Old 12-28-2012, 05:34 PM   #701
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Nor here. And EPA only bothers kids with loud exhausts and massive subs that go doof doofing around "hangin laps" of town and doing skids and stuff, generally if you're a di*#head, you'll have trouble, but for most of us, EPA isn't that interested. Like Uncle Scotty says, Common Sense.
my0six is offline   Reply With Quote
Old 12-28-2012, 06:00 PM   #702
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
Originally Posted by stretchedk7 View Post
good point. im thankful we dont have smog and all that here.
It has really become a pain in the ass. I even had to unbolt my GS AOS because the smog technician said it was possibly "tampering with" the PCV system ;-).
neg_matnik is offline   Reply With Quote
Old 12-28-2012, 06:04 PM   #703
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
You should read about mandatory smog inspections and states that require them. It goes above and beyond EPA requirements.
Old 12-28-2012, 06:10 PM   #704
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
wow. my car would never pass! one look at the 4 unch hood dumped exhaust and id be on a tow truck!
Old 12-28-2012, 10:41 PM   #705
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Why, thanks, that sounds like a lovely way to pass the time...
...although I might give it a miss and just take your word for it. I will say I'm very sorry for you guys, we're lucky "down under" that the restrictions aren't so bad. Plus, living in a TINY town and being in good regard of the local police sergeant, I have no dramas.
I will be keeping the pump and all hoses, valves, etc. along with any other factory part I take off it in the future, just so any potential buyer might have those options, although I would be strongly advising them against putting a sh*# part back in the car that will probably fail again down the track anyway...
I'm surprised they don't list these things with parts like the timing belt for mandatory replacement...
...the timing belt probably lasts longer!!!
Old 12-31-2012, 02:20 AM   #706
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Okay, so I bought a tactrix cable today, Openport 2.0, for $120 from a guy on an Aussie forum.
Looking forward to my new project
Old 01-03-2013, 11:15 AM   #707
Zebe
Member#: 118698
07 WRX Ltd Wagon
94 Miata
Currently in-process of removal, and I am down to one bolt...
For those of you who have removed the ENTIRE secondary air pump system from an '07 WITHOUT removing the intake manifold, any tips on how to separate the (passenger side) valve from the pipe? Of the two bolts that connect the valve and pipe, the upper bolt was accessible and easily removed, while the lower bolt is being more difficult. I can see it, and can get my closed end wrench on it, but have no room to move the wrench. If I could rotate the valve, I could create more room, but that doesn't look like it is going to happen.
Zebe is offline   Reply With Quote
Old 01-03-2013, 11:25 AM   #708
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
That valve won't come out without removing the IM, just remove everything up to it and leave it there.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 01-03-2013, 11:29 AM   #709
Leafy
Member#: 330625
2006 WRX
Do you have a grinder? It'll suck, you could use the bench grinder to make a special clearance wrench out of a cheap wrench. But working the wrench for 40 minutes going an 1/8 of a turn at a time would still be faster than pulling the intake mani.
Old 01-03-2013, 10:22 PM   #710
leemarchais
Member#: 341215
Originally Posted by C0rnFed View Post
For anyone looking to replace their Air Pump Systems, I am selling a perfect working condition air pump setup off a 2007 for $110 shipped. Just throwing that out there if anyone is having problems with theirs
I will buy the pump!
leemarchais is offline   Reply With Quote
Old 01-03-2013, 11:59 PM   #711
eatsleepsubaru45379
Member#: 322853
2006 WRX
Steel Gray
I have an 06 wrx had the same problem, i researched my options, i didnt want to replace it so i had a shop install block off plates, there are CEL but you can delete them if you have an accessport, i did this no codes, and you can pass emissions, i did problem solved, hope this helps
eatsleepsubaru45379 is offline   Reply With Quote
Old 01-04-2013, 11:17 AM   #712
Zebe
Member#: 118698
07 WRX Ltd Wagon
94 Miata
~Evil
Are you saying that even if I get the valve and pipe separated, that I still won't be able to get the valve off without removing the intake manifold?
Good suggestion. I am searching around for a half-moon or s-shape closed-end wrench.
I have the accessport and block off plates, just need to get the system components off the car.
Old 01-04-2013, 11:53 AM   #713
EvileyeZ88
Member#: 233501
99 outback sport
It might, but it would take a lot of time to do such a simple thing. You may even get 3/4 of the way done only to find the bolt is too long to pull out or something.
I left my valve in place because I didn't see a reason to spend the time on something so hidden, now when I go to put on my tgv deletes, that's when the valve will come out.
~Evil
Old 01-05-2013, 08:52 PM   #714
Zebe
Member#: 118698
07 WRX Ltd Wagon
94 Miata
Using an S-shape closed-end wrench, I was able to loosen the last bolt between the passenger side valve and pipe, and, with some careful maneuvering, the valve is out. Removal of the pipe is the next challenge. Any suggestions?
I have the pump, both valves, and driver side pipe all removed. The passenger side pipe is completely unbolted, and loose, but does not appear to have an easy method of extraction. Can it be done without removing the intake manifold?
Old 01-06-2013, 01:50 AM   #715
Andrewxxcarlson
Member#: 316415
2006 WRX
Interested. Benefits to taking out air pump are simply cleaning up the engine bay and if it doesn't function properly?
Old 01-07-2013, 10:44 PM   #716
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Also: Not having to replace a very expensive part when it fails (which it almost certainly will)
Old 01-09-2013, 09:45 PM   #717
Harry24
Member#: 272030
I had to cut mine out/in half with a sawzall... Totally sucked but worth it!
Harry24 is offline   Reply With Quote
Old 01-09-2013, 11:31 PM   #718
EvileyeZ88
Member#: 233501
99 outback sport
^ this
Old 01-11-2013, 12:01 AM   #719
Zebe
Member#: 118698
07 WRX Ltd Wagon
94 Miata
It came down to cutting the pipe. Part recip saw, part hacksaw, and a lot of elbow grease. So glad to be back in service with no CELs.
Old 01-11-2013, 12:16 PM   #720
StiBoost21
Member#: 317951
07 STI
Originally Posted by Acejam2k View Post
Just an update to my previous post:
2007 STI's have ports on *BOTH* heads. However, the passenger side head has a block-off plate on it from the factory, as displayed in the picture below. I found this on my 2007 STI, and on my friend's '07 as well. I have also confirmed this from other 2007 STI pictures that I've found on here and IWSTI.
2007 STI passenger side head with factory block-off plate:
So I might as well post something to this thread since every other member on nasioc did. Heres a question. If the 07's really do come from the factory with a block-off plate on the passenger side head....why are there two valves (according to some people on this thread, althought ive read both).
Can anyone please confirm whether there are 1 or 2 valves on the 07 stis. If there are two, is one of them on the passenger side or both on drivers side? And yes, ive read the whole thread.
StiBoost21 is offline   Reply With Quote
Old 01-11-2013, 12:18 PM   #721
Leafy
Member#: 330625
2006 WRX
STi have the block off. WRX have 2 valves.
Old 01-14-2013, 03:09 PM   #722
StiBoost21
Member#: 317951
07 STI
So to do this delete on 07 STI, one would only have to install 1 block-off plate on the driver side head, make sure to keep atmospheric pressure sensor in tact, and delete the cels via tune? I would think this delete would be a lot easier on the 07s since you only have one valve and the pump to take off on the drivers side and only requires access to the drivers side correct?
**Soo many comments on this thread some are contradicting **
Old 01-26-2013, 12:43 PM   #723
KSTech
Member#: 143570
This might help with showing the differences between the model years.
2006-2007 WRX (STI is similar but only one valve for the driver side):
2008+ WRX & STI, also 2005-2009 Legacy GT:
KSTech is offline   Reply With Quote
Old 01-26-2013, 12:44 PM   #724
KSTech
Member#: 143570
There is only one valve on the 2007 STI, and it is the only model like that.
Old 01-26-2013, 12:46 PM   #725
KSTech
Member#: 143570
The 2007 STI only needs the driver side block-off plate. It has the passenger side blocked off from the factory. This is the STI-only, not the WRX. It is much easier to do the 07 STI deletion than all the other models.
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
