#2751 | |
Member#: 154043
NWIC
Vehicle:2006 WRX Wagon WRB |
#2752 |
Member#: 243992
MWSOC
Vehicle:2006 WRX TR WRB |
Off topic but will you be making ford Taurus sho stuff?
Hmm I also like the 8375 but I am worried it would be too laggy for a daily driven pump gas sub 450whp car. Especially since I'm looking for good response. But I do love the size of the s300 in the engine bay hahahhaha Last edited by WhatTurboLag?; 01-15-2013 at 02:40 PM. |
#2753 |
Member#: 100353
Here's where we stopped on my 8375 in the fall. Needs more fuel pump (maxed out the DW300) and more boost.
![]() ![]() Engine: - Fresh 2.5L shortblock - Fresh balanced/lightened crankshaft - Manley 99.75mm forged pistons - Manley Turbo Tuff I-Beam rods - ACL main/rod bearings - Vigilant Motorsports Built - BC springs w/ Ti retainers - GSC S2 cams - ARP L19 head studs - 11mm oil pump - Gates racing timing belt - Borg Warner twinscroll 83-75 - Fobia twinscroll headers/uppipe - 2x Turbosmart Compgate 40mm external wastegates - Turbosmart Race-port 50mm BOV - GrimmSpeed MBC/BCS hybrid - Treadstone 28 x 10.5 x 4.5in sti core - GrimmSpeed ported intake manifold (rotated) - GrimmSpeed phenolic spacers - GrimmSpeed gasets all around - Custom 2.75in charge piping Drivetrain: - ACT XT-SS Clutch, 6-puck sprung disc - Factory STI 6spd Short Shifter - Torque Solution Tranny Mount - Torque Solution Engine Mounts - Torque Solution Pitch Stop Mount - Street: BBS w/Hankook R-S3 255/40R17 Fuel: - Five-O 1600cc top feed injectors - DW300 in-tank pump - 3L+ surge tank in engine bay (winter 2012/2013) - Aeromotive 1000hp A1000 stealth pump (winter 2012/2013) - Aeromotive billet fuel pump speed controller (winter 2012/2013) - Aeromotive top feed fuel rails - Aeromotive A1000 -6 FPR - more AN fittings than you can shake a stick at Misc: - omni 4bar MAP sensor (converting to speed density) - odyssey pc680, relocated to trunk - rotated intake manifold (AC delete?) - new ported top feed TGVs - countless other random bits Last edited by TickTack; 01-15-2013 at 05:19 PM. |
#2754 |
Member#: 162063
Vehicle:2007 STI FR TS 8374 UGM |
thats the same turbo i run on my daily driver, its an animal...[/quote]
Geoff, I know I have been following these threads religiously. Im driving my mechanic up a wall (FAST). Homestretch...package is on its way. Ill keep you posted with the results. Thanks man. |
#2755 | |||
Member#: 133386
Tri-State
Vehicle:13 F150 ecoboost |
thank you!!Quote:
a friend of mine has the world's fastest ford flex @ 12.8sec quarter mile - this 7 passenger vehicle shares the same engine/bay/trans as the SHO. While i am focusing our efforts on the F150 (longitudinal) 3.5L platform, some tech will trickle down to the transverse 3.5L as well... ![]() |
#2756 | |
Member#: 44836
MAIC
Vehicle:1999 Fozzy silver |
e85 im guessing?
#2757 |
Member#: 243992
MWSOC
Interesting the 8070 has the same compressor cover as the 8375? I just like the s300 size compressor cover. My buddies s256 with anti surge cover was a little small. In the end it's just a ricer preference of mine but when it comes down to it ill go with what ever performs best regardless of looks.
#2758 |
Member#: 100353
Yes, that's on e85.
#2759 | |
Member#: 166264
Vehicle:1974 VW 2.2 BW8475 396 WHP @ 25psi |
![]() Maybe Geoff can be persuated to offer that turbo S200SX-7670 with a FMW compressor wheel? That would keep spool the same and maybe a tiny better then 8070. He also gave the S300 a FMW wheel.... ![]() |
#2760 |
Member#: 260314
NESIC
Vehicle:2008 STI hatch silver |
Am I to understand that this was without head modifications? What about TGV's?
I got that you did a reversed, ported GrimmSpeed intake manifold. Was this for drag racing? Looks like the full torque wasn't realized till after 5K RPM. Looks great on the top-end, especially if the fuel supply pooped out! ![]() |
#2761 | |
Member#: 100353
![]() Also, this was my first trip around the block with the car, very little throttle and almost no boost. Man are these turbos loud! |
#2762 |
Member#: 236252
Vehicle:08 STi DGM |
What is the best BW turbo to achieve 400 whp with better than stock spool?
I plan on trying to keep it simple and as inexpensive as i can. I want to go efr, ig, ts. Supporting mods will be cosworth pistons, tgv delete, port matched, light port work, dw fp, dw 1200 cc injectors, areomotive fpr, perrin fuel rails, grimmspeed ebc, p&l tb, fr twin scroll exhaust manifold and dp or nameless performance. Might do tomei cams and go one size bigger on the exhaust valve. And i will go sd in the end as well as an e85 map. Gas around here is 92 oct so i dont think 400whp and 400+lbft torque to the ground with better than stock spool is out of the question. I just dont know what efr turbo to get to achieve these goals. Last edited by mofoSTI; 01-25-2013 at 02:29 PM. |
#2763 | |
Member#: 290509
I had a setup made for my buddies 2.0l eclipse, he did a borg warner 57 trim with a custom cut t3 turbine inlet and 4 bolt 2.5 inch outlet to work with the perrin rotated set up (in case I ever need it for my subaru) good to 50 psi and it is slightly bigger than a garret gt30r and will make 400 without being too laggy
#2764 | |
Member#: 243992
MWSOC
The smallest one with a tiny ar. But faster than stock spool is probably not possible. A vf39 is a 6cm (maybe 7cm) hot side. |
#2765 | |
Member#: 330625
NESIC
Vehicle:2006 WRX WRB |
That 8375 is insane, you make the same torque as I do at my peak torque rpm, with a freaking td04, although I hit 300ftlbs sooner. Like holy ****. |
#2766 |
Member#: 236252
May go with the 6258. It spools the best. Im not concerned with hp so much as i am torque. For dd and autox. I supose i would get use to the power i will go with the 6758 but not any bigger. Kind of excited and cant wait to get it done
#2767 | ||
Member#: 133386
Tri-State
the other option worth consideration is the EFR 7064 twinscroll iwg, that would be a bit larger but still acheive your targets and goals. both of these are in stock right now, pretty rare for the EFRs Quote:
the 6258 is a 44lb/min compressor so it could do 400+ as long as the engine can breathe |
#2768 |
Member#: 258525
Tri-State
Vehicle:2004 STi-BW7670 R6-Red/White |
My BW s256 7670 hits about 28psi by around 3800RPMs. Power levels on a mustang were approx 400whp/444wtq. I dont have the chart on me right now.
#2769 |
Member#: 330625
NESIC
Hopefully the 6758 is also strangely in stock, since I ordered one yesterday for the miata.
#2770 |
Member#: 236252
Thanks guys. I'm going to run the 6258 and try to squeeze the most out of it. Then down the road go bigger when i get use to the power. Keep in mind that stock power is enough to get one in trouble. I will get use to 375 - 400 whp before i go for more. I already had an 04 STi running 355whp and 390 lbft to the ground.
#2771 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag |
Posted in ppb too but figured it was worth posting here
Event: Dyno Tune Location: Pro Power dyno, Rio Rancho NM Ambient Temp: 50 Elevation: 5400' Weather: cloudy Tires: Bridgestone RE090's- then again on BFG G force drag radials Car: 2006 WRX Limited Wagon Tuner: Myself Dyno Info: Dynojet Transmission: 2005 STi 6MT with rallispec long gear set Gear: 3rd Peak HP at RPM: 823 at 6700 Peak Torque at RPM: 667 at 6200 Baseline hp/tq for a stock STi: 245-255hp/250-260tq Target Boost: 33 Target AFR: 11.3 Fuel: E70 (winter blend) Engine/Power Modifications: AEM EMS V1 2005 EJ257 Block sleeved by Benson CP Pistons 99.5mm (moly coated skirts, ceramic crowns) Carrillo Pro H beam rods, Carrillo bolts Heat treated oem crank King bearings 2006 Sti AVCS heads, ported GSC Stage 2 cams (272, AVCS) BC +1mm intake/exhaust valves BC springs, titanium retainers ARP L19 Studs 08 Sti oil pump, 11mm TGV deletes AP Fuel rails Aeromotive FPR ID2200cc injectors Integrated Engineering Surge tank with Dual bosch 044 pumps Cosworth Intake manifold (reverse mount) Treadstone fmic core Full Race Twinscroll T4 rotated turbo kit BorgWarner EFR 9180 EWG 1.05 T4 Finally got to put the EFR through it's paces. I had previously run the S300SX 91-79 .91 AR on the car and was pretty happy with it. I am AMAZED that a 94lb/min turbo is spooling 400-500rpm sooner than the older 82lb/min turbo. On the first trip to the dyno last week I ran my 2007 STi RE090 tires which have good tread but are very dry. The car made 805/636 SAE at 33psi, but I suspected the tires were spinning. Here's a graph of those pulls: ![]() And a graph vs the old 91-79- The 91-79 was at 34psi. ![]() I decided to try the dyno again yesterday, this time with my drag radials. The results were that the car held traction better to about 6500rpm, then let go hard. The tune and boost were untouched from the previous dyno. ![]() Now, SAE numbers are great for bragging rights, but we are at 5400' and our correction factor is pretty high. Here is the uncorrected graph, which in my opinion is still a lot of power for this altitude, at only 33psi ( I want to run 37-38 but need traction). A stage 2 STi only makes 250 uncorrected on this dyno. ![]() ![]() Someone want to help me embed these? https://www.youtube.com/watch?v=ncnswSPEq4M https://www.youtube.com/watch?v=4u0JHvsxEZc low quality phone vid of the 823 pull https://www.youtube.com/watch?v=CViAUFZeBwk |
#2772 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
![]() 2007 STi Limited Link G4 Extreme Pro ECU Wiseco 100mm pistons 8.5:1 CR DPR ported heads, +1mm valves Cosworth 272 cams Full Race 7670 TS turbo kit Greddy EVO exhaust(I think) Aeromotive custom fuel rail setup Custom FMIC kit 3" custom CAI etc, etc, etc... Currently hitting 15 psi @ 3200 rpm holding to redline. ![]() The car is ridiculously fun to drive and proves to me it was worth the wait every time I start the car up. |
#2773 | |
Member#: 229518
South East
Vehicle:2011 STi DGM |
#2774 |
Member#: 180429
Vehicle:99 WRX Dark green |
Anyone know what the max angle would be on the 6258 prior to issues with oil return or oil going through back seal? Got two of these going on forged ez30r. Image of installation via link
https://www.dropbox.com/s/4ua07iqmyn...pg?n=152903952 |
#2775 |
Member#: 330625
NESIC
Go to borgs website and get the efr technical bible pdf. I believe its covered in there.
| Thread Tools | |
| Display Modes | |
| "Official" Post your suspension setup and settings thread. | ScreaminFast | Brakes, Steering & Suspension | 19 | 09-14-2011 09:59 AM |
| Post Your Winter Setup in here. | car_cursed | Member's Car Gallery | 43 | 10-26-2008 01:12 PM |
| Post your Exhaust setup. | Teh Legacy | Legacy Forum | 32 | 06-24-2005 03:44 PM |
| Post your room setup here. | file_id | Off-Topic | 26 | 04-15-2004 12:03 AM |
| Post your SM setup!!! | Davenow | Motorsports | 66 | 01-10-2004 03:12 PM |
