. |
#117 |
Member#: 190729
NWIC
I think I have them in stock...
#118 |
Member#: 108051
Tri-State
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
Do it... mine are and offset iirc.
#119 |
Member#: 169062
SCIC
Vehicle:2006 STi WRB |
I found out a tapping noise was one of my rod bearing being bad and the noise was only from 2.5k rpm-4k rpm. The rod and crank were f'ed up bad. So, a tear down would be adviseable if you have a spare car or borrow one.
#120 |
Member#: 292364
MWSOC
Problem was cyl 2 wrist pin. Rebuilding right now should be running in a couple weeks or less
#121 |
Member#: 292364
MWSOC
UPDATE: just fired the car up anddddd the tick is still there although it doesn't sound as bad. I'm grabbing some 20w50 right now to try out and see if it goes away. It's only there now when completely warmed up
#122 |
Member#: 292364
MWSOC
Another update..switching from 10w40 to 20w50 made absolutely no difference in sound..car still runs perfect. Swapped avcs solenoids around to see if the noise followed..it didn't. Car still runs perfect. I am seriously lost as to what this could be.
#123 |
Member#: 182375
SWIC
Vehicle:08 Sti Wrbm |
Assuming you put new pistons and wrist pins in?
#124 |
Member#: 170602
Vehicle:06 Wrx 6Spd TSBorg Warner S400-Aem-2200s |
upppdates!! if you swapped to new pistons, and replaced the rod bushing...seems tou should run car wihtout timing belt cover and visually look at tensioner. sounds dumb but very easy to do and only takes a short amount of time.
maybe its an oil flow issue, also did the lash check out before you installed new motor? if lash is good and all bearings/wrist pins are clearanced right shouldnt be any more noise loud tap wise... maybe avcs issues...... |
#125 |
Member#: 292364
MWSOC
