Old 10-13-2009, 04:09 PM   #51
Jack T
Member#: 226760
2006 Legacy Limited
Thumbs down
Hello:
First time here on the recommendation of an enthusiast. Do I have a lemon? Wish I could start a new thread, but am not allowed to do that until I have at least three responses, I guess--at least that's the message I get when I try to.
I have a 2006 naturally aspirated 2.5L Legacy Limited sedan that has had several continuing problems, one dealing with the automatic transmission, one with air conditioning and one with body squeaks and rattles. For this comment, I will only address the air conditioning. I will address the other two on other threads.
Regarding the air conditioning, with automatic climate control, I don't believe it has worked since new. On very hot days, it just doesn't do the job. Do these cars just have small evaporators, or is there something the dealer is missing?
At 1639 miles, I took it to the dealer to be checked out. The technician reported the system had 1.33 lbs of freon and should have 0.95 lbs, evacuated and refilled with the proper amount. After tolerating substandard cool, I took it back at 3363 miles. The report said that it was working better than normal. Huh? I asked the technician for the service instructions for verifying operation. He left and returned with a FAX of the procedure, I read it, and it seemed like the system was, indeed, working fine.
Assuming there must be some sort of design flaw, maybe with the automatic climate control, I began a chain of communication with Subaru Corporate. Eventually, they sent me a newer service sheet, I read it, and found that the technician was taking the outside temperature as the reference, and should have been taking the inlet temperature at the passenger side of the console. Then, I realized that when he demonstrated the system operation on the previous visit, he had closed all the vents except the one where the thermometer was. According to the service procedure, all vents are supposed to be open.
Finally, at 36,364 miles, and during a hot spell, I returned to the dealer and asked once again to have the system looked at, including damper movement inside the duct system. New technician. New diagnosis. He found that the system had only 0.62 lbs of freon and stated it should be between 0.81 and 0.95 lbs. He evacuated the system and filled it with 0.95 lbs. He also showed me a different service procedure with the required gas pressures in the system and the ones he was getting. I have to admit, the system is colder, but on days over 80 degrees, the system needs to run in recirculating mode at very noisy high fan speed.
Anybody out there have something they could tell me about this? Thanks for your advice.
Regards,
Jack
Jack T is offline   Reply With Quote
Old 10-13-2009, 04:22 PM   #52
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Originally Posted by Jack T View Post
Hello:
Regards,
Jack
In order to get maximum cool, you need to run the a/c on recirulate. The lower the fan speed, the cooler the air will be. (The air remains inside the system and can cool more on lower fan speeds.)
Put a thermometer in one of the air vents and see what the temperature is after about 3 or 4 minutes, on recirculate and on fan speed 2 or 3. 60 degrees or colder is about ideal.
You say that the fan is loud on speed 4? Are you referring to the air coming out of the vents, or is it making a rattle or another noise? Have you ever replaced the cabin air filter? (the one for the air conditioner) It should be done once a year, at least.
If the system, on the last check, was low on freon, then you have a leak somewhere. A/C systems just don't loose freon. Have them add dye to the system and see where the leak is coming from.
RexyGirl is offline   Reply With Quote
Old 10-13-2009, 06:23 PM   #53
Jack T
Member#: 226760
2006 Legacy Limited
RexyGirl:
Thanks for your quick replay. This is the second time to write this as the site wouldn't let me send the first and I lost all content, so let's try again.
Fan Speed--This system has six fan speeds. Like all fans, the faster they run, the louder they are. In order to cool, whether in Auto or Manual mode, the fans in this car must run at either the fifth or sixth speeds, in recirculate mode and are noisy.
Cabin Filter--Thanks for alerting to the cabin filter. I didn't know this car had one. However, since this lack of performance has been since the car was new, it is not likely the root cause of the low performance.
Freon Level--It is my belief that at the first service, the technician somehow made a mistake about the freon level in the system--maybe the device he was using to measure was out of calibration. It is unreasonable that the factory installed that much extra freon--very difficult without having extremely high internal pressures. Then, the technician made a second mistake by demonstrating to me that performance was above normal when he was measuring outside air temperature rather than the prescribed recirculating temperature as a reference, and closing all but one vent where the thermometer was--not the printed procedure.
When the second technician performed service, he found too little freon in the system, I think, because the previous tech hadn't put in enough. By the way, between services, the AC performance did not deteriorate, which probably indicates there is no leak. In fact, the performance has been the same since the last re-charge.
Thermometer in Vent--Since I first determined the system was not performing as well as I thought it would, I have had a thermometer in the center vent. At first, the temperature seldom got down to 60 degrees, especially on hot days. When the car was moving at lower than freeway speeds, in stop and go traffic, or while stopped, going below 70 was extremely rare. Now, it reaches 60, but not while moving slowly on a hot day.
Unfortunately, we are not having hot weather right now, and testing the system is not possible.
Thanks for your help.
Regards,
Jack
Old 12-21-2009, 01:28 PM   #54
ILSMKU2
Member#: 77908
2011 E92 ///M3
RIP 11, 09, 06, 03 STI's
Thumbs down
Make: 2009 STI
Mileage: 13k
Time Out Of Use: None
Problem And Likely Cause: Radio paint is fading, peeling, scratching off. My finger?
Modifications: CB Exhaust
Submitted For Warranty Work (Yes/No): Yes (told to hold until Feb to see Subaru rep)
Reason Given For Denial: Subaru Rep needs to see it, come back when subaru rep is in town, until then, deal with it. Dealer wont replace without Subaru rep seeing it.
Your Story: This is my 3rd in a row subaru (03WRX, 06STI, 09STI) and recently noticed a silver spot on my radio dash trim. As I looked closer, I noticed that it was a chip in the black paint and the silver paint below it was showing! Then I took a closer look at my radio and noticed that the paint is fading off around my volume knob too. And the black rubber like paint above the volume knob is peeling off too.
Not sure what the chip in the trim is from. But the fade/scratches around the volume knob clearly seem to be from my fingers. It would make sense the scratches are from my finger nails I guess. I mean, only my fingers have touched them. And I dont have long finger nails. In fact, my nails dont pass my finger, as they are very short.
The problem is... I hardly use the stereo volume knob at all. 99% of the time, I touch my steering wheel controls. And the paint/finish on those is mint? Plus non of my other subaru's had this problem and I had those for a much, much loger time.
I showed this to my dealership months ago and they told me a subaru rep would have to come see it, because its a 2k stereo (yea right) and if they replace it, and Subaru denies it, then they loose money. I understand. But the subaru rep never came to the dealership and the dealership never called me to tell me when he was coming like they said they would. Last month I brought it to my dealerships attention again, asking them why they never called me like they said they would. They had no excuse other than sorry and took some photos to send to the rep. 2 weeks pass and I call to see if they got any word from the Subaru rep since they didnt call me back again and they said now subaru is changing all there sales reps and in the mean time, Im just going to have to wait until Feb for a rep to see it.
To me, its clearly wear, but it shouldnt be happening to a 8month old car. Especially since the past two Subaru's Ive had never had this problem. And Like I said, I hardly even use the volume knob as I have grown to love the streering wheel controls.
Here is what it looks like:
What do you guys think? Anyone else have this issue? Just seems odd that the one year they start using this non industry standard sized raido that now I have paint coming off. Where as the past two Subaru's I had that were industry standard double din size, never showed a single scratch in the 3yrs I owned each one of those.
Bummed out!
ILSMKU2 is offline   Reply With Quote
Old 12-27-2009, 05:55 PM   #55
boiboi9
Member#: 208460
I am 95% sure they will deny it, they will say you scratched it with your keys, ring, lighter, coin, or something like that. Also, above the knob it also appears to be pryed, or just wear, I am not sure, but its a long shot IMO.
I have had 2 OEM head units replaced, for a different issue, but I saw the dealer invoice to subaru of canada, and they were each $1750, that freaking insane for the crappy sound they produce!
Good Luck
boiboi9 is offline   Reply With Quote
Old 01-15-2010, 01:09 AM   #56
ILSMKU2
Member#: 77908
2011 E92 ///M3
Default Update
Well, after waiting all this time. SOA finally approved my radio replacement.
So some new SOA rep calls me this morning. Prior to that I always spoke to some other lady. So the dude calls me and says, were going to replace your radio in good faith. But the dealer said you had an amp and that the scratch on your radio was probably from that! I just rolled my eyes while listening to him and thought, well its covered, why argue.
But yea, my scratches were from use (maybe I turn my volume up and down to much?) and that SOA rep made it sound like it was ME who installed an AMP and somehow did that. Perhaps if I had one big gash across it or something sure. But Jesus! Look at my pic. Its from the FINGER MAN! THE FINGER!
Old 04-14-2012, 07:49 AM   #57
79letour
Member#: 302570
2013 XV
DGM!
I love reading these dialogs between SOA, the Dealers, and cutomers who have brand new cars or cars under "warranty".
Someone earlier was waiting on a Subaru Rep. Lol I think they have ONE and he vacations six months of the year.
My dealer and SOA are a bunch of dodgy, lying SCUMBAGS.
79letour is offline   Reply With Quote
Old 01-12-2013, 05:36 PM   #58
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
had my driver sunvisor replaced under warranty again today. this is the second time its been replaced. it keeps breaking where it swivels to go down. my dealer is very cool and never gave me any hassles.
Old 01-12-2013, 05:47 PM   #59
SpamBot
Member#: 287534
Let's see, how long would it take me to find threads where people have modified their vehicles, experienced a subsequent failure that is related, and quickly decide to return the vehicle to stock in an attempt to defraud Subaru?
You want dodgy, lying SCUMBAGS?
SpamBot is offline   Reply With Quote
Old 01-17-2015, 12:46 PM   #60
stovetopmafia
Member#: 378927
2014 WRX
Dark Grey
posted in the wrong thread
Last edited by stovetopmafia; 01-18-2015 at 01:15 PM. Reason: deleted because it was in the wrong thread
stovetopmafia is offline   Reply With Quote
Old 01-31-2015, 03:28 PM   #61
invisusAG
Member#: 412290
2015 WRX Limited
Make: 2015 WRX
Mileage: 11,000
Time Out Of Use: N/A
Problem And Likely Cause: Center armrest console wouldn't remain closed. Locking mechanism defective.
Modifications: ETS intake, Nameless Axleback Exhaust
Your Story: After a few months of owning the car, the center console wouldn't stay shut, it would keep springing up. I took it to the dealership and they replaced it on the spot with no questions asked.
invisusAG is offline   Reply With Quote
Old 06-15-2015, 05:58 PM   #62
trevor2.0
Member#: 407940
2015 Impreza 2.0
Crystal Black Silica
Make: Subaru Impreza (5 door)
Mileage: 9500
Time Out Of Use: 1.5 weeks (and counting 6/4 drop off date)
Problem And Likely Cause: Alarm locked out both fobs, no push button start, keyless entry, etc. If unlocked manually, alarm sounds, fob reset in owners manual does not work.
Cause: Subaru says it is the 'computer that talks to all other computers" has shorted out. Say that adding a radar detector via fuse tap to auto dimming mirror and dashcam to 12v fuse (to toggle parking mode) and door locks (constant power) caused computer to short out. the door locks and the 12v plug still work in the car.
Modifications: Radar detector (passport max) and dashcam (panorama X2)
Reason Given For Denial: TBA
Your Story: So I bought the car Dec 2014, had the radar detector in my BRZ so I moved it over to the impreza. Beginning of the summer added the dashcam due to parking worries. Drove around for months without issue. then fob stopped working. checked fuses, all were good. alarm goes off and does not allow for a reset. had it towed to subaru,
The rep states that "If the overall resistance in the cars electrical system changes it could short out the computer". They claim issue has been happening with folks with aftermarket tail lights or those of added LED lighting.
They ordered a new computer (still have not told me exactly what its technical name is, I have asked for it). Awaiting its arrival, they said that Subaru may not honor the repair due to aftermarket stuff.
trevor2.0 is offline   Reply With Quote
Old 06-15-2015, 08:09 PM   #63
RexyGirl
Member#: 63616
with mods :)
Mileage: 9500
Find out if they pulled any codes from the BIU computer ( Body Integrated Unit). If so, let me know what they were.
What exactly is the car doing / not doing?
It is very possible that hard wiring the radar detector and camera could have caused this issue, but I need more information
Old 06-16-2015, 12:51 PM   #64
trevor2.0
Member#: 407940
2015 Impreza 2.0
Both fobs stopped working (keyless entry and start), the car would not unlock with fob, would not turn over if unlocked with key and fob held over the on button, fob reset did not work. Additionally, the alarm was triggered when unlocking the car manually, unable to disable the alarm according to manual instructions.
I had the radar detector installed since Dec and the dashcam installed since March.
The BIU is what went out on the car, totally fried no codes. Warranty claim denied due to dashcam. 902 dollar bill. Apparently the electrical system is just that delicate, going to hook dashcam up to the battery directly. Only 'safe' way have anything installed is to bypass the entire electrical system of the car (dealer technician recommendation, also hinted to return the car to stock before bringing it in).
They said this has only become as issue in the newer vehicles due to a redesign of the electrical system. The said the radar detector didn't do anything because the rearview mirror is connected to the eyesight harness which has a breaker if it backfeeds/short circuits.
TLDR: dont install aftermarket stuff into the electrical system of your 2015 impreza it may fry you BIU and you will get a nice fat bill.
Old 07-19-2015, 11:19 AM   #65
JRim
Member#: 246777
99 2.5 RS
That is excellent advice!
JRim is offline   Reply With Quote
Old 07-20-2015, 07:04 PM   #66
trevor2.0
Member#: 407940
2015 Impreza 2.0
I did how ever reconnect everything to the battery with a simple toggle switch inside the car. Took a lot more work but no chance of that issue occurring. I was stunned when they showed me the electrical diagram...it is a jumbled mess.
Old 03-05-2016, 01:04 AM   #67
umwisnig
Member#: 428763
Make: 2015 WRX Sport (Premium)
Mileage: 12,000km (~7,500 miles)
Time Out Of Use: 1 hour
Problem And Likely Cause: Center console lid wouldn't remain closed. Latch lacked contact with the base and the lid's spring was too stiff.
Modifications: Accessport, mud flaps, and seasonal wheels/tires.
Submitted For Warranty Work: Yes
Reason Given For Denial: N/A
Your Story: Owned the car for a little under two years and use the center console each time I drive. As winter set in, the center console lid wouldn't remain latched, and would pop open about half an inch. Dealer tried lubricating the lid's spring, but to no avail, and ordered a replacement on warranty. Took a second visit to get the new lid installed. Issue is resolved. Same look, no creaks or rattles, and has a satisfying feel.
umwisnig is offline   Reply With Quote
Trouble/Warranty Denial Report Thread: Drivetrain (Engine, Tranny, Diff, Etc.) North Ursalia Warranty Issues & SOA Problems 2975 08-25-2016 07:13 PM
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle North Ursalia Warranty Issues & SOA Problems 140 07-12-2016 10:53 AM
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) North Ursalia Warranty Issues & SOA Problems 110 03-12-2016 01:48 PM
Trouble/Warranty Denial Report Thread: Braking System North Ursalia Warranty Issues & SOA Problems 83 05-03-2015 08:24 PM
Trouble/Warranty Denial Report Thread: Suspension North Ursalia Warranty Issues & SOA Problems 52 08-13-2014 06:05 PM
