Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 01-11-2013, 09:49 AM   #1
MeBoosta
Member#: 318040
2012 Impreza WRX
Metallic Grey
Default Is there something going on with the coolant?
I have a 2012 WRX with about 13k miles on it and i have been noticing in a lot of threads saying to replace the coolant every 30k miles. My coolant is down below the low line.
1. What is the best coolant to use?
2. Should the coolant be that low already?
3. What should i add to the coolant?
4. How should i go about adding the conditioner/water to the coolant when putting it in?
this may be an easy question.....please let me know!
MeBoosta is offline   Reply With Quote
Old 01-11-2013, 10:48 AM   #2
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
I'd pick up a gallon of <insert your favorite coolant brand here> and add it to the over flow tank until it is at the correct level.
Personally, I like Prestone. I always keep a gallon of 50/50 on hand and top off my / wife's car when I change oil.
Also, I bet in the owner's manual there is mention of adding coolant and the MFG requirements.
Unless you're tacking the car, I wouldn't worry about adding any additives to the coolant.
iamrazor is offline   Reply With Quote
Old 01-11-2013, 11:05 AM   #3
MeBoosta
Member#: 318040
2012 Impreza WRX
Metallic Grey
cool thanks alot man! I dont have a favorite brand....yet, I'm guna have to run to autozone after work then
Old 01-11-2013, 11:14 AM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You cant just use any coolant.
And Id wager your coolant level is just fine.
And your still under warranty, send it to the dealer.
Old 01-11-2013, 12:17 PM   #5
XplicitRacingDesign
Member#: 242434
2004 WRX STi
Blue/Charcoal Grey 2 tone
Is it below the line when hot or cold? It will be different.
XplicitRacingDesign is offline   Reply With Quote
Old 01-11-2013, 02:20 PM   #6
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Don't even bother with coolant. Boil or pick up some distilled water and pour it into the overflow tank. Keep in mind this level will raise when the car is warm and lower when the car is cold. Be sure the car has cooled overnight first before checking the level to get a proper reading.
Acejam2k is offline   Reply With Quote
Old 01-11-2013, 03:34 PM   #7
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
I was always too lazy to research the correct coolant. So I'd go to the Subaru dealer and buy OEM with a bottle of conditioner (it's basically stop leak). I think it cost like 32 cents more than prestone at auto zone. That's ok.....I had suby bucks and picked up other stuff while I was there.
Remember to use distalled water. Not spring water, not boiled water, not tap water, not soda water, not scotch and water. CVS has it cheap enough. Distilled water doesn't have minerals and crap to mess up your cooling system like all that other water does.
Old 01-11-2013, 03:40 PM   #8
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
You mean boiled tap water isn't the same as distilled water? what about deionized water? Isn't that just water that I haven't put batteries into yet?
Old 01-11-2013, 04:52 PM   #9
NateLS1
Member#: 132380
2004 WRX
rojo
Your car has blue coolant from the factory, its called Subaru Long Life Super Coolant. Comes 50/50 mixed already. And it definitely lasts longer than 30k.
If you think your low bring it to the dealer, its under warranty.
NateLS1 is offline   Reply With Quote
Old 01-11-2013, 05:11 PM   #10
downest
Member#: 194343
1991 CRX B18C5 turbo
'88 4Runner daily
As far as I know Subaru coolant is green, requires mixing with water, and also requires a small bottle of cooling system conditioner. It has a service life of 30k miles, which is why it's listed as part of many 30k/60k/90k services.
We use Honda coolant, which is blue, already mixed, and lasts until your engine has to come out for pistons/spun bearing etc (Honda rates it at 10 years/120k, not too many turbo Subarus go that long without major engine work). It's available at your local Honda dealer for just under $20 per gallon.
downest is offline   Reply With Quote
Old 01-11-2013, 05:17 PM   #11
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
The Subaru Green is also available in 50/50.
Subaru introduced a new Blue coolant a few years ago.
Old 01-11-2013, 05:18 PM   #12
NateLS1
Member#: 132380
2004 WRX
rojo
The green coolant is regular Long Life. They stopped using that in 08 / 09. All 08 sti's have the new blue stuff and all 09 up Subarus have the blue stuff. The service interval is pretty much the same as the Honda, pretty much lasts forever. Although I like changing it anyway.
Old 01-11-2013, 05:19 PM   #13
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I'm pretty sure 50/50 green is no longer carried. I believe you can only buy green concentrate. If you do find 50/50 green, it's probably years old.
Old 01-11-2013, 05:20 PM   #14
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Ah. Last time I bought Subaru OEM coolant was in 08. I use Peak Long Life now.
And I only buy concentrate anyway. 50/50 was the same price as concentrate around here.
Old 01-11-2013, 05:27 PM   #15
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
OP: Your coolant lasts 100k+ and does not need to be changed every 30k. When you do change it, don't bother using that shark chum conditioner. That stuff is known to plug up radiators (too much) and is really only meant for the phase I EJ25's.
The simplest fix in your scenario is to pour in some distilled water and call it a day.
