Old 01-10-2013, 11:35 PM   #1
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Default Learning View WTF!?!
My car has been running pretty poorly lately. It seemed like it was running really rich, with almost zero torque down low. Pulling away from a stop it felt as if it would if you tried to drive off from a stop in 3rd gear. It would hesitate and hesitate to give you power then eventually it would go. It was also occasionally stall out when coming to a stop. I just got my laptop working again today and so I pulled an LV and was shocked to see this. What could be going on here. Please help me diagnose this.
OUScooby is offline   Reply With Quote
Old 01-11-2013, 07:46 AM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Really bad fuel or broken parts?
Old 01-11-2013, 07:58 AM   #3
quazimoto
Member#: 70395
Did you do something to your TGV's? You have two codes that appear to be affecting the pair.
Old 01-11-2013, 11:52 AM   #4
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
TGVs have been deleted and tuned for, those two codes are always there (they are not CELs), they are unrelated to this.
Old 01-11-2013, 12:43 PM   #5
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
What ever it is quit driving your car. If it is pulling 10+ degrees in cruise situations you have a major issue.
There are so many things. Fuel injectors/coilpacks/sp etc. Good luck.
endrswrd is offline   Reply With Quote
Old 01-11-2013, 01:39 PM   #6
quazimoto
Member#: 70395
If they are deleted and tuned for those codes should be disabled.
Old 01-11-2013, 02:02 PM   #7
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
Also I was going to mention this as well, but I hadnt confirmed it yet.
Old 01-11-2013, 02:08 PM   #8
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Vacuum line from manifold back to ebcs came off. Hopefully too much damage wasn't done.
Old 01-14-2013, 12:42 PM   #9
bmx045
Member#: 262684
2015 Impreza Sport
ISM
sounds like your tuner doesn't know what he's doing, especially if he said the tgv are tuned for and didn't even disable the codes. i suspect foul play in the rest of the tune if i had to guess. and a simple vac leak shouldn't drop your iam to 0 AND pull -11*. no way jose.
bmx045 is offline   Reply With Quote
Old 02-10-2013, 03:54 AM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Codes can stay in the tempory column even though they are disabled....active CEL's show up in the "memorized DTCs" on teh right hand side.
