Old 01-14-2013, 08:22 PM   #1
Boxerscoopy90
Member#: 309974
Default Max front camber
Guys when maxing out front camber with stock camber bolt all u do is that loosen the two bolts and bend the rotor and then just retighten it . Im going to have an aligment in few days so im not messing with any thing but am
I right ?
Boxerscoopy90 is offline   Reply With Quote
Old 01-14-2013, 08:25 PM   #2
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Are you the hulk? I know I cant bend a rotor.
vision.dynamix is online now   Reply With Quote
Old 01-14-2013, 08:47 PM   #3
Boxerscoopy90
Member#: 309974
Haha no im not . I mean u push it from the upper side
Old 01-14-2013, 09:06 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Are you entering Pike's Peak tomorrow? If you are getting an alignment in a few days just wait as what you can do at your house will add zero value to the next several days' driving unless your real name is Niki Lauda.
Old 01-14-2013, 09:43 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
If this is purely for giggles and you want to know HOW it works, jump to the suspension forum and begin learning.
Old 01-14-2013, 10:58 PM   #6
leecea
Member#: 37359
2003 WRX
First, you need to max out the stock camber bolt. Rotate that bolt and you'll see the hub moving slightly in and out at the top. Find the position where the top of the hub is as far in as it will go. That has maxed out the camber bolt.
Now you do get that last bit of camber by taking up the slack in the bolts holes, kinda the way you described. The way I do it is to place a short section of 2x4 lumber under the "hat" section of the rotor and gently jack up the 2x4 until the slack is all taken up. Now I can tighten the nuts while the jack holds the hub in place. Make sure you do not rotate the camber bolt while tighten the nut.
The amount of extra camber you get might not be significant, but it only takes a second to do.
leecea is offline   Reply With Quote
Old 01-16-2013, 09:35 AM   #7
Boxerscoopy90
Member#: 309974
This is all what i wanted to know .. Thank u
Old 01-16-2013, 09:53 AM   #8
Boxerscoopy90
Member#: 309974
Guys does the direction of the bolt and nut matters ? Because on my car the nut is looking toward the rear od the car and the bolt is toward the front of the car . It might be reversed because most pictures here are not like mine so is it fine ?
Old 01-16-2013, 10:32 AM   #9
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
No, it doesn't matter. But I believe it really only goes together one way, due to other bolts on the hub assembly getting in the way of the bolt going through from one direction. If you got it in, it's in.
Loyale93 is offline   Reply With Quote
