#1 |
Member#: 261834
Vehicle:2010 WRX Darkness |
Thinking of ordering OpenPort and BCS. Anyone have input regarding their BCS? It's alleged to be PnP with Subies...
Last edited by WRX_hatch; 05-23-2011 at 01:48 PM. Reason: looking for minor boost increase- would money be better spent on the O2 sensor? |
#2 |
Member#: 231700
Vehicle:2004 WRX Wagon WRB |
Buy a MAC valve (part number 35A-AAA-DDBA-1BA) and save money for your tune. It cost me about $35 for the valve, a couple fittings, and some vacuum line. I just spliced into the existing BCS harness and soldered on the leads from the MAC valve. Otherwise you'll need to find a pigtail that works with the BCS harness. I didn't feel like spending the time or money tracking one down. Used double sided tape to stick it to the existing BCS bracket and put a zip tie around it for security. The MAC valve is the same one used by a variety of performance parts manufacturers. It is working great for me so far on the e-tune that I'm getting right now. REMEMBER: YOU WILL NEED A TUNE! Otherwise you'll overboost since the wastegate duty cycle must be lowered quite a bit for a 3 port.
Also, update your profile with your car details so we know what you've got. |
#3 |
Member#: 261834
The plus for the Tactrix BCS is that it comes with the Subaru adapter harness. It's the same solenoid sold by Prodrive apparently.
#4 |
Member#: 255153
TXIC
Vehicle:'02 Corn fed bugeye '11 forester 2.5X SWP |
I say MAC valve as well. Very cheap and reliable.
#5 |
Member#: 261834
The order is in for the Openport 2. I have to hold off on other stuff. Money doesn't grow on trees anymore. Well, it sort of does, just not in my yard...
#6 |
Member#: 11205
RMIC
Vehicle:2009 WRX Dom3-e85-ewg |
You can get the connectors here for an oem look. I don't worry much about shipping cost be cause I order a bunch at a time and use them to make pigtails for Bosch Injectors. They are cheap but shipping is high
![]() http://www.connectorsfast.com/store/...rs&SubCatID=61 Nippon Denso Style Male Connectors (ND-M2) I also found them here for a cheaper shipping price. http://www.injectorconnectors.com/Connector_Store.html |
#7 |
Member#: 261834
Checked that link, thank you. The OP2.0 showed up earlier today. Just read my ROM and it's not recognized so I'm not sure where to start looking for a start point. Not surprised that a newer model wasn't found. I WAS surprised that it found the OP and ECU and read it the first time. (Gotta be lucky once/day.)
Last edited by WRX_hatch; 05-27-2011 at 05:10 PM. Reason: I am supposed to use the 07+ CAN Subaru option for reading, correct? |
#8 |
Member#: 261834
EcuFlash works better when you have metadata where it belongs... There are valid maps in my ROM now. I wish I ordered the O2 sensor with OP2.0
#9 |
Member#: 320656
Vehicle:2002 WRX wagon |
this is going to sound stupid but do any of you know if the openport 2.0 works with an 02 ej205
#10 |
Member#: 306186
Vehicle:2002 Subaru WRX PSM |
The tactrix openport 2.0 works with the 02+ wrx's very well. Spend the couple extra bucks to get the jumper, saves your paper clip/spare wire stash.
#11 |
Member#: 320656
ok thanks for the info and advice man.
| Thread Tools | |
| Display Modes | |
| FS : EPTX: Tsudo UP, Tactrix 3 port BCS, Stock 07 STi TBE | Black07STiGuy | Engine/Power/Exhaust | 37 | 05-24-2011 04:46 PM |
| FS : EPTX: Tsudo UP, Tactrix 3 port BCS, Stock 07 STi TBE | Black07STiGuy | TXIC Private Classifieds | 28 | 05-23-2011 06:47 PM |
| oem bcs and grimspeed 3 port bcs | scooby_wooby | Engine/Power/Exhaust | 7 | 10-14-2009 02:43 PM |
| BCS , 2 way or 3 way iam lost . | vulpina | Factory 2.5L Turbo Powertrain | 4 | 08-18-2007 09:05 PM |
| Buschur Dyno Tuning Special Prices - Feb 2 and Feb 3 | Dyno Flash | MWSOC Vendor Classifieds | 9 | 01-29-2007 06:24 PM |
