Old 01-12-2013, 03:25 AM   #1
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Default How do I screw in the front license plate on a 2013 Impreza?
This might seem like a stupid question but how do you screw in the front plates? There are two pre-drilled holes in the front of my fender but it doesn't get screwed in. Do I have to put something in it before screwing it in?
http://www.cars101.com/subaru/imprez...portfront3.JPG
I checked the rear plates and took off the screw, it had some white plug stud thing in it to screw the screw on.
subaru604 is offline   Reply With Quote
Old 01-12-2013, 06:31 AM   #2
M45
Member#: 333446
2013 Impreza SL CVT
I have a front plate bracket that the dealer installed. I'd look for one of those. I'm guessing the install is easy.
Old 01-12-2013, 09:03 AM   #3
Guzzi 1
Member#: 338666
2013 Impreza Premium
Dark Grey Metalic CVT
The dealer screwed the plate right into the front bumper. I had no licence plate bracket. Kind os wierd I say, but now that the holes are there, I'm not making more.
John
Old 01-12-2013, 10:27 AM   #4
FourOhFour
Member#: 309509
2012 Impreza
You either buy the bracket that uses those holes or you find the two dimples nearby and screw directly into the bumper there, as I recall.
Mine's screwed directly to the bumper. The bracket probably looks nicer, but meh...
FourOhFour is offline   Reply With Quote
Old 01-12-2013, 01:15 PM   #5
hi5.0
Member#: 340456
2013 Impreza
Got direct mount plate too. No way in heck am I paying what the dealer wants for the "genuine Subaru" part. Plus I like the weight savings. I'll just buy some license plate frames to replace the dealer ones and be done with it when my permanent plates come in. Making pilot holes in the dimples would should make things easier if you go that route.
hi5.0 is offline   Reply With Quote
Old 01-12-2013, 02:48 PM   #6
aeoporta
Member#: 334126
2013 5mt Sp Premium
Venetian Red & Dark Gray
the holes at the front of the car are fro japaneese license plate.
you would need a Totsubo Subaru Front License Plate Kit if you were using those holes plenty of threads on nasioc about them and any pitfalls you may encounter.
Other option drilling holes into bumper the same way it is done in most cars, if you don't need a front license plate then you can just use a plate delete.
Front license plate holder for impreza
part number: DCOLICBRKIMP12
pics
http://forums.nasioc.com/forums/show...&postcount=410
Old 01-12-2013, 07:52 PM   #7
Brian722
Member#: 339726
Yeah they really weigh the car down...
Brian722 is offline   Reply With Quote
Old 01-13-2013, 01:56 PM   #8
M45
Member#: 333446
2013 Impreza SL CVT
I'd wager you could buy the bracket and do it yourself. Mine was on there before I bought the car.
Old 01-13-2013, 02:08 PM   #9
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Yeah but the thing is I want to install this Bump Shox XL thing which doesn't allow me to add an additional braket.
bumpshox.com
Old 01-15-2013, 10:11 AM   #10
winglik
Member#: 317022
2013 Impreza Sp. Lim
Dark Grey Metallic
bumpshox.com
Actually the shox XL can mount on top of the Subaru License Plate Bracket. My car comes with the Subaru plate bracket. I added the Shox Xl on top of it. it works well, and added that extra inch from people backing up into me.
winglik is offline   Reply With Quote
Old 01-15-2013, 10:31 AM   #11
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
That's good to know, thanks for the tip !
Old 01-18-2013, 07:04 PM   #12
pRiMe DiReCtIvE
Member#: 301387
2012 Impreza HB
Black/Dark Grey
Go to Sports Chalet...they have free license plate frames that say "I'd rather be....fishing, skiing..etc"
pRiMe DiReCtIvE is offline   Reply With Quote
Old 01-18-2013, 07:52 PM   #13
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
I don't see it...
http://www.sportchalet.com/p2p/endec...tateSubmit.y=0
Old 01-21-2013, 04:37 PM   #14
ukrainian102
Member#: 296019
2011 WRX Premium
Actually you don't need any fancy brackets. Go to Home Depot and pick up a couple well nuts (http://www.calsci.com/motorcycleinfo...s/WellNuts.png). I don't remember the right diameter exactly, but they're super cheap. Try a few out and see what holds it. Also for this you would need to drill holes in your plate (since the bumper holes don't match US license plate holes), but that's better than drilling the bumper.
ukrainian102 is offline   Reply With Quote
Old 01-21-2013, 06:19 PM   #15
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Yeah I just realized the pre-drilled holes does not match my license plate's holes. Is it legal to drill the license plate? I mean it is still DMV's property...
Old 01-21-2013, 06:30 PM   #16
Guzzi 1
Member#: 338666
I seriously doubt it as long as you don't do something that obscures the plate. Thing is, if you decide to put a frame around the plate nothing is going to line up with the new holes. Just food for thought.
John
Old 01-21-2013, 06:43 PM   #17
CLL_OBP
Member#: 310435
2012 Sport Limited
Obsidian Black Pearl
When I wrecked my car in the front many years ago, I had to use the same bent up New York tag. I don't think anybody will mess with you. They recycle them anyway.
CLL_OBP is offline   Reply With Quote
Old 01-21-2013, 06:53 PM   #18
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Alright cool thanks ! Looks like I will drill through the plates then. Will upload a picture once everything is done!
Old 01-23-2013, 03:25 PM   #19
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Can you upload a picture of how it looks?
I want to know how does the bumpshox xl actually attaches to the subaru license plate bracket. Are there another pair of holes for the bumpshox xl?
Old 01-28-2013, 12:10 PM   #20
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Can you post a picture of how yours look like?
I'm thinking if it will look weird or stand out too much if I add both to it...but I don't want to just add the bumpshox and nothing on the back to secure it from people bending my plate.
Old 01-30-2013, 08:37 AM   #21
winglik
Member#: 317022
Dark Grey Metallic
Here you go. The one i have is not XL, the XL version will be a little bigger. But you should get the plate guard before installing the BumpShox, since it requires 4 mounting holes. The back and front bumpers are made with some very soft plastic, any contact will leave a mark or dent. I had one small dent in my back bumper in less than 2 days. But after I installed the BumpShox on the front and Bumper Bully mat on the back, so far so good.
Old 01-30-2013, 11:19 AM   #22
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Sticks out a lot...especially with my XL oh man...
Thinking if I should get the SOA342L120 instead..
Old 01-30-2013, 12:00 PM   #23
winglik
Member#: 317022
Dark Grey Metallic
SOA342L120 was dealer installed when i got the car. the BumpShox added 1" on top.
Old 01-30-2013, 12:03 PM   #24
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
What I didn't like about the SOA342L120 was that there are two bumps on the back of the plate, so if a bad parking driver hits me the two bumps would either damage the screws or dig the bumps deeper into my car.
http://www.brandsport.com/sub-soa342l120.html
I like the DCOLICBRKIMP12 cause it's all around, so even if a bad parker hit me it would not damage or strip the two screws holding everything together.
Message Board Statistics All times are GMT -4. The time now is 10:30 PM.
