Old 01-05-2013, 06:58 PM   #1
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Running a tune by mac auto in parker co on 91 octane. Just put in a wideband and found out that I'm dipping under 10:1 pretty much at all times in open loop. Nothing has changed on the car and I just checked for boost leaks and cleaned the maf. My question is; since I have a cat is the up-the-tailpipe wideband they use less accurate because of the cat? And am I seeing more accurate readings? Should I start looking for mechanical issues or work things out with tuning? I'm thinking the ladder at this point.
Oh and I'm looking at the dyno print out that shows a solid straight 11.6(ish):1 afr.
Jeffman44 is offline   Reply With Quote
Old 01-07-2013, 01:19 PM   #2
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Bump
Old 01-07-2013, 01:35 PM   #3
bmx045
Member#: 262684
2011 MCS
pull a learning view, post it up or tell us what your airflow learning trims are. if you have an intake thats not scaled properly(or injectors), or not good enough it can affect open loop (wot) fueling. one way to see if the learned trims are screwing with things is to reset the ecu and do a pull and see where your AFR's are.
they say readings at the tailpipes are .4 leaner AFR than what you'd measure at the turbo/downpipe area. Another thing that can cause richness under boost is a boost leak. if air is leaking out from somewhere, the ecu is going to command fuel for a targeted boost ASSUMING the engine recieves that boost. If it doesn't, it has all this fuel and nothing to do with it.
bmx045 is offline   Reply With Quote
Old 01-07-2013, 04:00 PM   #4
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Who are "they"? I'm curious where you got this info from
Old 01-07-2013, 05:10 PM   #5
Jeffman44
Member#: 239072
2005 WRX Wagon
white
I figured because the cat oxidizes fuel to lower emissions and the wideband measures voltage by oxidizable shtuff on the sensor, that this would cause my open loop map to be pretty screwed by tuning it post cat. I'll get a learning view up soon. I've been tuning a lot of closed loop stuff lately and all the reflashes haven't had any effect on the problem.
Old 01-08-2013, 08:03 AM   #6
bmx045
Member#: 262684
2011 MCS
After further review, it seems imperical data does not support my claims.
Old 01-09-2013, 11:44 PM   #7
Jeffman44
Member#: 239072
2005 WRX Wagon
white
So couple things....
Realized I switched my cat back from a 3" eBay coffee can to a 2.5" borla. Probably causing the richness.
And in my tuning I noticed that my tip in enrichment was still stock. I have 725cc injectors now..... After scaling that properly the car runs like a dream. I also have an e-85 map on the same setup... Still stock tip in table. Why would a veteran tuner not touch this table? I even took the car in because it was bucking and drove like hell. He still left that table untouched.
Old 01-10-2013, 08:16 AM   #8
bmx045
Member#: 262684
2011 MCS
the catback made no difference in fueling, I can tell you that. Tip in doesn't mean you're going to run rich, it's more of a drivability. The tip-in is usually the response to quick pedal movements, consistent bucking, or constant bucking would not be the cause of this table remaining stock.
Old 01-10-2013, 12:09 PM   #9
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Only bucking with throttle movement was my problem. That tables values are additional ipw. Scaling it from the 420cc to 725cc proportionally solved the problem 100%
Old 01-10-2013, 02:50 PM   #10
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
How did you scale the injectors, what did you do for the latency? I de-capped a set of stock 420's and will be using them in my up coming build.
romanlynch is offline   Reply With Quote
Old 01-10-2013, 03:46 PM   #11
Jeffman44
Member#: 239072
2005 WRX Wagon
white
You generally have to get the latency from the manufacturer but since you're modding the stock ones you can keep them the same. To scale the tip in just multiply the whole table by old injectors/new injectors. For me that was 420/725 so .58.
Old 01-10-2013, 05:23 PM   #12
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Sorry, that is incorrect
Old 01-10-2013, 06:25 PM   #13
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Yea youre probably right. It must be magic that is making my afrs steady during throttle change.
Old 01-10-2013, 06:56 PM   #14
romanlynch
Member#: 126684
02 wrx
Actually I did read a thread that stated (technically) you should change the latency because even though I'm using stock injectors they are flowing more fuel. The computer will, in most cases compensate for it, but your supposed to change it. I'll see if I can find it when I get home, I posted in it so shouldn't be hard to find the link.
Old 01-10-2013, 06:57 PM   #15
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Old 01-10-2013, 07:04 PM   #16
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Yea I could see that because it won't be flowing the exact right amount of fuel at the exact same time. Might be interesting to try and dial it in perfect.
Old 01-10-2013, 07:54 PM   #17
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
hacked injectors do NOT have the same latency as stock, don't make that mistake.
Old 01-17-2013, 12:59 PM   #18
adecan
Member#: 277425
02 WRX
So, what would be the recommended latency value for decaped (not bored) stock 420’s??
adecan is offline   Reply With Quote
Old 01-19-2013, 04:52 PM   #19
Jeffman44
Member#: 239072
2005 WRX Wagon
white
I have no idea but I'm curious too, free bump
Old 01-23-2013, 05:08 PM   #20
romanlynch
Member#: 126684
02 wrx
I would assume the same as a set of 850's or at least close enough it wouldn't make much difference. But that's me assuming
Message Board Statistics All times are GMT -4. The time now is 12:29 AM.
