Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 11-22-2012, 12:46 AM   #1
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
Default 2013 Nissan Leaf
http://www.thetruthaboutcars.com/201...-more-or-less/
Time will tell whether these JDM changes make it in full to the (Smryna built?) USDM model. Key changes include: 10% more range, possibly by virtue of strengthened regenerative braking; optional leather upholstery and a Bose stereo; and, possibly most significantly, the substitution of a heat pump in place of a pure resistive heating element.
This last is important because the >1 coefficient of performance of a heat pump will halve or perhaps cut by two thirds heating loads and the resultant range loss.
In any case, the outside appearance isn't changed. Here's the outside, in case you've been living under a rock, as well as the new interior leather:
Other notable vehicles in terms of HVAC: The PHEV Prius prototypes (but not the production model) also employed a heat pump, and the Volvo C30 EV prototypes employ a small biodiesel burner for auxiliary heat, of all things. Finally, the series 200 Land Cruiser and its Lexus cousin boast of the following:
Originally Posted by Toyota PR
In extreme cold situations, the Land Cruiser’s auxiliary Positive Temperature Coefficient (PTC) heater warms air instantly by passing it over an electrically heated ceramic element.
shikataganai is offline   Reply With Quote
Old 11-22-2012, 06:17 PM   #2
Otobot
Member#: 306844
I will hold off until the 2014 Outlander PHEV arrives to give that a try. I just dont want to spend that much on a car that I cant take on a road trip and have to constantly worry about being stranded. At least with a PHEV you have the benefit of an electric and the range of a hybrid when you need it.
Otobot is offline   Reply With Quote
Old 11-22-2012, 10:32 PM   #3
sxotty
Member#: 95600
2003 WRX wagon
Mitsubishi's promotional video for that outlander is awful, but I like the outlander myself as well. Probably cost *pinky $1 million dollars!!!
Shika let us know when Nissan improves the warranty on their battery or at least the thermal management system
sxotty is offline   Reply With Quote
Old 11-22-2012, 10:56 PM   #4
plunk10
Member#: 32342
2004 :derp:
I'm curious to see the Ford Ecoboost 1.0 liter 3 cylinder Fiesta then of course, the Cruze diesel. Some folks are reporting nearly 50 mpg in that new Fusion Hybrid too!
I like that the Leaf is improving, but it's still too many dollarbucks for my consideration.
plunk10 is offline   Reply With Quote
Old 11-22-2012, 11:21 PM   #5
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
5 year TCO for a Leaf SL is $2k cheaper than for a Fiesta SES, assuming you make enough to have at least $7,500 in Federal tax liability against which the credit is applied.
http://www.edmunds.com/tco.html
Old 11-22-2012, 11:21 PM   #6
Otobot
Member#: 306844
I agree that was pretty cheesy add, but what do you expect from the frenchies.... Haha. I do like the workings of the car. As far as cost I can see it being somewhere near 35k-40k. Mitsu said it would remain competitively prized. Add on the tax insentives for EV vehicles and its not such a bad deal.
the idea of a 300 combined hp Outlander with S-AWC that gets 100mpg seems pretty tough to pass on even if it cost more than 40k. Oh and forgot to mention the clean diesel option they will have.
Old 11-23-2012, 07:25 AM   #7
plunk10
Member#: 32342
2004 :derp:
thank! I need to show this to my buddy who is convinced a $30K hybrid is somehow better for his wallet than having no car payments while getting 22mpg.
Old 01-09-2013, 02:04 PM   #8
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
Lightbulb
As one can see from the PR linked below, all of the JDM changes described in the OP made it over to the USDM model, plus we got 6.6 kW charging, too! (Japan relies much more heavily on DC quick charging, e.g. CHAdeMO, so Level 2 charging power isn't as relevant for them.)
2013 USDM Nissan LEAF press release
Changes:
- now built in Smyrna, TN rather than in Japan
- new, stripper S trim lacking much of the below
- 6.6 kW Level 2 charger
- heat pump!
- black leather and 17"s
- option of the previously-seen-on-Infinitis Around View Monitor
- marginally increased range via aero and regeneration, marginally increased cargo volume
Pricing TBD.
Old 01-09-2013, 03:23 PM   #9
Balantz
Member#: 101457
Czar of Sweet Dance
Moves
Once range easily, reliably tops 100 miles, I'm in.
Balantz is offline   Reply With Quote
Old 01-09-2013, 04:12 PM   #10
plunk10
Member#: 32342
2004 :derp:
heat pump?
Old 01-09-2013, 08:22 PM   #11
skywaffles
Member#: 82470
show me your
wizard nose
heat pump?
Essentially an air conditioner run in reverse. It absorbs heat from an outside source and transfers it to a heat sink.
skywaffles is offline   Reply With Quote
Old 01-09-2013, 08:58 PM   #12
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
That's not happening with the current battery, and, for better or worse, manufacturers have de facto decided that an effective 75 mile range is sufficient. It's probably the right choice in terms of cost of the vehicle, getting the most units out there and in action, etc., but is still kind of annoying. Give me a choice of battery capacities a la Tesla, Nissan!
heat pump?
Yup, it transfers heat rather than creating it.
As I mentioned in my original post, "[the heat pump] is important because the >1 coefficient of performance [] will halve or perhaps cut by two thirds heating loads and the resultant range loss." A COP of ~3 would imply that powering the heat pump with 1 kW will result in 3 kW of heat transferred from the outside of the car to its interior.
Given that heating loads are a major factor in reducing range on EVs this is kind of a big deal, actually. Heated seats and a heated steering wheel reduce the need for warm air, but there comes a point when those tricks cease to work.
Old 01-09-2013, 10:42 PM   #13
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
Looks like COP doesn't go down to 1 until -15C.
Source: http://sfbayleafs.org/news/2013/01/2...ct-highlights/
Old 01-15-2013, 12:32 AM   #14
Rootus
Member#: 89821
2015 STI LE
http://www.autoblog.com/2013/01/14/n...massive-price/
The base price of the Leaf dropped $6,400 to $28,800. You lose some content, as expected, and don't get the fancy new charger, but this puts the out-of-pocket cost of the car really close to $20K. That makes it a lot more compelling as a commuter car.
Rootus is offline   Reply With Quote
Old 01-15-2013, 12:36 AM   #15
plunk10
Member#: 32342
2004 :derp:
yeah, the local CarMax has a 2012 for $24,000 and change. I think its around a $14K discount from MSRP
Old 01-15-2013, 12:39 AM   #16
Rootus
Member#: 89821
2015 STI LE
The effective MSRP for a base 2012 would have been ~28K, so 24K for a used one is about right.
Old 01-15-2013, 12:59 AM   #17
plunk10
Member#: 32342
2004 :derp:
no no, this one is BRAND NEW Leaf SL for $24k.
Here's the link (if it works)
http://tinyurl.com/b2q86uw
MSRP 38,270
CarMax 24,108
Old 01-15-2013, 01:05 AM   #18
Rootus
Member#: 89821
2015 STI LE
Ah, interesting. I didn't know CarMax did new car sales. I wonder if they're factoring the tax credit into the price. If not that's a pretty good deal.
Old 06-26-2013, 11:44 AM   #19
torquemada
Member#: 128484
2006 EDM WRX STI
http://green.autoblog.com/2013/06/25...nge-better-pe/
Nissan has sold tens of thousands of Leaf EVs around the world, but at least for the moment, only buyers in Japan will get to trick their electric vehicles out with the company's new Nismo Performance Package. The NPP's various modules will improve the aerodynamics, driving performance and even the energy efficiency of your Leaf, thanks to technology built up in Nissan's Nismo motorsports division.
The visual and aero changes include lightweight LMX6 aluminum wheels for around $450 each, as well as an add-on rear spoiler, front and rear bumpers and side skirts in the Aero Package (about $5,500 in fiberglass or $7,700 in wet carbon fiber). In addition, the $1,100 sports suspension kit incorporates reworked dampers and springs to improve handling while delivering a ride height that's lower by 30 millimeters.
The most interesting change, though, is the Sports Reset feature for roughly $1,400 US, which tunes the vehicle control module to both improve the driving characteristics that make it "possible to enjoy sports driving more" (according to Google Translate) and increase range. There are no official details on how many more miles can be tweaked out of the pack, but if any of these changes come to the US, this one would likely be the easiest to get people to sign up for.
For more JDM Leaf enhancements and pricing in yen, check out the translated Nismo release here.
Old 06-26-2013, 02:08 PM   #20
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
So for $1400 the Sports Reset feature will improve driving characteristics and increase range. At the same time. Right. Those are as mutually exclusive as you're going to get.
But a $7700 aero package, that sounds like a good deal.
Old 06-26-2013, 04:32 PM   #21
Balantz
Member#: 101457
Czar of Sweet Dance
Moves
Come on, Nissan. Just extend the damn range.
Old 06-26-2013, 04:48 PM   #22
SCRAPPYDO
Member#: 873
2013 F150 King Ranch
Datsun 71 240Z & 68 2000
It is the fine print my freind.
the sports reset turns off the fan, AC, heater, radio, GPS, glove box light, all but one rear LED, both headlights, all interior lights, etc and diverts power to the motor...
It is all in the details...
SCRAPPYDO is online now   Reply With Quote
