Old 01-14-2013, 10:21 PM   #1
rationull
Member#: 297202
2011 Impreza WRX
Default Is this a leak, or just water from the hood scoop?
2011 WRX here.
I know that the iron section between the turbine and compressor sections on our turbos will develop surface rust pretty much immediately, but the other day I noticed a discolored section. Not sure if it's just from water dripping in through the scoop (it's rained on and off over the past few weeks) or if it could be a leak (is that an oil or coolant line?)
There's no oily residue or anything -- when I touch it it just feels like rust. It's not wet now AFAICT.
Any thoughts?
rationull is offline   Reply With Quote
Old 01-14-2013, 10:55 PM   #2
myk
Member#: 223143
2001 2.5rs Sedan
Brack
If it isn't wet but looks wet which it does it's probably oil, potentially from the feed line. Easy enough to get some new copper crush washers and re-bolt it down.
myk is offline   Reply With Quote
Old 01-14-2013, 10:58 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Quit putting the lotion in the basket about one tiny, tiny, tiny mark. Hell if you stuck your head under my hood, you'd throw up blood within 9 seconds. It could oil, water, or Cherry Coke....regardless, it is super tiny and the size says don't worry.
Old 01-14-2013, 11:40 PM   #4
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Wow really?
Old 01-15-2013, 01:14 AM   #5
SuperScubi
Member#: 233407
2004 Aspen White STi
PIA Tune 347whp 327tq
OP... posting something like this is going to get you flamed
try the search button before posting something this minor
SuperScubi is offline   Reply With Quote
Old 01-15-2013, 01:54 AM   #6
rationull
Member#: 297202
2011 Impreza WRX
LOL! Didn't realize it would be a big deal. That's OK. Oil leak near the turbine section or other hot parts of the exhaust could be a big deal, just figured I'd see if this was something I should be looking into.
Old 01-15-2013, 10:46 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If it was leak, yes...check into it. One drop is hardly a leak though. Oil leaks will turn into a thick sludge build up within days and be SUPER evident as to something being wrong.
Old 01-15-2013, 11:12 AM   #8
Ballistic1350
Member#: 156877
04 sti
or you could take it to a dealer and let them deal with it since I assume your still on warranty...
Ballistic1350 is offline   Reply With Quote
Old 01-15-2013, 04:28 PM   #9
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
That is normal almost every turbo ive owned has that kinda discolor on it including my td04 ,vf52 (which is what you have) and also my 20g so i would not worry about it i know i dont.
nate_fisher is offline   Reply With Quote
Old 01-15-2013, 11:52 PM   #10
rationull
Member#: 297202
2011 Impreza WRX
To be clear, are you talking about the darker area or just the general rust color?
Old 01-16-2013, 08:13 AM   #11
nate_fisher
Member#: 270482
2011 turbotek fxt
Darker areas and rust color are normal imo
