Old 01-09-2013, 10:29 AM   #1
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Default Topfeed Vs Sidefeed ?
I am planning a larger turbo somewhere in the 360-400whp range this summer and have been debating doing a fuel system conversion.
But I would much rather just drop in injectors and bolt on a New turbo then have to rip into the fueling system.
Are Sidefeed injectors as safe as Topfeed when you are staying in the 350-400whp power range or would it be best to just convert to Topfeed ?
The motor is already built and will have the following this spring
Crawford AOS
Killer B Oil Pickup
Ideas and opinions ?
I am trying to make reliable power and have spent a lot of time planning this.
Gigs90 is offline   Reply With Quote
Old 01-09-2013, 10:54 AM   #2
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Just got her retuned at 410whp on side feeds.
BlackFighter is offline   Reply With Quote
Old 01-09-2013, 10:58 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
The only difference is injector selection and price for the most part. For the same flow, top feeds will cost less because they're more plentiful especially when you're looking for more than 600cc.
Old 01-09-2013, 11:21 AM   #4
Wicked Performance
Member#: 265606
Larger topfeeds also work and tune much better. But at that power level you could use 850s sidefeed and it would be ok. You should parallel the feed at least.
Wicked Performance is offline   Reply With Quote
Old 01-09-2013, 02:40 PM   #5
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
Yes, 850cc sidefeed injectors will be good for your power range.
thisisthenewsic is offline   Reply With Quote
Old 01-09-2013, 05:13 PM   #6
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I am just worried about possible tuning issues as I want this to be a very reliable car at higher power levels.
Old 01-13-2013, 06:55 PM   #7
SuperScubi
Member#: 233407
2004 Aspen White STi
PIA Tune 347whp 327tq
I just retuned my STi yesterday with 850cc sidefeed injectors and put down 380.5whp
You'll have no issues with using sidefeed injectors. If you are worried... get ID sidefeed to topfeed conversion rails
SuperScubi is offline   Reply With Quote
